18830
18830
    AVENTOOLS(艾文)
    TWEEZER ASSORTED
18830 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address: www.aventools.com All Categories > Hand Tools > Tweezers and Smart Tweezers > Ceramic Tweezers > Item # 18830 Item # 18830, Ceramic Tipped Tweezers Set Set of 3 ceramic tipped tweezers with plastic hanldes. Tips are made from Zirconia ceramic that can withstand heat upto 1500 degree C. Tips have an extremely smooth surface and solder will not adhere to it. Resistant to hydroflouric acid. Set consists of one each of the following:Straight tip, Bent tip and Curved tip. Tip width: 2mm larger image Supplied in a protective plastic pouch. Features · Specifications Features z z z z z z z z z z z z z z Extremely smooth surface and very low coefficient of friction. Low thermal conductivity and high thermal shock resistance. Excellent electric loss at very high frequency range (VHF, UHF, and SHF). Will not cause electromagnetic induction or eddy current loss in high frequency. 100% non magnetic, non rusting and non static. Highly resistant to all strong acids except hydrofluoric. Free from all metallic contamination. Solder will not adhere to surface. Six times harder than stainless steel. Two times harder than carbon steel. Will hold tip geometry better than metal. Can be subject to microwaves for sterilization. Thermal insulators well suited for soldering. Resistant to 1500ºC Specifications Tip 1 each of Straight, Bent & Curved. Tip Width: 2mm Length 4-3/4 in Resistant Temperature 1500 ºC Weight 0.25 lb
18830 价格&库存
很抱歉,暂时无法提供与“18830”相匹配的价格&库存,您可以联系我们找货
