PT65501
PT65501
    APEM(埃斐)
    插件
    PT65501
PT65501 数据手册
PANEL PCB SWITCHES T -P SW 02 18 65 PT65 series Rotary code switches DISTINCTIVE FEATURES 4 actuator types Sub-miniature size Solder and flux sealed, washable ENVIRONMENTAL SPECIFICATIONS • Operating temperature: -20 °C to +70 °C (-4 °F to +167 °F) ELECTRICAL SPECIFICATIONS • Operating voltage : ≤ 42 V • Contact load, static : ≤ 0.2 A • Contact load, dynamic : ≤ 0.15 A • Initial contact resistance : 80 mΩ max. • Insulation resistance : 100 MΩ min. MECHANICAL SPECIFICATIONS • Torque : 0.7 Ncm min • Expected life : 10,000 cycles min. MATERIALS • Base : UL94-V0, high temperature thermoplastic • Cover : UL94-V0, high temperature thermoplastic • Actuator : PA 4.6 nylon • Contacts : gold over nickel plated phosphor bronze • Terminals : tin plated The company reserves the right to change specifications without notice. 1 Rotary code switches PCB MOUNTING SOLDERING PACKAGING • Switches for screwdriver slot or accessory actuation (PT651 and PT657) : tubes of 50 pieces • Switches with spindle (PT653) or segment wheel (PT655) : trays of 50 pieces • Accessories : bags of 50 pieces 7.62 (.300) 2.54 (.100) PCB RIGHT ANGLE 2.54 2.54 (.100) 2.54 (.100) • Wave soldering : 280 °C (536 °F) max. for 5 seconds max. PCB STRAIGHT Ø1.00 (.039 DIA) • Manual soldering : 340 °C (644 °F) max. for 2 seconds max. Ø1.00 (.039 DIA) • DIN CEI 68-2-20 2.54 (.100) 2 5.08 (.200) PCB RIGHT ANGLE 5.08 Ø1.00 (.039 DIA) PCB SWITCHES PT65 series Rotary code switches BUILD YOUR PART NUMBER PT65 SERIES CODES ACTUATORS TERMINALS 1 Screwdriver 01 BCD (none) 3 Spindle 02 BCD complement 5 Segment wheel 03 Hexadecimal 7 Accessories 06 Hexadecimal complement Straight L254 Right angle, spacing 2.54 (.100) L508 Right angle, spacing 5.08 (.200) AVAILABLE AS STANDARD PRODUCTS SCREWDRIVER SPINDLE SEGMENT WHEEL ACCESSORIES Upper actuation Side actuation Upper actuation Upper actuation Side actuation Upper actuation BCD PT65101 PT65101L254 PT65101L508 PT65301 PT65501 - PT65701 BCD COMPLEMENT PT65102 - - PT65502 - - HEXADECIMAL PT65103 PT65103L254 PT65103L508 PT65303 PT65503 PT65303L254 - HEXADECIMAL COMPLEMENT PT65106 - - - - - 6.50 (.256) 2.20 (.087) SCREWDRIVER SLOT - STRAIGHT TERMINALS 78 01 4 9 23 56 10.00 (.393) 10.00 (.393) 2.54 (.100) 0.20 (.008) 0.27 (.011) 3.20 (.126) 4.00 (.157) 7.62 (.300) 0.55 (.022) 1 C 4 8 C 2 4.00 (.157) 3 PANEL PCB SWITCHES PT65 series Rotary code switches ACTUATORS PT65 1 3 8 7 Screwdriver Spindle (grey) Segment wheel (grey) Accessories (see next page) 56 1 3 3.20 (.126) 01 78 7.70 (.303) 1.00 (.039) 9 9.50 (.374) 78 4 56 4.00 (.157) 1.05 (.041) 3.50 (.138) 4.40 (.173) 2.80 (.039) 7.30 (.287) 2.85 (.112) 3.20 (.126) 0 23 78 01 23 9 4 01 23 9 4.00 (.157) 56 1.00 (.039) 1.00 (.039) 4 PCB SWITCHES PT65 series 1.05 (.041) 7 5 CODES PT65 01 02 03 06 POSITION C MARKING 1 2 4 C POSITION 8 C MARKING 1 2 4 8 MARKING 1 2 4 POSITION 8 C MARKING 1 2 4 8 0 0 0 0 1 1 1 1 2 2 2 2 3 3 3 3 4 4 4 4 5 5 5 5 0 0 0 0 6 6 6 6 1 1 1 1 7 7 7 7 2 2 2 2 8 8 8 8 3 3 3 3 9 9 9 9 4 4 4 4 10 10 10 10 5 5 5 5 11 11 11 11 6 6 6 6 12 12 12 12 7 7 7 7 13 13 13 13 8 8 8 8 14 14 14 14 9 9 9 9 15 15 15 15 01 4 POSITION BCD BCD complement Hexadecimal Hexadecimal complement 02 03 06 Rotary code switches TERMINALS PT65 01 9 2.54 (.100) Ø1.00 (.039 DIA) 78 Ø1.00 (.039 DIA) Ø1.00 (.039 DIA) L508 2.54 (.100) 7.62 (.300) 2.54 (.100) 5.08 (.200) 01 01 9 78 9 78 L254 56 2.54 (.100) 2.54 (.100) 2.54 (.100) 23 4 2.54 (.100) 56 56 5.08 (.200) 2.54 (.100) (none) 23 4 23 4 7.62 (.300) (none) Straight L254 Right angle, spacing 2.54 (.100) L508 Right angle, spacing 5.08 (.200) ACCESSORIES To order separately. ACCESSORIES ADAPTED TO YOUR APPLICATIONS Basic model PT657 has been designed to accept different actuators with snap-in connection. According to your application, you can choose between spindles or plastic knobs in two different lengths and a Ø 17 mm (.669) knurled wheel for lateral marking. Standard colours are shown below. Special colours are also available on request. U4824 grey Length 13.3 mm U4832 black Length 5.3 mm (standard) U4906 red Length 15.7 mm U4916 red 11.60 (.457) 4.00 (.157) 3.10 (.122) green U4944 grey U4945 yellow U4946 red U4847/1 white/black Ø9.50 (.473 DIA) U4943 3.10 (.122) 4.40 (.173) 2.80 (.110) 7.70 (.303) blue 4.10 (.161) 2.10 (.083) 3.50 (.138) 3.10 (.122) 1.80 (.071) 7.62 (.300) KNURLED WHEEL (unmarked - marking on request) U4941 15.70 (.618) 5.30 (.209) 6.10 (.240) 10.50 (.413) Length 4.4 mm 13.30 (.524) 1.00 (.039) black 1.00 (.039) U4822 Length 11.6 mm (standard) DIMENSIONS 1.00 (.039) PLASTIC KNOBS COLORS 1.00 (.039) SPINDLES P/N 17.00 (.669) 7.20 (.283) 9.60 (.378) 5 PANEL PCB SWITCHES PT65 series Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: PT65101L508 PT65503 PT65501 PT65506 PT65521 PT65526 PT65301 PT65312 PT65303 PT65712 PT65701 PT65101L254 PT65121 PT65121L508 PT65106 PT65101 PT65117 PT65301V PT65102 PT65102L254 PT65102L508 PT65103 PT65103L254 PT65103L508 PT65106L254 PT65106L508 PT65112 PT65112L254 PT65112L508 PT65121L254 PT65125 PT65125L254 PT65125L508 PT65126 PT65126L254 PT65126L508 PT65127 PT65127L254 PT65127L508 PT65301L254 PT65301L508 PT65302 PT65302L254 PT65302L508 PT65303L254 PT65303L508 PT65305 PT65312L254 PT65312L508 PT65321 PT65321L254 PT65321L508 PT65326 PT65326L254 PT65326L508 PT65327 PT65331 PT65501L254 PT65501L508 PT65502 PT65502L254 PT65502L508 PT65503L254 PT65503L508 PT65506L254 PT65506L508 PT65512 PT65512L254 PT65512L508 PT65521L254 PT65521L508 PT65525 PT65526L254 PT65526L508 PT65701L254 PT65701L508 PT65703 PT65703L254 PT65703L508 PT65705 PT65706 PT65712L254 PT65721 PT65721L254 PT65721L508 PT65724 PT65724L254 PT65726 PT65726L254 PT65727 PT65731 PT65726L508 PT65725 PT65SG173 PT65725L254 PT65SG129 PT65SG178 PT65501RT PT65503RT PT65SG126
PT65501 价格&库存
很抱歉,暂时无法提供与“PT65501”相匹配的价格&库存,您可以联系我们找货
PT65501
  • 1+72.906431+9.47760
