PT65121
PT65121
    APEM(埃斐)
    插件
    PT65121
PT65121 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES ROTARY DIP SWITCHES Outside the U.S. and the UK, this series is sold as the CR36 series, with a blue case. FEATURES 3 + 3 terminal layout. Completely sealed for process compatibility. 4, 6, 8, 10 or 16 positions w/extensive codings. Precision designed detent action. Compact size. High reliability & long life. Clockwise or counterclockwise settable. Solder coated terminals. MATERIALS Base Cover Actuator Contacts Terminals Terminal sealing Actuator seal GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Switching capacity Initial contact resistance Insulation resistance 24 VDC max. 400 mA max. 150 mA max. 1.5 VA max. < 80 milliohms > 100 megohms UL94V-O, high temperature thermoplastic UL94V-O, high temperature thermoplastic POM Gold over nickel plated bronze Gold over nickel plated bronze Molded-in 'O'-ring MECHANICALS, THERMALS Torque Expected life Contact force Operating temperature range 7.0 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. -20°C to 70°C SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Solvent washing Aqueous cleaning 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred CODES NOTE: For each dial position in tables, Common terminal(s) (C) are connected to terminal number(s) indicated - i.e. none or combinations of 1, 2, 3, 4 or 8. Each model in this series has 2 Common terminals except codes 11 and 24 which have one. CODE 26 OCTAL 8 Positions Dial No. 1 0 1 2 3 4 5 6 7 P12 2 4 CODE 11 ON/0FF 4 Positions Dial No. 1 0 1 0 1 CODE 27 OCTAL COMPLEMENT 8 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 CODE 12 BCD 4 Positions Dial No. 1 0 1 2 3 BINARY CODED DECIMAL (01) 10 Positions Dial No. 1 2 4 0 1 2 3 4 5 6 7 8 9 2 8 CODE 21 DECIMAL 4 Positions Dial No. 1 1 2 3 0 2 3 COMP. OF BINARY CODED DECIMAL (02) 10 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 4 CODES 24 & 25 BCD 6 Positions Dial No. 1 2 4 0 1 2 3 4 5 BINARY CODED HEXADECIMAL (03) 16 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 A B C D E F CODE 05 GRAY CODE 16 Positions Dial No. 1 2 0 1 2 3 4 5 6 7 8 9 A B C D E F 4 8 COMP. OF BINARY CODED HEXADEC. (06) 16 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 A B C D E F APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com P Arrow shaped slot Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) Pitch Positions .100" (2,54) .200"(5,08) Binary Coded Decimal 10 PT65101 PT65101L254 PT65101L508 Comp. of Binary Coded Dec. 10 PT65102 PT65102L254 PT65102L508 Binary Coded Hexadecimal 16 PT65103 PT65103L254 PT65103L508 Comp. of Binary Coded Hex. 16 PT65106 PT65106L254 PT65106L508 Code 12, Binary Coded Dec. 4 PT65112 PT65112L254 PT65112L508 Code 21, Decimal 4 PT65121 PT65121L254 PT65121L508 Code 25, Binary Coded Dec. 6 PT65125 PT65125L254 PT65125L508 Code 26, Octal 8 PT65126 PT65126L254 PT65126L508 Code 27, Octal complement 8 PT65127 PT65127L254 PT65127L508 Spindle Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) Pitch Positions .100" (2,54) .200"(5,08) 10 PT65301 PT65301L254 PT65301L508 Comp. of Binary Coded Dec. 10 PT65302 PT65302L254 PT65302L508 Binary Coded Hexadecimal 16 PT65303 PT65303L254 PT65303L508 Code 12, Binary Coded Dec. 4 PT65312 PT65312L254 PT65312L508 Code 21, Decimal 4 PT65321 PT65321L254 PT65321L508 Code 26, Octal 8 PT65326 PT65326L254 PT65326L508 Code 27, Octal complement 8 PT65327 PT65327L254 PT65327L508 Binary Coded Decimal P SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES Segment Wheel Actuator Models Complete Model No. by Terminal Style Right Angle Straight Code (see truth tables) .100" (2,54) .200"(5,08) 10 PT65501 PT65501L254 PT65501L508 Comp. of Binary Coded Dec. 10 PT65502 PT65502L254 PT65502L508 Binary Coded Hexadecimal 16 PT65503 PT65503L254 PT65503L508 Code 21, Decimal 4 PT65521 PT65521L254 PT65521L508 Code 26, Octal 8 PT65526 PT65526L254 PT65526L508 Binary Coded Decimal Positions Pitch All models listed on this page have 2 Common terminals except Code 11 and Code 24 which have one. Other codes are available - consult factory. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com P13 PT65 SERIES Cross shaped slot Actuator Models Complete Model No. by Terminal Style Right Angle Straight SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Code (see truth tables) Positions Pitch .100" (2,54) .200"(5,08) Binary Coded Decimal 10 PT65701 PT65701L254 PT65701L508 Comp. of Binary Coded Dec. 10 PT65702 PT65702L254 PT65702L508 Binary Coded Hexadecimal 16 PT65703 PT65703L254 PT65703L508 Code 05, Gray Code 16 PT65705 PT65705L254 PT65705L508 Comp. of Binary Coded Hex. 16 PT65706 PT65706L254 PT65706L508 Code 11, ON/OFF 4 PT65711 PT65711L254 PT65711L508 Code 12, Hexadecimal 4 PT65712 PT65712L254 PT65712L508 Code 21, Decimal 4 PT65721 PT65721L254 PT65721L508 Code 24, Binary Coded Dec. 6 PT65724 PT65724L254 PT65724L508 Code 25, Binary Coded Dec. 6 PT65725 PT65725L254 PT65725L508 Code 26, Octal 8 PT65726 PT65726L254 PT65726L508 Code 27, Octal complement 8 PT65727 PT65727L254 PT65727L508 Operating Elements snap-fit securely into PT65 (& P60A) Series switch models with cross shaped slot actuators. Order separately by Model number shown below and indicate color. Spindle colors: red, gray or black (consult factory for color codes) US Model No. Dim. A EU Model No. SAPT65473 .287 N/A SAPT654116 .457 U4820 SAPT654133 .524 U4830 P Short spindle above applies to model SAPT65473 only Segment wheel colors: yellow, red, green, blue, gray or black (consult factory for color codes) US Model No. EU Model No. SRPT659544 U4940 Knob color: red US Model No. Dim. A EU Model No. DKPT6510553 .209 U4906 DKPT65105157 .618 U4916 DKPT65105291 1.146 N/A DKPT65105344 1.354 N/A Short knob above applies to model DKPT6510553 only Wheel color: white US Model No. Dim. A EU Model No. DRPT651772 .283 U4847/1 printing on request (fits PT65 models only) P14 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com MECHANICAL OUTLINES Terminal option suffix*: Mtg. hole pattern: Codes 01 BCD 02 BCD complement 03 Hexadecimal 06 Hexadecimal Comp. See other available codes on page G17 NONE Straight terminals Terminals None Straight V Crimped L254 Rt. angle 2.54 (.100") L508 Rt. angle 5.08 (,200") ORDER GUIDE: V Crimped terminals Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. L254 Right angle terminals Example; PT65101V Series Actuator Terminals Code L508 Right angle terminals P * 'None' indicates no option suffix is required. TERMINAL IDENTIFICATION FOR ALL MODELS (viewed from top of switch inserted into printed circuit board). Refer to TRUTH TABLES on page G17. 1 C C Code 11 2 1 2 C C C 4 3 1 Code 12 Code 21 1 C 2 4 Code 24 1 1 8 C C C C 4 2 4 2 Codes 25 & 26 Code 27 and 10& 16 pos. models P15 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. PT65 SERIES STANDARD OPTIONS : Actuators 1 Arrow shaped slot 3 Spindle 5 Segment wheel 7 Cross shaped slot PT65 SERIES
PT65121 价格&库存
很抱歉,暂时无法提供与“PT65121”相匹配的价格&库存,您可以联系我们找货
PT65121
  • 1+74.247841+9.63602
  • 10+61.6732110+8.00406
  • 50+53.9537950+7.00222
  • 100+51.02988100+6.62275
  • 250+47.57387250+6.17422
  • 500+45.26923500+5.87512
  • 1000+43.223051000+5.60957
库存:1465
PT65121
  • 10+112.0774910+14.54562
  • 25+77.4229125+10.04808
  • 50+73.0564650+9.48140
  • 100+59.34387100+7.70175
  • 250+55.60362250+7.21634
库存:305
PT65121
    • 1+36.92520
    • 200+14.74200
    • 500+14.24520
