TDS SERIES SP 3 POSITION
3 STATE (+,0,-) DIP SWITCHES
FEATURES
3 code functions per position (n).
Self-cleaning twin point contacts.
UL94V-O materials used throughout.
Process compatible.
Crimped terminals for positive p.c.
board retention during installation.
GENERAL SPECIFICATIONS
Electrical life
2000 operations minimum per switch
Contact rating, non-switching
100 mA at 50 VDC
Contact rating, switching
25 mA at 24 VDC
Contact resistance Initial:50 mΩ max. After 2000 operations: 100 mΩ max.
Insulation resistance 100 MΩ minimum between adjacent terms.at 500 VDC
Dielectric strength 500 VDC for 1 minute
Capacitance
5 pf. maximum
MECHANICALS, THERMALS
Mechanical life
Operating force
Vibration
Shock
Temperature range
1000 grams maximum
10-55-10 Hz./1 min. (3 planes) per MIL-STD-202F, METHOD 201A
50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B
Operating and storage: -40°C to +85°C
SOLDERING RECOMMENDATIONS*
Hand soldering
320°C max. for 2 seconds max.(30 watt iron max.)
Wave soldering
260°C max. for 5 seconds
*For best results, keep actuator in 'O' position during soldering.
G
MATERIALS
Base
Cover
Actuators
Contacts
Terminals
UL94V-O, glass fiber filled PBT, black
UL94V-O, glass fiber filled Nylon, white
Gold over nickel over brass
90/10 Solder plate over brass
PACKAGING
Normally supplied in standard IC tubes with all actuators
in the 'O' position
MODEL
NO. 0F
NUMBER POS. (n)
G14
G01-G14
A DIM. (MAX)
B DIMENSION
INCHES
MM
INCHES
MM
TDS04
4
.557
14.14
.300
7.62
TDS08
8
.957
24.3
.700
17.78
TDS09
9
1.057
26.84
.800
20.32
TDS10
10
1.157
29.39
.900
22.86
APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com
14
10/3/00, 3:51 AM
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
ELECTRICALS
很抱歉,暂时无法提供与“TDS08”相匹配的价格&库存,您可以联系我们找货
