CS-32-12ZEB
CS-32-12ZEB
    NIDEC(尼得科)
    SWITCHROTARYDIPSPDT100MA16V
CS-32-12ZEB 数据手册
ROTARY SELECTOR SWITCHES (SMD) RoHS compliant CS-32 INTERNAL STRUCTURE ① ② ⑦ ⑥ ⑤ ③ ④ Part name ■ FEATURES ● ● ● ● ● ● RoHS compliant Optimum for high density board mounting applications Compatible with most automatic pick & place machinery Protection against dust and washable after soldering Top and side setting types are available Same dimensions as ST-32 trimmer and conveniently usable as a set ● Resin materials are UL Recognized 94V-0 or 94V-1 equivalent ⑧ Material ① Wiper Multi metal alloy ② Cover Stainless steel (SUS 304) ③ Housing ④ Terminal pin ⑤ Base element ⑥ “O” ring ⑦ Rotor ⑧ Electrode Epoxy Copper alloy, Sn-Cu-plated Ceramic Silicone rubber Polyphenylenesulphide Ag-Pd cermet ■ PART NUMBER DESIGNATION CS-32 - 1 2 Z E T A Series name Shape of terminal No. of poles A, G:J-hook B, H:Gull wing C:Through hole pins 1 pole Form of packaging No. of contacts T:Taping (Reel) Blank:Bulk in plastic bag 2 contacts Contact timing Terminal pin Z:Non-shorting (without neutral detent) E:Sn-Cu (Lead-free) ※ Please refer to the LIST OF PART NUMBERS when placing orders. CS-32 ROTARY SELECTOR SWITCHES (SMD) ■ SCHEMATICS DIAGRAMS ● 1 pole 2 contacts Switching specifications Series Schematic C CW C ON CCW CW CS-32-12ZEA 〃 12ZEB 〃 12ZEC 〃 12ZEG 〃 12ZEH C C OFF CCW CW CW C CCW CCW C ON CW CCW ■ LIST OF PART NUMBERS Circuit type A, G J-hook B, H Gull wing Taping CS-32-12ZETA CS-32-12ZETB Plastic bag CS-32-12ZEA CS-32-12ZEB Taping CS-32-12ZETG CS-32-12ZETH 500 pcs. /reel Plastic bag CS-32-12ZEG CS-32-12ZEH 100 pcs. /pack Setting position Form of packaging C Pieces in package Through hole pins 500 pcs. /reel Top setting 1 pole 2 contacts Whitout neutral detent CS-32-12ZEC 100 pcs. /pack Side setting ※ Verify the above part numbers when placing orders. Taping version can be supplied only in reel unit. CS-32 ROTARY SELECTOR SWITCHES (SMD) ■ STANDARD SPECIFICATIONS Circuit type Operating temperature range ■ ELECTRICAL CHARACTERISTICS 1 pole 2 contacts −40 ~ 85 °C Storage temperature range Sealing Net weight Washable by “O” ring ※ Please refer to page 150, 151 Approx. 0.05g (A, B) Approx. 0.06g (C) Approx. 0.11g (G, H) Maximum current 100 mA Maximum voltage 16 V Contact timing Non-shorting Contact resistance 2 Ω maximum Insulation resistance 100 MΩ (DC500 V) minimum Dielectric strength ■ MECHANICAL CHARACTERISTICS No. of positions 0.5 VA Contact rating AC250 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 3 times each 2 Vibration Stopper strength Stepping angle Solderability Soldering heat 5 mN·m {51 gf·cm} maximum Sn-Cu (lead-free): 245 ± 3 °C, 2 ~ 3 s Shear (Adhesion) 5 N {0.51 kgf}, 10 s Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength Relative humidity 90 ~ 95 %, 240 h Humidity (Steady state) High temperature exposure 85 °C, 96 h Low temperature exposure −40 °C, 96 h Thermal shock −40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles 〈Reflow profile for soldering heat evaluation〉 (℃) 250 Peak : 250 0 ℃ 200 180 ℃ Pre Heating Zone 150 150 ℃ 100 5 N {0.51 kgf}, 10 s 50 { } : Reference only 50 cycles minimum DC16 V 30 mA Load life 250° ± 15° Sn-Cu (Lead-free) Flow : 260 ± 3 °C as the temperature in a pot of molten solder, immer­sion from head of ter­minal to backside of board, 5 ~ 6 s, two times maximum. Reflow : Peak temperature 255 °C (Please refer to the profile below.) Manual soldering : 350 ± 10 °C, 3 ~ 4 s 490 m/s2, 11 ms 6 directions for 3 times each Shock 20 mN·m {204 gf·cm} minimum Temperature Adjustment torque +5 Over 230 ℃ 90±30 s 30±10 s Heating time Soldering Zone リフロー回数: 2回 Reflow : two times maximum CS-32 ROTARY SELECTOR SWITCHES (SMD) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CS-32-12ZEA 1 C 0.6 CW 3.4 CCW 0.5W × 1.9L × 0.45D 2 3.4 3.5 Production date code & Lead-free Identification mark, 1 digit (Location reversed every 2 years) 2 – 0.7 t = 0.12 2.1 0.05 2 C CCW CW ● CS-32-12ZEB 1 C CW 3.4 CCW 0.5W × 1.9L × 0.45D 2 4.4 3.4 Production date code & Lead-free Identification mark, 1 digit (Location reversed every 2 years) 0.05 2 2 – 0.7 t = 0.12 2.1 C CCW CW C 1 0.5W × 1.9L × 0.45D 3.4 3.5±1 Production date code & Lead-free Identification mark, 1 digit (Location reversed every 2 years) 2 ● CS-32-12ZEC t = 0.12 3.4 1.3 CCW C CCW 1 4±1 2 CW 0.05 max CW No plating on the cut surface ● CS-32-12ZEG 0.2 3.5 Operating face 2 – 0.7 2.1 2.4 2 – 0.6 1.1 2.6 4.7 1.7 1 Production date code & Lead-free Identification mark, 1 digit (Location reversed every 2 years) CW C 3.6 0.5W × 1.9L × 0.45D C CCW 1 CCW CW t = 0.12 CS-32 ROTARY SELECTOR SWITCHES (SMD) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● CS-32-12ZEH 2.4 2 – 0.6 3.5 0.2 Operating face 1.4 0.5W × 1.9L × 0.45D 1.3 2.6 4.7 1.7 Production date code & Lead-free Identification mark, 1 digit (Location reversed every 2 years) CW C CCW 1 t = 0.12 3.6 C CCW CW ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● CS-32-12ZEA, 12ZEG ● CS-32-12ZEB, 12ZEH 1.6 (Unit: mm) 0.9 2.2 1.5 1.6 0.9 1 4.6 0 1.2 0.8 1.9 1.2 1 6 0 1.2 3.2 1.2 0.8 3.2 Note 1) The zero point is the center of mounting. Note 2) The land patterns conform to EIAJ RC2161. Note 3) The land patterns are for reflow soldering. 1.2 CS-32 ROTARY SELECTOR SWITCHES (SMD) ■ PACKAGING SPECIFICATIONS ● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. ● CS-32ZETA and ZETB versions are boxed with 4 reels (2000 pcs.). CS-32ZETG and ZETH versions are boxed with one reel (500 pcs.) Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the dia-grams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) +1 13 0 (ETA/ETB) +1 13.4 0 (ETG/ETH) Empty Filled End φ21±0.8 Head 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed φ60 +10 (ETA/ETB) φ50 min. (ETG/ETH) Empty 2±0.5 φ13±0.2 15.41 (ETA/ETB) 17.41 (ETG/ETH) φ180 –1.5 (Top setting type) φ254±2 (Side setting type) 0 ● CS-32-12ZETA/CS-32-12ZETB ● CS-32-12ZETG/CS-32-12ZETH (Unit: mm) 0.3±0.1 8±0.1 2±0.1 4±0.1 .1 +0 0 5 1. φ 2±0.05 .1 +0 0 5 1. φ 4±0.1 1.75±0.1 8±0.1 1.75±0.1 (Conforms to JIS C 0806) 0.4±0.1 Installation example (CS-32EH) 12 5.5±0.1 12 5.5±0.05 Installation example (CS-32EA) 2.5 Direction of feed ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs. , etc. ● Boxing of bulk in a plastic bag is performed with 100 pcs. (standard 500 pcs.) per box. 5.5 max. Direction of feed
CS-32-12ZEB 价格&库存
很抱歉,暂时无法提供与“CS-32-12ZEB”相匹配的价格&库存,您可以联系我们找货
