PANEL
PCB SWITCHES
N
-IK
2
80
-1
IKN series
SW
Surface mount and through-hole • low profile •
dual in line switches
DISTINCTIVE FEATURES
Low profile
Wide operating temperature range
Self-cleaning wiping contacts
Tin plated terminals
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature : -40 °C to +100 °C (-40 °F to 212 °F)
• Storage temperature : -40 °C to +125 °C (-40 °F to 257 °F)
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating :
- switching : 100 mA 24 VDC
- non-switching : 100 mA 48 VDC
• Contact resistance :
- initial : 30 mΩ max.
- after 2,000 cycles : 100 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength : 500 VAC min.
• Electrical life : 2,000 cycles
• Travel : 0.67 mm (.026)
MATERIALS
• Case and actuator : UL 94-V0 thermoplastic
• Stationary contact : bronze, gold plated over nickel barrier
• Moving contact : beryllium copper, gold plated
• Terminals : tin plated over nickel barrier
• Protection tape : polyimide
The company reserves the right to change specifications without notice.
1
7.30
(.287)
1.55
(.061)
A
0.60
(.023)
IC TUBE
APEM
2.85
(.112)
1
4
ON
1.50
(.059)
3
APEM
5
6
7
8
7.30
(.287)
8.00
(.314)
Coplanarity
MAX 0.102 (.004)
2.54
(.100)
10.00 Maxi
(.394 MAX)
1
SURFACE MOUNT
4
3
1.27
(.050)
APEM
ON
Number of ways
Qty per tube
2
88 pcs
4
48 pcs
6
33 pcs
8
25 pcs
TAPE AND REEL
Unrolling direction
1
ON
3
4
APEM
L
2
12.00
(.472)
Ø100.00 mini
(3.937 DIA MIN)
Ø13.00 0.25
(.511 DIA .009)
Number of ways
2
4
3.00
(.118)
A
Tape dim. “L”
Reel dim. “A”
16 (.629)
16.40 (.646)
CIKNR
24 (.944)
6
24 (.944)
8
32 (1.259)
24.40 (.960)
FICHIER:
CIKNR
24.40
(.960)
Page F11
ECHELLE: 0.8
32.40
(1.275)
Indice
le 06/02/02
Standard packaging unit : 1,000 pieces
2
2.54
(.100)
1.77
(.069)
0.60
(.023)
1.00
(.039)
1 2 3 4 5 6 7 8
1
ON
2
APEM
1.00
(.039)
7.62
(.300)
ON
2
458.00
(18.031)
10.00
(.393)
4
1.00
(.039)
3
0.30
(.011)
4
3
APEM
2
2
11.60
(.456)
Ø0.80
(.031 DIA)
A
1
10.00 Maxi
(.393 MAX)
THROUGH-HOLE
1.00
(.039)
ON
PCB LAYOUT
7.62
(.300)
7.62
(.300)
2.54
(.100)
3.40
(.133)
4.00
(.157)
PACKAGING
Ø360.00 Maxi
(14.173 DIA MAX)
PCB SWITCHES
IKN series
2.54
(.100)
BUILD YOUR PART NUMBER
IKN
SERIES
MODEL TYPE
NUMBER OF WAYS
TAPE SEAL
02
Two way
000
Through-hole IC tubes
04
Four way
030
SMT IC tubes
06
Six way
040
SMT tape and reel
08
Eight way
00
Top tape seal
Other models
(3, 5 and 7 ways) : on request
TAPE
THROUGH-HOLE
7.30
(.287)
4
11.10 (.437)
6
16.20 (.637)
8
21.30 (.838)
2.54
(.100)
7.62
(.300)
0.60
(.023)
10.00 Maxi
(.393 MAX)
1.00
(.039)
APEM
ON
1
Ø0.80
(.031 DIA)
2
3
4
5
1.50
(.059)
6
7
8
7.62
(.300)
6 (.236)
3.40
(.133)
Dimension “A”
2
1.00
(.039)
Number of Poles
4.00
(.157)
1.55
(.061)
A
2.54
(.100)
Supplied with all poles in “ON” position.
TAPE
7.30
(.287)
6 (.236)
4
11.10 (.437)
6
16.20 (.637)
8
21.30 (.838)
10.00 Maxi
(.394 MAX)
1.00
(.039)
1.27
(.050)
APEM
ON
1 2 3 4 5 6 7 8
8.00
(.314)
0.60
(.023)
7.62
(.300)
2
0.30
(.011)
Dimension “A”
Coplanarity
MAX 0.102 (.004)
1.00
(.039)
Number of Poles
2.85
(.112)
A
2.54
(.100)
1.77
(.069)
SURFACE MOUNT
2.54
(.100)
3
PANEL
PCB SWITCHES
IKN series
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
IKN0804000 IKN0803000 IKN0200000 IKN0203000 IKN0204000 IKN0400000 IKN0403000 IKN0404000
IKN0600000 IKN0603000 IKN0604000 IKN0800000
很抱歉,暂时无法提供与“IKN0404000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+36.569471+4.73229
