TDS10
TDS10
    APEM(埃斐)
    插件,P=2.54mm
    开关 DIP 三进制
TDS10 数据手册
TDS SERIES SP 3 POSITION 3 STATE (+,0,-) DIP SWITCHES FEATURES 3 code functions per position (n). Self-cleaning twin point contacts. UL94V-O materials used throughout. Process compatible. Crimped terminals for positive p.c. board retention during installation. GENERAL SPECIFICATIONS Electrical life 2000 operations minimum per switch Contact rating, non-switching 100 mA at 50 VDC Contact rating, switching 25 mA at 24 VDC Contact resistance Initial:50 mΩ max. After 2000 operations: 100 mΩ max. Insulation resistance 100 MΩ minimum between adjacent terms.at 500 VDC Dielectric strength 500 VDC for 1 minute Capacitance 5 pf. maximum MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Temperature range 2000 operations minimum per switch 1000 grams maximum 10-55-10 Hz./1 min. (3 planes) per MIL-STD-202F, METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B Operating and storage: -40°C to +85°C SOLDERING RECOMMENDATIONS* Hand soldering 320°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds *For best results, keep actuator in 'O' position during soldering. G MATERIALS Base Cover Actuators Contacts Terminals UL94V-O, glass fiber filled PBT, black UL94V-O, glass fiber filled PBT, black UL94V-O, glass fiber filled Nylon, white Gold over nickel over brass 90/10 Solder plate over brass PACKAGING Normally supplied in standard IC tubes with all actuators in the 'O' position MODEL NO. 0F NUMBER POS. (n) G14 G01-G14 A DIM. (MAX) B DIMENSION INCHES MM INCHES MM TDS04 4 .557 14.14 .300 7.62 TDS08 8 .957 24.3 .700 17.78 TDS09 9 1.057 26.84 .800 20.32 TDS10 10 1.157 29.39 .900 22.86 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 14 10/3/00, 3:51 AM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS
TDS10 价格&库存
很抱歉,暂时无法提供与“TDS10”相匹配的价格&库存,您可以联系我们找货
