NDI & DM SERIES
SPST STANDARD DIP SWITCHES
FEATURES
High reliability.
Self-cleaning contacts.
Multi- positions.
Process compatible with tape seal.
Dual in-line .100" x .300" term. spacing.
GENERAL SPECIFICATIONS
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
ELECTRICALS
Electrical life
Contact rating, non-switching
Contact rating, switching
Contact resistance at current 100 mA
Insulation resistance at 500 VDC
Dielectric strength
Capacitance
2000 cycles min. per switch @ 24 VDC, 25 mA
100 mA at 50 VDC
25 mA at 24 VDC
50 milliohms max. initial - 100 milliohms max. after life test
100 Megohms minimum
500 VAC for 1 minute
5 pf. max. between adjacent terminals
MECHANICALS, THERMALS
Mechanical life
Operating force
Vibration
Shock
Operating temperature range
1000 grams max.
10-55 Hz.per MIL-STD-202F METHOD 201A
50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B
-20°C to 85°C
SOLDERING & CLEANING RECOMMENDATIONS*
Hand soldering
350°C max. for 2 seconds max.(30 watt iron max.)
Wave soldering
260°C max. for 5 seconds max.
Cleaning (with tape seal)
Spray wash from top side only.
* Note: keep switches in “OFF” position during soldering and cleaning for best results
MATERIALS
Base & Cover
Actuators
Contacts
Terminals
Term. Sealing
Tape seal
P
NDI: UL94V-O, glass fiber filled PBT, black
DM: UL94V-O, glass fiber filled PPS, black
UL94V-O, Nylon, white
Gold over nickel plated copper alloy
Gold plated brass.
Molded-in
Kapton
PACKAGING
DIP switches are shipped in standard IC tubes with all actuators in the "OFF" position.
Tape & reel packaging per EIA available for DMR models (see next page).
SWITCH
CROSS
SECTIONS
SCHEMATIC (TYPICAL)
Double
contact system
DI & DM
See tabulations on following pages for
number of positions available (10 shown)
APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com
P2
Recessed
Spread terminals
MODEL
NO.
with no
tape seal
MODEL
NO.
with
tape seal
MODEL
NO.
with no
tape seal
MODEL
NO.
with
tape seal
No.
'A' Dim.
of
+.008/-.000"
Pos. (+0.2/-0.0mm)
NDI01H
NDI02H
NDI04H
NDI06H
NDI08H
NDI10H
NDIR01H
NDIR02H
NDIR04H
NDIR06H
NDIR08H
NDIR10H
n/a
n/a
n/a
n/a
n/a
n/a
n/a
NDIR02HT
NDIR04HT
NDIR06HT
NDIR08HT
NDIR10HT
NDI01S
NDI02S
NDI04S
NDI06S
NDI08S
NDI10S
NDIR01S
NDIR02S
NDIR04S
NDIR06S
NDIR08S
NDIR10S
n/a
n/a
n/a
n/a
n/a
n/a
n/a
NDIR02ST
NDIR04ST
NDIR06ST
NDIR08ST
NDIR10ST
1
.137 (3,48)
2
.237 (6,02)
4
.437 (11.10)
6
.637 (16,18)
8
.837 (21,26)
10 1.037 (26,34)
1
.137 (3,48)
2
.237 (6,02)
4
.437 (11,10)
6
.637 (16,18)
8
.837 (21,26)
10 1.037 (26,34)
+ Auto-insertable
using equipment from Amistar, Dynapert,
Panasert, Northeastern Tool, Universal and others.
n/a = not available.
P
DM Series
Surface
Mount +
Actuator
Style
Raised
Actuator
Recessed
Actuator
MODEL
NO.
with no
tape seal
DM01
DM02
DM03
DM04
DM05
DM06
DM07
DM08
DM09
DM10
DM12
DMR01
DMR02
DMR03
DMR04
DMR05
DMR06
DMR07
DMR08
DMR09
DMR10
DMR12
MODEL
NO.
with
tape seal
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
DMR02T
DMR03T
DMR04T
DMR05T
DMR06T
DMR07T
DMR08T
DMR09T
DMR10T
DMR12T
'A' Dimension
No. of +.008/-.000"
Pos. (+0.2/-0.0mm)
1
2
3
4
5
6
7
8
9
10
12
1
2
3
4
5
6
7
8
9
10
12
.137
.237
.337
.437
.537
.637
.737
.837
.937
1.037
1.237
.137
.237
.337
.437
.537
.637
.737
.837
.937
1.037
1.237
(3,48)
(6,02)
(8,56)
(11,10)
(13,64)
(16,18)
(18,72)
(21,26)
(23,80)
(26,34)
(31.42)
(3,48)
(6,02)
(8,56)
(11,10)
(13,64)
(16,18)
(18,72)
(21,26)
(23,80)
(26,34)
(31.42)
For tape & reel packaging on DMR models only, add 'TR'
to model number - example: DMR08TTR. Note- tape &
reel packaging is available only with tape seal models.
900 switches per reel.
P3
Actuator
Squared terminals
Raised
NDI Series
Machine
Insertable +
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
NDI01H NDI01S NDI02H NDI02S NDI04H NDI04S NDI06H NDI06S NDI08H NDI08S NDI10H NDI10S
NDIR01H NDIR01S NDIR02H NDIR02HT NDIR02S NDIR02ST NDIR04H NDIR04HT NDIR04S NDIR04ST
NDIR06H NDIR06HT NDIR06S NDIR06ST NDIR08H NDIR08HT NDIR08S NDIR08ST NDIR10H NDIR10HT
NDIR10S NDIR10ST DM01 DM02 DM04 DM05 DM06 DM08 DM09 DM10 DM12 DMR01 DMR02 DMR02T
DMR02TTR DMR03T DMR04 DMR04T DMR04TTR DMR05T DMR06T DMR06TTR DMR07T DMR08 DMR08T
DMR08TTR DMR09T DMR09TTR DMR10 DMR10T DMR12T DMR12TTR DMR05TTR DMR03TTR
