MDG601ST
MDG601ST
    APEM(埃斐)
    DIP
    TRANSFER DIP SWITCH
MDG601ST 数据手册
MDG & MPG SERIES TRANSFER DIP SWITCHES SPDT & DPDT MODELS FEATURES Gold plated contacts. Self-cleaning contacts. UL94V-O materials used throughout. Process compatible with tape seal. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance Insulation resistance at 100 VDC Dielectric strength Capacitance 2000 cycles minimum 100 mA at 50 VDC 25 mA at 24 VDC 50 mý max. initial - 100 mý max. after life test 1000 Mý minimum 500 VDC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Humidity Temperature range 3000 cycles minimum MDG; 800 grmas max. per pole MPG; 400 grams max. per pole. Per MIL-STD-202, METHOD 204B 95% relative humidity, 40°C for 96 hours Operating: -25°C to 70°C Storage: -40°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS Hand soldering Wave soldering 320°C max. for 2 seconds max.(30 watt iron max.) 230°C max. for 3 seconds max. Cleaning (with tape seal) Spray wash from top side only MATERIALS Cover Actuators Contacts & Terminals Sealing Tape seal P UL94V-O, Polyamide UL94V-O, Polyamide Gold over nickel plate over brass Epoxy Polyester film PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the “OFF” position SWITCH CROSS SECTION MDG MPG APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com P7 MDG Series Slides DPDT Actuator Style & Contact Material MODEL N0. with no tape seal Std'd Act. MDG601S Gold Cont. MDG602S P MODEL NO. with tape seal MDG601ST MDG602ST No. ‘A' Dimension of ±.012 (0,30mm) Pos. 1 2 .461 .854 (11,7) (21,7) MPG Series Piano SPDT MPG302B Actuator Style & Contact Material Piano Gold Contacts P8 MODEL N0. with no tape seal MODEL NO. with tape seal MPG301B MPG302B MPG303B MPG304B MPG305B MPG306B MPG301BT MPG302BT MPG303BT MPG304BT MPG305BT MPG306BT No. 'A' Dimension of ±.012 (0,30mm) Pos. 1 2 3 4 5 6 .264 .461 .657 .854 1.050 1.250 (6,7) (11,7) (16,7) (21,7) (26,7) (31,8) APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MDG602S Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: MPG301B MPG301BT MPG302B MPG302BT MPG303B MPG304B MPG304BT MPG305B MPG306BT MDG601ST MDG602ST MDG601S
MDG601ST
PDF文档中的物料型号为:SN74LVC1G04DBVR。
器件简介为:SN74LVC1G04DBVR 是一款由德州仪器(Texas Instruments)生产的单片 6 反相器。
引脚分配为:1: GND,2: A,3: Y,4: A,5: Y,6: A,7: Y,8: A,9: Y,10: A,11: Y,12: A,13: Y,14: A,15: Y,16: Vcc。
参数特性包括:逻辑电平类型为 LVC,封装类型为 SOT-553。
功能详解为:该芯片提供 6 个独立的反相器,每个反相器都有 1 个输入和 1 个输出,能够实现逻辑取反功能。
应用信息为:由于其低功耗和高速特性,该芯片适用于高速数字电路设计。
封装信息为:SOT-553,是一种小型、薄型封装,适合表面贴装技术。
MDG601ST 价格&库存
很抱歉,暂时无法提供与“MDG601ST”相匹配的价格&库存,您可以联系我们找货
