NDIR10S
NDIR10S
    APEM(埃斐)
    插件,P=2.54mm
    SWITCH DIP 1/2 PITCH
NDIR10S 数据手册
NDI & DM SERIES SPST STANDARD DIP SWITCHES FEATURES High reliability. Self-cleaning contacts. Multi- positions. Process compatible with tape seal. Dual in-line .100" x .300" term. spacing. GENERAL SPECIFICATIONS SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. ELECTRICALS Electrical life Contact rating, non-switching Contact rating, switching Contact resistance at current 100 mA Insulation resistance at 500 VDC Dielectric strength Capacitance 2000 cycles min. per switch @ 24 VDC, 25 mA 100 mA at 50 VDC 25 mA at 24 VDC 50 milliohms max. initial - 100 milliohms max. after life test 100 Megohms minimum 500 VAC for 1 minute 5 pf. max. between adjacent terminals MECHANICALS, THERMALS Mechanical life Operating force Vibration Shock Operating temperature range 2000 cycles min. per switch 1000 grams max. 10-55 Hz.per MIL-STD-202F METHOD 201A 50 G (peak value) for 11 msec. per MIL-STD-202F, METHOD 213B -20°C to 85°C SOLDERING & CLEANING RECOMMENDATIONS* Hand soldering 350°C max. for 2 seconds max.(30 watt iron max.) Wave soldering 260°C max. for 5 seconds max. Cleaning (with tape seal) Spray wash from top side only. * Note: keep switches in “OFF” position during soldering and cleaning for best results MATERIALS Base & Cover Actuators Contacts Terminals Term. Sealing Tape seal P NDI: UL94V-O, glass fiber filled PBT, black DM: UL94V-O, glass fiber filled PPS, black UL94V-O, Nylon, white Gold over nickel plated copper alloy Gold plated brass. Molded-in Kapton PACKAGING DIP switches are shipped in standard IC tubes with all actuators in the "OFF" position. Tape & reel packaging per EIA available for DMR models (see next page). SWITCH CROSS SECTIONS SCHEMATIC (TYPICAL) Double contact system DI & DM See tabulations on following pages for number of positions available (10 shown) APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com P2 Recessed Spread terminals MODEL NO. with no tape seal MODEL NO. with tape seal MODEL NO. with no tape seal MODEL NO. with tape seal No. 'A' Dim. of +.008/-.000" Pos. (+0.2/-0.0mm) NDI01H NDI02H NDI04H NDI06H NDI08H NDI10H NDIR01H NDIR02H NDIR04H NDIR06H NDIR08H NDIR10H n/a n/a n/a n/a n/a n/a n/a NDIR02HT NDIR04HT NDIR06HT NDIR08HT NDIR10HT NDI01S NDI02S NDI04S NDI06S NDI08S NDI10S NDIR01S NDIR02S NDIR04S NDIR06S NDIR08S NDIR10S n/a n/a n/a n/a n/a n/a n/a NDIR02ST NDIR04ST NDIR06ST NDIR08ST NDIR10ST 1 .137 (3,48) 2 .237 (6,02) 4 .437 (11.10) 6 .637 (16,18) 8 .837 (21,26) 10 1.037 (26,34) 1 .137 (3,48) 2 .237 (6,02) 4 .437 (11,10) 6 .637 (16,18) 8 .837 (21,26) 10 1.037 (26,34) + Auto-insertable using equipment from Amistar, Dynapert, Panasert, Northeastern Tool, Universal and others. n/a = not available. P DM Series Surface Mount + Actuator Style Raised Actuator Recessed Actuator MODEL NO. with no tape seal DM01 DM02 DM03 DM04 DM05 DM06 DM07 DM08 DM09 DM10 DM12 DMR01 DMR02 DMR03 DMR04 DMR05 DMR06 DMR07 DMR08 DMR09 DMR10 DMR12 MODEL NO. with tape seal n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a DMR02T DMR03T DMR04T DMR05T DMR06T DMR07T DMR08T DMR09T DMR10T DMR12T 'A' Dimension No. of +.008/-.000" Pos. (+0.2/-0.0mm) 1 2 3 4 5 6 7 8 9 10 12 1 2 3 4 5 6 7 8 9 10 12 .137 .237 .337 .437 .537 .637 .737 .837 .937 1.037 1.237 .137 .237 .337 .437 .537 .637 .737 .837 .937 1.037 1.237 (3,48) (6,02) (8,56) (11,10) (13,64) (16,18) (18,72) (21,26) (23,80) (26,34) (31.42) (3,48) (6,02) (8,56) (11,10) (13,64) (16,18) (18,72) (21,26) (23,80) (26,34) (31.42) For tape & reel packaging on DMR models only, add 'TR' to model number - example: DMR08TTR. Note- tape & reel packaging is available only with tape seal models. 900 switches per reel. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com P3 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Actuator Squared terminals Raised NDI Series Machine Insertable + Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: NDI01H NDI01S NDI02H NDI02S NDI04H NDI04S NDI06H NDI06S NDI08H NDI08S NDI10H NDI10S NDIR01H NDIR01S NDIR02H NDIR02HT NDIR02S NDIR02ST NDIR04H NDIR04HT NDIR04S NDIR04ST NDIR06H NDIR06HT NDIR06S NDIR06ST NDIR08H NDIR08HT NDIR08S NDIR08ST NDIR10H NDIR10HT NDIR10S NDIR10ST DM01 DM02 DM04 DM05 DM06 DM08 DM09 DM10 DM12 DMR01 DMR02 DMR02T DMR02TTR DMR03T DMR04 DMR04T DMR04TTR DMR05T DMR06T DMR06TTR DMR07T DMR08 DMR08T DMR08TTR DMR09T DMR09TTR DMR10 DMR10T DMR12T DMR12TTR DMR05TTR DMR03TTR
NDIR10S 价格&库存
很抱歉,暂时无法提供与“NDIR10S”相匹配的价格&库存,您可以联系我们找货
