S-7071EWC
S-7071EWC
    COPAL(日电产 科宝电子)
    插件
    SWITCH ROTARY DIP 16POS
S-7071EWC 数据手册
      ROTARY CODED SWITCHES (SMD) RoHS compliant S-7000 INTERNAL STRUCTURE ① ③ ② ⑦ ⑧ Part name ■ FEATURES ● RoHS compliant ● Low profile of 2.9 mm ● Wide variety (top or side setting, 6, 10 or 16 positions, J-hook, gull wing or throuhg hole pins) to choose from ● Washable ● Resin materials are UL Recognized 94V-0 or 94V-1 equivalent ① Cover ② “O” ring ③ Rotor ④ Spacer ⑤ Slider contact ⑥ Fixed contact ⑦ Housing ⑧ Terminal pin ④ ⑤ ⑥ Material Stainless steel (SUS 304) Silicone rubber Polyphenylenesulphide Stainless steel (SUS 304) Copper alloy, Gold-plated Epoxy Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION S - 7 0 1 0 E T A Series name Shape of rotor 0:Without knob Code format 1:10 positions, real code 3:10 positions, complementary code 6: 6 positions, real code 5:16 positions, real code 7:16 positions, complementary code Setting position 0:Top setting 1:Side setting (Except for 6 positions type) ※ Please refer to the LIST OF PART NUMBERS when placing orders. Shape of terminal A:J-hook B:Gull wing C:Through hole pins (Except for 6 positions type) Form of packaging T:Taping (Reel) W:Tray packaging (Through hole pins only) Blank: Bulk in plastic bag Terminal pin E:Au (Lead-free) S-7000 ROTARY CODED SWITCHES (SMD) ■ CODE FORMAT 16 positions Position 0 Real code Code 8 4 2 1 8 4 2 1 1 ● ● ● ● ● ● ● ● 10 positions 6 positions 3 4 5 2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 6 7 ● ● ● ● ● ● ● ● 8 ● 9 ● ● ● ● ● ● ● A ● B ● ● ● ● ● ● ● C ● ● D ● ● ● ● ● ● E ● ● ● F ● ● ● ● ● ● …Contact closed ■ LIST OF PART NUMBERS Setting position Shape of terminal A J-hook Top setting B Gull wing C Through hole pin A J-hook Side setting B Gull wing C Through hole pin Form of packaging Binary coded hexal Real code Binary coded decimal Real code Real code Complementary code Pieces in package Taping S-7060ETA S-7010ETA S-7030ETA S-7050ETA Real code 500 pcs. / reel Plastic bag S-7060EA S-7010EA S-7030EA S-7050EA S-7070EA 50 pcs. / pack Taping S-7060ETB S-7010ETB S-7030ETB S-7050ETB S-7070ETB 500 pcs. / reel Plastic bag S-7060EB S-7010EB S-7030EB S-7050EB S-7070EB 50 pcs. / pack S-7010EWC S-7030EWC S-7050EWC S-7070EWC 50 pcs. / tray S-7010EC S-7030EC S-7050EC S-7070EC Tray packaging Plastic bag 50 pcs. / pack Taping S-7011ETA S-7031ETA S-7051ETA S-7071ETA 500 pcs. / reel Plastic bag S-7011EA S-7031EA S-7051EA S-7071EA 50 pcs. / pack Taping S-7011ETB S-7031ETB S-7051ETB S-7071ETB 500 pcs. / reel Plastic bag S-7011EB S-7031EB S-7051EB S-7071EB 50 pcs. / pack S-7011EWC S-7031EWC S-7051EWC S-7071EWC 50 pcs. / tray S-7011EC S-7031EC S-7051EC S-7071EC 50 pcs. / pack Tray packaging Plastic bag   : Not manufactured ※ Verify the above part numbers when placing orders. Taping and tray version can be supplied only in reel or tray unit. The products indicated by receipt of order basis. Complementary code Binary coded hexadecimal mark are manufactured upon S-7000 ROTARY CODED SWITCHES (SMD) ■ STANDARD SPECIFICATIONS Circuit type Operating temp. range ■ ELECTRICAL CHARACTERISTICS BCD (Real code, complementary code) BCH (Real code, complementary code) Contact rating Non-switching Switching Minimum −40 ~ 85 °C Storage temp. range Sealing Contact resistance Insulation resistance Washable by “O” ring ※ Please refer to page 150,151 Dielectric strength Net weight Adjustment torque 6, 10, 16 Vibration 20 mN·m {204 gf·cm} maximum Shock 60° (6 positions) 36° (10 positions) 22.5° (16 positions) Load life Solderability 245 ± 3 °C, 2 ~ 3 s Humidity (Steady state) Reflow:255 °C (Peak temperature) Please refer to the profile below) Flow : 260 ± 3 °C, 5 ~ 6 s, two times maximum Manual soldering : 350 ± 10 °C, 3 ~ 4 s AC250 V, 60 s 5 N {0.51 kgf} 10 s Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Temperature 150 100 50 Peak : 250 0 ℃ +5 Over 230℃ 150℃ 10000 steps minimum, DC5 V, 100 mA 40 °C, Relative humidity 90 ~ 95 %, 240 h −40 °C, 96 h 〈Reflow profile for soldering heat evaluation〉 180℃ 490 m/s2, 11 ms 6 directions for 3 times each Low temp. exposure { } : Reference only 200 10-500-10 Hz, 3 directions for 2 h each 85 °C, 96 h 5 N {0.51 kgf} 10 s (℃) 250 (Amplitude)1.5 mmor (Acceleration)98 m/s2, High temp. exposure Thermal shock Shear (adhesion) Pull-off strength 100 MΩ (DC100 V) minimum ■ ENVIRONMENTAL CHARACTERISTICS Stepping angle Soldering heat 100 mΩ maximum Approx. 0.26 g (A or B type in top setting) Approx. 0.28 g (C type in top setting) Approx. 0.62 g (Side setting type) ■ MECHANICAL CHARACTERISTICS No. of positions DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μA Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Soldering Zone Reflow : two times maximum −40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles S-7000 ROTARY CODED SWITCHES (SMD) S-7050A/7070A 外形図 ■ OUTLINE DIMESIONS 0A 外形図 Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● S-7010EA (Real code) ● S-7030EA (Complementary code) ● S-7050EA (Real code) ● S-7070EA (Complementary code) Production date code Production date code F012 4 4 2.9 8 Lead-free ldentification mark 2 1 A 4 4±1 2.54 2.54 8 7.2 C 1.2 A Projection 0.5 2.8 4.7 A 4±1 2.54 0.6 W × 2.6 L × 0.6 D 5 6 0.6 W × 2.6 L × 0.6 D Lead-free ldentification mark 6 – 0.5 t = 0.15 C Lead-free ldentification mark 1.2 2.8 Marking appears only with complementary code F012 A 7.2 7.62 7 8 4 7.2 Production date code 789 0.5 2.54 Marking appears only with complementary code 3456 C 2.54 ● S-7050EC (Real code) ● S-7070EC (Complementary code) 0 1 8 7.2 2.9 Lead-free ldentification mark 6 – 0.5 t = 0.15 2 3 4 C S-7050C/7070C 外形図 B CDE 5 6 9 8 7.2 Marking appears only with complementary code C 0.6 W × 2.6 L × 0.6 D 6 – 0.8 t = 0.15 7.62 0.6 min. 2.54 C F012 4 2.54 Marking appears only with complementary code Production date code 1 1 A 9.8 7.2 7 8 4 2.9 ● S-7010EC (Real code) ● S-7030EC (Complementary code) 2 2 789 C Lead-free ldentification mark Marking appears only with complementary code 3456 8 7.2 2.54 0.6 min. 6 – 0.8 t = 0.15 B CDE 0.6 min. 0.6 W × 2.6 L × 0.6 D 0 1 030C 外形図 4 2.54 Production date code 2 3 7.2 9 2.9 ● S-7050EB (Real code) ● S-7070EB (Complementary code) Production date code C 7.5 S-7050B/7070B 外形図 Marking appears only with complementary code ● S-7010EB (Real code) ● S-7030EB (Complementary code) 1 C 7.2 2.54 9.8 30B 外形図 2.54 0.6 min. 5 6 C Lead-free ldentification mark 2 C 789 8 1 A 7.5 7.2 7 8 0 1 7.2 6 – 0.8 t = 0.15 0.6 W × 2.6 L × 0.6 D 2 3456 4 6 – 0.8 t = 0.15 0.6 W × 2.6 L × 0.6 D 2 3 7.2 9 C B CDE 1 4.7 2 A Projection 2.54 S-7000 ROTARY CODED SWITCHES (SMD) S-7051A/7071A 外形図 -7011A/7031A 外形図 ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● S-7011EA (Real code) ● S-7031EA (Complementary code) Marking appears only with complementary code Marking appears only with complementary code Production date code Lead-free ldentification mark 7.8 2 8.3 9 F01 C 8 1 min. 4 S-7051B/7071B 外形図 C 8 4 7.2 3456 2 8.3 789A 9 F01 0 1 1 1.4 min. C 2 2.54 8 4 S-7051C/7071C 外形図 C ● S-7011EC (Real code) ● S-7031EC (Complementary code) 4 ● S-7051EC (Real code) ● S-7071EC (Complementary code) Marking appears only with complementary code Production date code Marking appears only with complementary code Production date code 8 Lead-free ldentification mark Lead-free ldentification mark 7.2 7.2 7.8 3456 789A 2 8.3 7.8 9 F01 0 1 3.5 3.5 B CDE 2 3 5 6 7 8 8.3 4 1.4 min. C 7.8 7.8 0.4 1.4 min. 0.6 W × 2.6 L × 0.6 D 6 – 0.8 t = 0.15 2.54 1.4 min. 031C 外形図 2 2.54 7.8 B CDE 2 3 5 6 7 8 8.3 7.8 1 6 – 0.8 t = 0.15 2.54 Lead-free ldentification mark 0.6 W × 2.6 L × 0.6 D C 2.54 Marking appears only with complementary code Production date code Lead-free ldentification mark 4 6 – 0.8 t = 0.15 2.54 ● S-7051EB (Real code) ● S-7071EB (Complementary code) Marking appears only with complementary code 7.2 0.8 2 2.54 ● S-7011EB (Real code) ● S-7031EB (Complementary code) Production date code 1 1 min. C 7.1 7.1 B 外形図 6 – 0.8 t = 0.15 2.54 0.8 1 min. 2 1 min. 0 1 1 789A 0.6 W × 2.6 L × 0.6 D 0.6 W × 2.6 L × 0.6 D C 7.8 B CDE 2 3 5 6 7 8 8.3 7.2 3456 7.2 4 Lead-free ldentification mark 0.4 Production date code ● S-7051EA (Real code) ● S-7071EA (Complementary code) 0.6 W × 2.6 L × 0.6 D 0.6 W × 2.6 L × 0.6 D C C 1 8 2 4 1.8 5.08 6 – 0.5 t = 0.15 2.54 C 1 2 C 8 4 2.54 1.8 5.08 6 – 0.5 t = 0.15 2.54 2.54 S-7000 ROTARY CODED SWITCHES (SMD) ■ OUTLINE DIMESIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) ● S-7060EA (Real code) ● S-7060EB (Real code) Production date code C 1 2 1 6 – 0.8 t = 0.15 9.8 6 7.2 4.7 7.5 7.2 5 4 5 3 3 4 NO 2 6 C 1 2 4 1 0.6 min. 6 – 0.8 t = 0.15 C 7.2 2.9 Lead-free ldentification mark 2.54 2.54 4 NO C 7.2 2.9 0.6 min. 2 Production date code 2.54 2.54 0.6 W × 2.6 L × 0.6 D Lead-free ldentification mark 0.6 W × 2.6 L × 0.6 D ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● A type (Unit: mm) 3 3.5 ● B type 6 0 3 3.5 3 0 6 – 1.6 2.54 2.54 ● A type 6 – 1.6 2.54 1.9 2.3 ● B type 4.3 0 2.3 1.9 4.3 0 6 – 1.2 2.54 2.54 ■ SIZE OF P.C.B. PROCESSING 6 –φ0.8 6 – 1.2 2.54 2.54 ● C type Operating face ▼ 6 –φ0.8 2.54 2.54 5.08 7.62 ● C type 2.54 2.54 2.54 S-7000 ROTARY CODED SWITCHES (SMD) S-7000 リール ■ PACKAGING SPECIFICATIONS ● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500, pcs., etc. ● Taping version is boxed with one reel (500 pcs.). Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) Filled Empty 17.4±1 Head End 40 mm min. Direction of feed φ21±0.8 2±0.5 20 pitches min. 400 mm min. φ13±0.2 φ254±2 (Top setting type) φ330±2 (Side setting type) φ50 min. (Top setting type) φ80±1 (Side setting type) Empty 21.4±1 S-7000 ROTARY CODED SWITCHES (SMD) (Conforms to JIS C 0806-3) ● S-70 □□ ETA 3 4 5 ● S-70 □□ ETB < Top setting > 0.3±0.1 2±0.1 12±0.1 4±0.1 φ1.5 0 +0.1 7.5±0.1 16 +0.1 0 1.75±0.1 φ1.5 16 3 4 5 BCD 7.5±0.1 12±0.1 4±0.1 F0 12 6 A 8.7 0.3±0.1 Direction of feed Direction of feed E +0.1 1.75±0.1 7 8 9 3.4 2±0.1 φ1.5 0 1.75±0.1 12±0.1 2±0.1 4±0.1 6 A 0.3±0.1 7.5±0.1 16 +0.1 0 16 φ1.5 F0 12 BCD E 12±0.1 4±0.1 7.5±0.1 2±0.1 1.75±0.1 (Unit: mm) 7 8 9 3.4 Direction of feed ● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag (top setting type) is performed with 5pcs. (standard 200 pcs.) per box. Only that side setting type is 100 pcs. (standard 200 pcs.) per box. Direction of feed 8.7 0.3±0.1
S-7071EWC 价格&库存
很抱歉,暂时无法提供与“S-7071EWC”相匹配的价格&库存,您可以联系我们找货
