IKN0203000
IKN0203000
    APEM(埃斐)
    插件
    拨码开关 插件 SPST 24VDC 100mA
IKN0203000 数据手册
PANEL PCB SWITCHES N -IK 2 80 -1 IKN series SW Surface mount and through-hole • low profile • dual in line switches DISTINCTIVE FEATURES Low profile Wide operating temperature range Self-cleaning wiping contacts Tin plated terminals ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -40 °C to +100 °C (-40 °F to 212 °F) • Storage temperature : -40 °C to +125 °C (-40 °F to 257 °F) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating : - switching : 100 mA 24 VDC - non-switching : 100 mA 48 VDC • Contact resistance : - initial : 30 mΩ max. - after 2,000 cycles : 100 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 500 VAC min. • Electrical life : 2,000 cycles • Travel : 0.67 mm (.026) MATERIALS • Case and actuator : UL 94-V0 thermoplastic • Stationary contact : bronze, gold plated over nickel barrier • Moving contact : beryllium copper, gold plated • Terminals : tin plated over nickel barrier • Protection tape : polyimide The company reserves the right to change specifications without notice. 1 Surface mount and through-hole • low profile • dual in line switches 7.30 (.287) 1.55 (.061) A 0.60 (.023) IC TUBE APEM 2.85 (.112) 1 4 ON 1.50 (.059) 3 APEM 5 6 7 8 7.30 (.287) 8.00 (.314) Coplanarity MAX 0.102 (.004) 2.54 (.100) 10.00 Maxi (.394 MAX) 1 SURFACE MOUNT 4 3 1.27 (.050) APEM ON Number of ways Qty per tube 2 88 pcs 4 48 pcs 6 33 pcs 8 25 pcs TAPE AND REEL Unrolling direction 1 ON 3 4 APEM L 2 12.00 (.472) Ø100.00 mini (3.937 DIA MIN) Ø13.00 0.25 (.511 DIA .009) Number of ways 2 4 3.00 (.118) A Tape dim. “L” Reel dim. “A” 16 (.629) 16.40 (.646) CIKNR 24 (.944) 6 24 (.944) 8 32 (1.259) 24.40 (.960) FICHIER: CIKNR 24.40 (.960) Page F11 ECHELLE: 0.8 32.40 (1.275) Indice le 06/02/02 Standard packaging unit : 1,000 pieces 2 2.54 (.100) 1.77 (.069) 0.60 (.023) 1.00 (.039) 1 2 3 4 5 6 7 8 1 ON 2 APEM 1.00 (.039) 7.62 (.300) ON 2 458.00 (18.031) 10.00 (.393) 4 1.00 (.039) 3 0.30 (.011) 4 3 APEM 2 2 11.60 (.456) Ø0.80 (.031 DIA) A 1 10.00 Maxi (.393 MAX) THROUGH-HOLE 1.00 (.039) ON PCB LAYOUT 7.62 (.300) 7.62 (.300) 2.54 (.100) 3.40 (.133) 4.00 (.157) PACKAGING Ø360.00 Maxi (14.173 DIA MAX) PCB SWITCHES IKN series 2.54 (.100) Surface mount and through-hole • low profile • dual in line switches BUILD YOUR PART NUMBER IKN SERIES MODEL TYPE NUMBER OF WAYS TAPE SEAL 02 Two way 000 Through-hole IC tubes 04 Four way 030 SMT IC tubes 06 Six way 040 SMT tape and reel 08 Eight way 00 Top tape seal Other models (3, 5 and 7 ways) : on request TAPE THROUGH-HOLE 7.30 (.287) 4 11.10 (.437) 6 16.20 (.637) 8 21.30 (.838) 2.54 (.100) 7.62 (.300) 0.60 (.023) 10.00 Maxi (.393 MAX) 1.00 (.039) APEM ON 1 Ø0.80 (.031 DIA) 2 3 4 5 1.50 (.059) 6 7 8 7.62 (.300) 6 (.236) 3.40 (.133) Dimension “A” 2 1.00 (.039) Number of Poles 4.00 (.157) 1.55 (.061) A 2.54 (.100) Supplied with all poles in “ON” position. TAPE 7.30 (.287) 6 (.236) 4 11.10 (.437) 6 16.20 (.637) 8 21.30 (.838) 10.00 Maxi (.394 MAX) 1.00 (.039) 1.27 (.050) APEM ON 1 2 3 4 5 6 7 8 Supplied with all poles in “ON” position. 8.00 (.314) 0.60 (.023) 7.62 (.300) 2 0.30 (.011) Dimension “A” Coplanarity MAX 0.102 (.004) 1.00 (.039) Number of Poles 2.85 (.112) A 2.54 (.100) 1.77 (.069) SURFACE MOUNT 2.54 (.100) 3 PANEL PCB SWITCHES IKN series Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: IKN0804000 IKN0803000 IKN0200000 IKN0203000 IKN0204000 IKN0400000 IKN0403000 IKN0404000 IKN0600000 IKN0603000 IKN0604000 IKN0800000
IKN0203000 价格&库存
很抱歉,暂时无法提供与“IKN0203000”相匹配的价格&库存,您可以联系我们找货
