SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE.
P60A & P60AS SERIES
ROTARY DIP SWITCHES
FEATURES
New 4 + 1 terminal layout.
Completely sealed for process compatibility.
Ultra-compact size with 10 or 16 positions.
Precision designed detent action.
Thru-hole (P60A Series) & SMT (P60AS Series) models.
High reliability & long life.
Clockwise or counterclockwise settable.
Solder coated terminals.
GENERAL SPECIFICATIONS
ELECTRICALS
Operating voltage
Contact rating, static
Contact rating, dynamic
Test voltage
Initial contact resistance
Insulation resistance
24 VDC max.
400 mA max.
150 mA max.
250V 50Hz/1 min.
< 100 milliohms
> 100 megohms
MATERIALS
Base
MECHANICALS, THERMALS
Torque
Expected life
Contact force
Operating temperature range
0.98 inch-oz. min. (0.7 Ncm min.)
10,000 switching operations
15 grams min.
-20°C to 85°C
SOLDERING RECOMMENDATIONS
Hand soldering
Wave soldering
Reflow soldering (SMT)
Solvent washing
Aqueous cleaning
340°C max. for 2 seconds max.
(40 watt iron max.)
260°C max. for 10 seconds max.
215°C max. for 40 seconds max.
Freons or alcohol. (Do not use
chlorinated solvents)
Deionized water preferred
Thru-hole and SMT
Printed Circuit Models
Cover
Actuator
Contacts
Terminals
Terminal sealing
Actuator seal
UL94V-O,
high temperature thermoplastic
UL94V-O,
Nylon
Gold over nickel plated
stainless steel
Solder coated copper
Molded-in
'O'-ring
P
Model No. Model No.
Thru-hole
Surface
Mounting
Mounting
Code (see truth tables pg. G22) Positions
(see fig. 1)
(see fig. 2)
Binary Coded Decimal
10
P60A701
P60AS701
Complement of BCD
10
P60A702
P60AS702
Binary Coded Hexadecimal
16
P60A703
P60AS703
Complement of BCH
16
P60A706
P60AS706
Figure 1
Figure 2
Mechanical outline
P.C. hole pattern
Mechanical outline
P.C. pad layout
P16 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com
STANDARD OPTIONS BY SERIES:
P60A
X
X
X
P60A & P60AS SERIES
P60AS
X*
X*
X
ACTUATORS
3 Spindle
Codes
01 BCD
02 BCD complement
03 Hexadecimal
06 Hexadecimal Comp.
X
X
X
X
Terminals
None
Straight
V
Crimped
L508
Rt. angle 5.08 (.200")
None
SMT
X
X
X
X
X
X
X
5 Segment
wheel
7 Cross
shaped slot
X
* - Please contact factory
ORDER GUIDE:
Make selections from the above table in sequence
to specify a complete model number.
Note that 'None' indicates that no option suffix is
required.
See page G19 for optional Operating Elements.
P60A301V
Series
Actuator
Example;
Terminals
Code
CODES
P
NOTE: For each dial position in tables, Common terminals (C) are connected to terminal number(s)
indicated - i.e. - none or combinations of 1, 2, 4 or 8.
Each model in this series has 2 Common terminals.
BINARY CODED
DECIMAL (01)
10 Positions
Dial No. 1 2 4
2
3
4
5
6
7
8
9
8
BINARY CODED
HEXADECIMAL (03)
16 Positions
Dial No. 1 2 4 8
2
3
4
5
6
7
8
9
A
B
C
D
E
F
MECHANICAL OUTLINES
Terminal option suffix*:
COMP. OF BINARY
CODED DECIMAL (02)
10 Positions
Dial No. 1 2 4 8
2
3
4
5
6
7
8
9
NONE
Straight
terminals
COMP. OF BINARY
CODED HEXADEC. (06)
16 Positions
Dial No. 1 2 4 8
2
3
4
5
6
7
8
9
A
B
C
D
E
F
L508
Right angle
terminals
Mtg. hole pattern:
V
Crimped
terminals
NONE
SMT
terminals
* 'None' indicates no option suffix is required.
APEM 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com P17
Series
Actuators
3 Spindle
5 Segment wheel
7 Cross shaped slot
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
P60A701 P60A703 P60AS701 P60AS703 P60A703L508
很抱歉,暂时无法提供与“P60A703L508”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+70.3322350+9.09935
