P60A503
P60A503
    APEM(埃斐)
    DIP
    P60A503
P60A503 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. P60A & P60AS SERIES ROTARY DIP SWITCHES FEATURES New 4 + 1 terminal layout. Completely sealed for process compatibility. Ultra-compact size with 10 or 16 positions. Precision designed detent action. Thru-hole (P60A Series) & SMT (P60AS Series) models. High reliability & long life. Clockwise or counterclockwise settable. Solder coated terminals. GENERAL SPECIFICATIONS ELECTRICALS Operating voltage Contact rating, static Contact rating, dynamic Test voltage Initial contact resistance Insulation resistance 24 VDC max. 400 mA max. 150 mA max. 250V 50Hz/1 min. < 100 milliohms > 100 megohms MATERIALS Base MECHANICALS, THERMALS Torque Expected life Contact force Operating temperature range 0.98 inch-oz. min. (0.7 Ncm min.) 10,000 switching operations 15 grams min. -20°C to 85°C SOLDERING RECOMMENDATIONS Hand soldering Wave soldering Reflow soldering (SMT) Solvent washing Aqueous cleaning 340°C max. for 2 seconds max. (40 watt iron max.) 260°C max. for 10 seconds max. 215°C max. for 40 seconds max. Freons or alcohol. (Do not use chlorinated solvents) Deionized water preferred Thru-hole and SMT Printed Circuit Models Cover Actuator Contacts Terminals Terminal sealing Actuator seal UL94V-O, high temperature thermoplastic UL94V-O, high temperature thermoplastic Nylon Gold over nickel plated stainless steel Solder coated copper Molded-in 'O'-ring P Model No. Model No. Thru-hole Surface Mounting Mounting Code (see truth tables pg. G22) Positions (see fig. 1) (see fig. 2) Binary Coded Decimal 10 P60A701 P60AS701 Complement of BCD 10 P60A702 P60AS702 Binary Coded Hexadecimal 16 P60A703 P60AS703 Complement of BCH 16 P60A706 P60AS706 Figure 1 Figure 2 Mechanical outline P.C. hole pattern Mechanical outline P.C. pad layout P16 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com STANDARD OPTIONS BY SERIES: P60A X X X P60A & P60AS SERIES P60AS X* X* X ACTUATORS 3 Spindle Codes 01 BCD 02 BCD complement 03 Hexadecimal 06 Hexadecimal Comp. X X X X Terminals None Straight V Crimped L508 Rt. angle 5.08 (.200") None SMT X X X X X X X 5 Segment wheel 7 Cross shaped slot X * - Please contact factory ORDER GUIDE: Make selections from the above table in sequence to specify a complete model number. Note that 'None' indicates that no option suffix is required. See page G19 for optional Operating Elements. P60A301V Series Actuator Example; Terminals Code CODES P NOTE: For each dial position in tables, Common terminals (C) are connected to terminal number(s) indicated - i.e. - none or combinations of 1, 2, 4 or 8. Each model in this series has 2 Common terminals. BINARY CODED DECIMAL (01) 10 Positions Dial No. 1 2 4 0 1 2 3 4 5 6 7 8 9 8 BINARY CODED HEXADECIMAL (03) 16 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 A B C D E F MECHANICAL OUTLINES Terminal option suffix*: COMP. OF BINARY CODED DECIMAL (02) 10 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 NONE Straight terminals COMP. OF BINARY CODED HEXADEC. (06) 16 Positions Dial No. 1 2 4 8 0 1 2 3 4 5 6 7 8 9 A B C D E F L508 Right angle terminals Mtg. hole pattern: V Crimped terminals NONE SMT terminals * 'None' indicates no option suffix is required. APEM 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com P17 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Series Actuators 3 Spindle 5 Segment wheel 7 Cross shaped slot Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: P60A301L508 P60A503 P60A701 P60A703 P60AS701 P60AS701TR P60AS703 P60A703L508 P60A501
P60A503 价格&库存
很抱歉,暂时无法提供与“P60A503”相匹配的价格&库存,您可以联系我们找货
P60A503
  • 25+40.40813
  • 50+37.38538
  • 100+30.00987
  • 500+27.26521
  • 1000+25.04047
  • 2500+23.79510
  • 5000+23.34773
  • 10000+22.91245
库存:43
