35-964
35-964
    GCELECTRONICS
    插件,P=2.54mm
    开关 DIP 4位 顶部操作
35-964 数据手册
SWITCHES ROTARY SWITCHES 35-12 0 SP Fig. 7 Retail Part No. 35-859 35-855 35-856 35-1857 Bulk Part No. 35-859-BU 35-855-BU 35-856-BU 35-1857-BU Retail Part No. 35-375 35-376 35-378 35-379 35-1212 35-1226 35-1306 35-1312 35-1314 35-1324 35-1334 35-1343 35-1323 Bulk Part No. 35-375-BU 35-376-BU 35-378-BU 35-379-BU Fig. 3 Fig. 2 Fig. 1 Fig. No. 1 2 3 4 Fig. No. 5 5 5 5 6 6 7 7 7 7 7 7 7 Amps Poles/ Throws 125 VAC SPST 3 SPST 6 SPST 6 SP3T 6 Amps 250 VAC 1.5 3 3 3 Amps Amps Amps (Cont.) 125 VAC 125 VDC 0.3† 0.3† 0.3† 6 6 5 5 5 5 5 5 5 250mA* 250mA* 2.5 2.5 2.5 2.5 2.5 2.5 2.5 350mA 350mA 350mA 350mA 350mA 350mA Action On/Off On/Off On/Off Off/On/On/On Positions 6 12 3 4 12 No Stop 6 6 12 No Stop 12 4 4 3 8 Actuator White Plastic Brass Knob Black Plastic Brass Knob Poles Index 2 1 3 3 1 2 1 1 1 2 3 4 1 30º 30º 30º 30º 30º 30º 30º 30º 30º 30º 30º 30º 45º Terminal Type 6” Wire Leads 6” Wire Leads 6” Wire Leads 6” Wire Leads Actuator 1/4” Metal 1/4” Metal 1/4” Metal 1/4” Metal 1/2” Metal 1/2” Metal 1/4” Plastic 1/4” Plastic 1/4” Plastic 1/4” Plastic 1/4” Plastic 1/4” Plastic 1/4” Plastic FN=Face Nut KN=Knurled Nut LR=Locking Ring N=Nut Notes: *Or 28VDC Adj.=Adjustable Stop †=Or 30V DC Non-Shorting=break before make Fig. 5 Fig. 4 Terminal Type Sd Eyelet Sd Eyelet Sd Eyelet Sd Eyelet Sd Eyelet Sd Eyelet Sd Lug Sd Lug Sd Lug Sd Lug Sd Lug Sd Lug Sd Lug Fig. 6 Mounting Style Snap-In Threaded Bushing Threaded Bushing Threaded Bushing Mounting Hole (In) Hardware 0.500 KN, FN 0.375 N, FN 0.375 N, FN 0.375 Mounting Mounting Style Hole (In) Shorting 0.375 Shorting 0.375 Non-Shorting 0.375 Shorting 0.375 Non-Shorting 0.250 Non-Shorting 0.250 Non-Shorting 0.386 Non-Shorting 0.386 Non-Shorting 0.386 Non-Shorting 0.386 Non-Shorting 0.386 Non-Shorting 0.386 Non-Shorting 0.386 Hardware N, LR N, LR N, LR N, LR N, LR, W N, LR, W N, LR N, LR N, LR, StR N, LR N, LR N, LR N, LR, StR Spec Drawing Page No. 301-A 301-B 301-C 301-D Spec Drawing Page No. 301-E 301-E 301-E 301-E 301-F 301-F 301-G 301-G 301-G 301-G 301-G 301-G 301-G Sd=Solder StR=Stop Ring W=Washer Switches SLIDE SWITCHES Fig. 10 Fig. 8 Retail Part No. 35-202 35-210 35-222 35-242 Bulk Part No. 35-202-BU 35-210-BU 35-222-BU 35-242-BU Fig. No. 8 10 11 12 Circuit Funct. On/On On/On On/On On/On Amps Poles & Amps Amps Amps Throws 125 VAC 250 VAC 30 VAC 125 VDC SPDT 0.30 1/2 SPDT 6 DPDT 3 6 11 DPDT Fig. 12 Fig. 11 Actuator Style Terminal Type Mounting Style Black Plastic Black Plastic Black Plastic Black Plastic Solder Lug Printed Circuit Board Lug Printed Circuit Board Lug Solder Lug Surface Surface Surface Surface Spec Drawing Page No. 301-H 301-J 301-K 301-L DIP SWITCHES Retail Bulk Part No. Part No. 35-953 35-957 35-961-BU 35-961 35-962 35-963 35-964-BU 35-964 35-965 35-966-BU 35-966 35-967 35-968-BU 35-968 35-969 35-970-BU 35-970 35-974 35-971 300 Fig. No. 13 13 14 14 14 14 14 14 14 14 14 14 14 15 Number of Positions 4 8 1 2 3 4 5 6 7 8 9 10 12 8 Spec Drawing Page No. Side Actuated 301-M Side Actuated 301-M Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Standard 301-N Right Angle 301-N Profile Fig. 13 Rating: 100mA@50Vdc (carry) 100mA@5Vdc 25mA@25Vdc Fig. 15 Fig. 14 Note: All figures are for illustration purpose only, and the number/type of terminals may vary. Phone (815)316-9080•Fax (815)316-9081 All quantities are single; BU’s are packages of 10 Unless otherwise noted. SWITCHES ROTARY, SLIDE & DIP SWITCHES (Cont.) A B C D E F H I J K L G Switches M N For the latest information–www.gcelectronics.com All quantities are single; BU’s are packages of 10 Unless otherwise noted. 301
35-964 价格&库存
很抱歉,暂时无法提供与“35-964”相匹配的价格&库存,您可以联系我们找货
