AS2AF2
AS2AF2
    SENSATA(森萨塔)
    SWITCH UNIT PB 22MM BLK METAL
AS2AF2 数据手册
Control Switches and Signaling Devices 22.5 mm Metal Series Control Switches and Signaling Devices, 22.5mm Metal Series 292 Non-Illuminated Operators, 22.5mm Metal Series 294 Illuminated Operators, 22.5mm Metal Series 296 Pilot Lights and Lens Assemblies, 22.5mm Metal Series 297 Control Switches and Signaling Devices, 22.5mm Metal Series 298 Airpax Corporation 807 Woods Road Cambridge, Maryland 21613 USA Tel: 410-228-1500 Fax: 410-228-3456 infoppp@airpax.net Control Switches and Signaling Devices, 22.5mm Metal Series This range of 22.5mm metal series pushbuttons, selector switches, illuminated switches and pilot lights have been designed to provide the following features: • Economy of space • Self wiping contacts • RoHS compliant • Simple to mount (only need a screw driver) • Mounting method is unaffected by excessive vibration • Electric shock protection (grounded unit) • Aesthetically pleasing • Heavy-duty construction • Shrouded terminals • Very good flame resistance • Use of LEDs for long life Actuators The circular actuators have chrome plated metal bezels and are functionally interchangeable on the different contact elements. 40X30 Contact elements The contact elements are double break and have self-wiping contacts. The elements are interchangeable and can be stacked without additional hardware. 1 to 6 elements (NO or NC) can be used for non-illuminated actuators, whereas, 1 to 4 elements (NO or NC) can be used for illuminated actuators. Gold NO or NC contact elements for low voltage, low current, < 25mA, switching applications are available. 43 24 24 Illuminated pushbuttons and pilot lights Pilot lights and pushbutton switches are suitable for direct connection through a series resistor, series resistor and diode, using bayonet cap filament bulb type BA9s as follows: Supply voltage for direct connection without series resistor . . . . 6V - 130V Supply voltage through series resistor . . . . . . . . . . . . . . . . . . . . 12V - 415V Supply voltage through resistor and diode . . . . . . . . . . . . . . . . . 230 VAC Bulb . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Filament, type BA9S with OAL max. 28mm Terminals Contact elements and pilot lights are designed to have shrouded terminals with combination screws. Mounting The metal series control devices 22.5mm can be mounted in any position on panels of 1 to 6 mm thickness. We recommend minmum mounting centers of 30mm x 40mm. However, the dimensions and configuration should be decided on the basis of the application. The actuators and the lens assemblies lock on the holding bracket. See assembly details. Electrical and mechanical characteristics Environment Standards conformity: CSA - C22.2 No. 14-95, UL508, EN60947-5-1 2000 Approvals: CSA - C22.2 No. 14-95, UL508, VDE0660 Degree of protection: IP 65 as per IEC529, NEMA 4X, 12 as per UL50 Ambient temperature: -25°C to +70°C Operating position: All positions Contact element block Element screw torque: Connection screw torque: Rated insulationvoltage: Rated thermal current: Contact operation: Make and break capacity as per IEC 947-5-(1) 1990: as per CSA - C22.2 No. 14-95, UL508 Ø 22.5 DIN Mounting details 40 Control Switches and Signaling Devices Pilot lights and illuminated actuators are available with integral LEDs, suitable for operating at various voltages; 6V, 12V, 24V, 30V, 48V, 63.3V, 110V, 125V, 230VAC or DC and 415VAC. Pilot lights and illuminated actuators are available with LED bulbs (bayonet cap, BA9s design with OAL max. 28mm) suitable for operating at various voltages; 24V, 48V, 110V and 230V. On request an extra short circuit protection consisting of built-in fuse in the LED modules can be provided. Pilot lights are available with built -in transformers suitable for operating at 110VAC, 230VAC input and 6V, 12V and 24V output. Mounting bracket screws torque 8 - 10 in/lbs 30 3 - 4 in/lbs 5 - 7 in/lbs 500V 10A Self wiping, slow break NO or NC AC 15 - 4A, 415VAC DC 13 - 0.5A, 110VDC A 600 Q 600 Terminal capacity: Minimum 1 X 0.5mm2 (20AWG), maximum 2 x 15mm2 (2x16AWG), or 1 x 2.5mm2 (1x14AWG) Terminals marking: 1-2 for NC, 3-4 for NO Short circuit protection: 10A cartridge fuse, HRC type, rated for resistive loading Mechanical life: Over one million operations Electrical rating: (one million operating cycles at 3600 cycles per hour, load factor 0.5) V 24 120 230 V 24 110 AC15 DC13 A 4 3 2 A 0.5 0.2 Modules for pilot lights and illuminated switches with integral LED / LED bulb (BA9S cap) Current consumption (applicatable to all colors) 24VAC/DC, 110VAC and 240VAC: max. 20mA 110VDC: max. 15mA 220VDC: max. 10mA Service life(at nominial voltage and at ambient temperature): 100,000 hours Voltage limits (nominal voltage): ±20% of rated voltage Short circuit protection: on specific request 292 Terminal capacity: min. 1 X 0.5mm2 (20AWG) max. 2 x 1.5mm2 (2x16AWG) or 1 x 2.5mm2 (1x14AWG) Control Switches and Signaling Devices, 22.5mm Metal Series Ordering Information 1. Actuators, illuminated actuators, contact elements, lens assemblies and pilot lights are each ordered separately. For complete assemblies, please contact the factory for specific part numbers 2. Prefix AS2 for all actuators indicates 22.5 metal series 3. The type numbers of contact elements are: NO Actuator mounting S1, S3 Note: S3, S4, S7, and S8 have gold plated Individual mounting S5, S7 contact suitable for low voltage, low current NC Actuator mounting S2, S4 applications
AS2AF2
物料型号:文档中提到了多种型号的控制开关和信号设备,例如AS2AF3、AS2PLB4等,这些型号属于22.5mm金属系列。
器件简介:这些控制开关和信号设备设计用于节省空间、自清洁触点、符合RoHS标准、易于安装、抗振性强、具有防电击保护、外观美观、结构坚固、端子遮蔽、阻燃性能好,并使用LED以延长使用寿命。
引脚分配:文档中提到了不同的接触元件配置,如1到6个NO或NC元件,对于非照明操作器,以及1到4个NO或NC元件对于照明操作器。
参数特性:包括额定绝缘电压、额定热电流、接触操作的制作和断开能力、机械寿命超过一百万次操作等。
功能详解:文档详细描述了照明按钮和指示灯的连接方式,包括直接连接、通过串联电阻或串联电阻和二极管连接,并提供了不同电压下的连接示例。
应用信息:这些设备适用于多种工业控制和信号应用,包括非照明和照明操作器、指示灯和透镜组件。
封装信息:提供了详细的安装说明,包括推荐的安装中心距离、安装支架扭矩、环境标准符合性等。
AS2AF2 价格&库存
很抱歉,暂时无法提供与“AS2AF2”相匹配的价格&库存,您可以联系我们找货
