Control Switches
and Signaling Devices
22.5 mm Metal Series
Control Switches and Signaling Devices,
22.5mm Metal Series
292
Non-Illuminated Operators,
22.5mm Metal Series
294
Illuminated Operators, 22.5mm Metal Series 296
Pilot Lights and Lens Assemblies,
22.5mm Metal Series
297
22.5mm Metal Series
298
Airpax Corporation
807 Woods Road
Cambridge, Maryland
21613 USA
Tel: 410-228-1500
Fax: 410-228-3456
infoppp@airpax.net
Control Switches and Signaling Devices, 22.5mm Metal Series
This range of 22.5mm metal series pushbuttons, selector switches, illuminated switches and pilot lights have been designed to provide the following
features:
• Economy of space
• Self wiping contacts
• RoHS compliant
• Simple to mount (only need a screw driver)
• Mounting method is unaffected
by excessive vibration
• Electric shock protection (grounded unit)
• Aesthetically pleasing
• Heavy-duty construction
• Shrouded terminals
• Very good flame resistance
• Use of LEDs for long life
Actuators
The circular actuators have chrome plated metal bezels and are functionally interchangeable on the different contact elements.
40X30
Contact elements
The contact elements are double break and have self-wiping contacts. The elements are
interchangeable and can be stacked without additional hardware. 1 to 6 elements (NO or NC)
can be used for non-illuminated actuators, whereas, 1 to 4 elements (NO or NC) can be used
for illuminated actuators. Gold NO or NC contact elements for low voltage, low current, < 25mA,
switching applications are available.
43
24
24
Illuminated pushbuttons and pilot lights
Pilot lights and pushbutton switches are suitable for direct connection through a series resistor, series resistor and diode, using bayonet cap filament
bulb type BA9s as follows:
Supply voltage for direct connection without series resistor . . . . 6V - 130V
Supply voltage through series resistor . . . . . . . . . . . . . . . . . . . . 12V - 415V
Supply voltage through resistor and diode . . . . . . . . . . . . . . . . . 230 VAC
Bulb . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Filament, type BA9S with OAL max. 28mm
Terminals
Contact elements and pilot lights are designed to have shrouded terminals with combination screws.
Mounting
The metal series control devices 22.5mm can be mounted in any position
on panels of 1 to 6 mm thickness. We recommend minmum mounting centers
of 30mm x 40mm. However, the dimensions and configuration should be
decided on the basis of the application. The actuators and the lens
assemblies lock on the holding bracket. See assembly details.
Electrical and mechanical characteristics
Environment
Standards conformity:
CSA - C22.2 No. 14-95, UL508, EN60947-5-1 2000
Approvals:
CSA - C22.2 No. 14-95, UL508, VDE0660
Degree of protection:
IP 65 as per IEC529, NEMA 4X, 12 as per UL50
Ambient temperature:
-25°C to +70°C
Operating position:
All positions
Contact element block
Element screw torque:
Connection screw torque:
Rated insulationvoltage:
Rated thermal current:
Contact operation:
Make and break capacity
as per IEC 947-5-(1) 1990:
as per CSA - C22.2 No. 14-95, UL508
Ø 22.5 DIN
Mounting
details
40
Pilot lights and illuminated actuators are available with integral LEDs, suitable for operating at various voltages; 6V, 12V, 24V, 30V, 48V, 63.3V, 110V,
125V, 230VAC or DC and 415VAC. Pilot lights and illuminated actuators are available with LED bulbs (bayonet cap, BA9s design with OAL max. 28mm)
suitable for operating at various voltages; 24V, 48V, 110V and 230V. On request an extra short circuit protection consisting of built-in fuse in the LED
modules can be provided. Pilot lights are available with built -in transformers suitable for operating at 110VAC, 230VAC input and 6V, 12V and 24V
output.
Mounting bracket
screws torque
8 - 10 in/lbs
30
3 - 4 in/lbs
5 - 7 in/lbs
500V
10A
Self wiping, slow break NO or NC
AC 15 - 4A, 415VAC
DC 13 - 0.5A, 110VDC
A 600 Q 600
Terminal capacity:
Minimum 1 X 0.5mm2 (20AWG), maximum 2 x 15mm2 (2x16AWG), or 1 x 2.5mm2 (1x14AWG)
Terminals marking:
1-2 for NC, 3-4 for NO
Short circuit protection:
10A cartridge fuse, HRC type, rated for resistive loading
Mechanical life:
Over one million operations
Electrical rating:
(one million operating cycles at 3600 cycles per hour, load factor 0.5)
V
24
120
230
V
24
110
AC15
DC13
A
4
3
2
A
0.5
0.2
Modules for pilot lights and illuminated switches with integral LED / LED bulb (BA9S cap)
Current consumption (applicatable to all colors)
24VAC/DC, 110VAC and 240VAC:
max. 20mA
110VDC:
max. 15mA
220VDC:
max. 10mA
Service life(at nominial voltage and at ambient temperature): 100,000 hours
Voltage limits (nominal voltage):
±20% of rated voltage
on specific request
292 Terminal capacity:
min. 1 X 0.5mm2 (20AWG) max. 2 x 1.5mm2 (2x16AWG) or 1 x 2.5mm2 (1x14AWG)
Ordering Information
1. Actuators, illuminated actuators, contact elements, lens assemblies and pilot lights are each ordered separately. For complete assemblies, please
contact the factory for specific part numbers
2. Prefix AS2 for all actuators indicates 22.5 metal series
3. The type numbers of contact elements are:
NO
Actuator mounting S1, S3
Note: S3, S4, S7, and S8 have gold plated
Individual mounting S5, S7
contact suitable for low voltage, low current
NC
Actuator mounting S2, S4
applications
