HFX36S10
HFX36S10
    APEM(埃斐)
    HFX36S10
HFX36S10 数据手册
1.91in (48.51mm) 0.96in (24.38mm) 0.69in (17.53mm) TOP VIEW 1.38in (35.05mm) Ø0.12in (3.05mm) R 0.25in (6.35mm) Ø0.22in (5.59mm) SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE MECHANICAL OPERATING TRAVEL CENTERING BREAKOUT FORCE OPERATING FORCE MAXIMUM FORCE OPERATING TEMP LIFE EXPECTANCY WIRING RED BLACK BLUE YELLOW GREEN 5.0V DC 2.5V DC 10mA max/axis 2mA max/axis 0V – 5V DC ±2% 36° (18° from center) Single spring, omnidirectional 0.109Nm 0.151Nm 0.169Nm -40°C to +85°C 10 million operations Supply voltage Ground X-Axis Y-Axis Z-Axis Ø1.39in (35.31mm) SIDE VIEW 3.88in (98.04mm) 0.32in (8.13mm) 1.64in (41.66mm) 1.32in (33.53mm) 1.51in (38.35mm) Ø1.62in (41.15mm) Ø1.62in (41.15mm) BOTTOM VIEW 1.91in (48.51mm) RoHS compliant CH Products P/N DESCRIPTION HFX-36S10 REV Series I – 3 Axes, Low Profile PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED. A
HFX36S10 价格&库存
很抱歉,暂时无法提供与“HFX36S10”相匹配的价格&库存,您可以联系我们找货
HFX36S10
    • 1+2802.60000
    • 200+1118.26440
    • 500+1080.89640
