HG-3340S000
HG-3340S000
    APEM(埃斐)
    SWITCH JOYSTICK HALL EFFECT
HG-3340S000 数据手册
2.90in (73.66mm) SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE MECHANICAL OPERATING TRAVEL CENTERING BREAKOUT FORCE OPERATING FORCE MAXIMUM FORCE OPERATING TEMP LIFE EXPECTANCY WIRING RED BLACK BLUE YELLOW ORANGE VIOLET GRAY BROWN WHITE 11.90in (302.26mm) 5.0V DC 2.5V DC 10mA max/axis 2mA max/axis 0V – 5V DC ±2% 0.44in (11.18mm) 38° (19° from center) Single spring, omnidirectional 1.3Nm 1.5Nm 1.7Nm -40°C to +85°C 10 million operations 2.70in (68.58mm) Strain Relief 0.80in (20.3mm) 3.14in (79.76mm) 2.80in (71.12mm) Supply voltage Ground X-Axis Y-Axis Switch 1 Switch 2 Switch 3 Switch 4 Switch common Notes: -Drop-in mounting only 4.55in (115.57mm) 1.65in (41.91mm) -Standard HG joysticks are assembled with Strain Relief (.80in) -Lower profile housings are also available (contact Sales for details) 3.30in (83.82mm) 1.65in (41.91mm) Mounting Cutout Dimensions Ø0.281in (9/32) (7.14mm) 1.20in (30.48mm) 2.40in (60.96mm) 1.20in (30.48mm) Ø2.812in (2 13/16) (71.42mm) RoHS compliant CH Products P/N DESCRIPTION HG-3340S000 REV A Series IV – Multi, Square, 2 Axes, 4 Top Buttons PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED.
HG-3340S000 价格&库存
很抱歉,暂时无法提供与“HG-3340S000”相匹配的价格&库存,您可以联系我们找货
