1600
SERIES
Navigation Keypad
This highly tactile, USB compatible,
pointing device is ideal for use
in any application requiring
X-Y positional control.
Four directional keys allow navigation to specific
menu items or graphic icons (targets). Functions
or options associated with those targets can
be selected using the central ‘enter key’.
The keypad can also be used to control linear
movement of mechanical systems.
Integral LED illumination makes this 5 key control
pad highly visible and suitable for use in all lighting
conditions. Individual keytops feature both tactile
and visual delineation to ensure accurate
identification of key function. Intuitive functionality
and ‘Design for Accessibility’ ensure this
keypad is easy to use by those with sensory
or mobility impairment.
An industry standard USB interface ensures
simple connection and compatibility with
host systems, requiring no specialised drivers
or software applications.
70
56
• X-Y Positional
Control with
‘Enter Key’ function
• Cursor Control
• Menu Navigation
• USB Interface
(via Mini-B socket) with
All dimensions in mm
integral cable anchor device.
(Cable supplied separately)
• Factory set USB Key codes can be reprogrammed using
a software utility [free download]
• Integral illumination (Intensity can be set using API
or software utility [free download]
• Robust construction for reliability, durability and resilience
• Water and dust resistant (IP65)
• Designed for Accessibility
• Intuitive functionality with excellent tactile characteristics
The keypad’s robust, weather resistant
construction make it ideal for use in both
indoor or exposed outdoor conditions.
Its space efficient, compact, design
ensures a neat, water and dust resistant
‘under-panel’ installation as part of any
system control panel.
Performance
83
Vibration & Shock:
Impact Resistance:
Certification:
EMC:
ESD Immunity:
DDA / ADA:
Navigation Keypad
Part Numbers
Navigation, 5 key device
USB cable, USB A to USB Mini-B (90° angled), 0.9m long
1605-33001
4500-01
ETSI 6M3
IK09 (10J Rating)
CE / FCC / UL
EN55022 Class B
15kV Contact and Air
Compliant
Environmental
Operational temperature:
Weather Resistance:
UV
-20ºC to +70ºC (dry)
IP65 (when panel mounted)
Specification
Rating:
Connection:
Underpanel depth
5V + 0.25V (USB 2.0)
USB Mini-B Socket
25mm
Whilst every effort is made to ensure details are correct at time
of print, specifications are subject to change without notice.
For more information & to order:
www.storm-interface.com
Storm Interface products include
technology protected by international
patents and design registration.
All rights reserved.
Storm is a trademark
of Keymat Technology Ltd
Storm Interface is a trading name
PID1600 Nov 2015
This product is licensed under NCR’s design rights, including NCR U.S. Design Patent D687,783 and European Design Registration 001887290.
It includes proprietary technology and intellectual property retained by Keymat Technology Ltd (trading as Storm Interface).
Designed & produced by NIK Design Ltd
www.nikdesign.co.uk
FM 39602
很抱歉,暂时无法提供与“1605-330013”相匹配的价格&库存,您可以联系我们找货
