57.38
2.26
128.11
5.04
33.15
1.31
25.64
1.01
40.64
1.60
47.79
1.88
48.26
1.90
35.56
1.40
48.26
1.90
35.56
1.40
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES
TOLERANCES:
.X .030
.XX .010
.XXX .005
ANGLES 1
.XXXX .0005
FRACTIONS 1/32
: CRITICAL DIMENSIONS
MATERIAL
FORM NO.: EF-300
4
DRAWN
DATE
ET
7/16/2015
CHECKED
3
THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION
OF APEM, INC. AND IS TENTED SUBJECT TO THE
CONDITIONS THAT THE INFORMATION (A) BE RETAINED IN
CONFIDENCE (B) NOT BE REPRODUCED OR COPIED IN
WHOLE OR PART (C) NOT BE LEASED TO THIRD PARTY AND
MANUFACTURERS OF MAN-MACHINE INTERFACE PRODUCTS (D) NOT BE USED OR INCORPORATED IN ANY PRODUCT
970 PARK CENTER DR. VISTA, CA 92081
EXCEPT UNDER EXPRESSED WRITTEN AGREEMENT WITH
TEL: (760) 598-2518 FAX: (760) 598-2524
APEM, INC.
TITLE:
ENG APPR.
SIZE
A
COMMENTS:
FINISH
5
NAME
For Catalog
HF3397
PROJECT/ACCT. NO.
PLOTFILE: 12/22/2015
SCALE: 1:2
2
DWG. NO.
REV
FILE NO.
DO NOT SCALE DRAWING
1
SHEET 1 OF 1
CAN CONFIGURATION GUIDE
CUSTOMER:
Firmware : 520-416 Rev A
PART#:
HF3397
ID Selection
Check mark as required
Fill in as required
#1
11 BIT
#2
FILL IN 1 TX AND 1 RX IDENTIFIER FOR EACH WIRE COMBINATION AT RIGHT
TX is from Joystick to bus
MSB
Select
Orange
Blue
WIRE
WIRE
G
G
Address 0
LSB
RX is from bus to Joystick
TX
Address 1
G
RX
IDENTIFIER
(CAN2.0A)
TX
RX
CAN ID
#3
TX
Address 2
G
RX
#4
TX
Address 3
RX
#1
TX
F
D
D
7
0 FILL IN 1 TX AND 1 RX IDENTIFIER FOR
RX
29 BIT
#2
G
G
TX
F
D
D
7
1 TX is from Joystick to bus
Address 1
F
D
D
7
Address2
F
D
D
7
Address 3
G
RX
IDENTIFIER
(CAN2.0B)
Address 0
#3
TX
G
RX
#4
TX
RX
8
8 BYTE TX DATA FRAME
1
B B B B
1
1
1
1
1
1
1
1
1
2
2
6
1
1
1
1
Z
5
Z
Z
Z
Z
Z
Z
Z
Z
Z
Z
Z
Z
L
L
R R N N Y Y Y Y Y Y Y Y Y Y U U D D N N X X X X X X X X X X R R
Z
Z
Z
4
3
Y Y Y
Y Y Y
2
1
X X X X X
L
L
N
X
很抱歉,暂时无法提供与“HF3397”相匹配的价格&库存,您可以联系我们找货
