HF3395
HF3395
    APEM(埃斐)
    HF3395
HF3395 数据手册
48.26 1.90 37.34 1.47 48.26 1.90 120.86 4.76 35.56 1.40 33.15 1.31 35.56 1.40 40.64 1.60 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: .X .030 .XX .010 .XXX .005 ANGLES 1 .XXXX .0005 FRACTIONS 1/32 : CRITICAL DIMENSIONS MATERIAL FORM NO.: EF-300 4 DRAWN DATE ET 7/16/2015 CHECKED 3 THIS DOCUMENT CONTAINS PROPRIETARY INFORMATION OF APEM, INC. AND IS TENTED SUBJECT TO THE CONDITIONS THAT THE INFORMATION (A) BE RETAINED IN CONFIDENCE (B) NOT BE REPRODUCED OR COPIED IN WHOLE OR PART (C) NOT BE LEASED TO THIRD PARTY AND MANUFACTURERS OF MAN-MACHINE INTERFACE PRODUCTS (D) NOT BE USED OR INCORPORATED IN ANY PRODUCT 970 PARK CENTER DR. VISTA, CA 92081 EXCEPT UNDER EXPRESSED WRITTEN AGREEMENT WITH TEL: (760) 598-2518 FAX: (760) 598-2524 APEM, INC. TITLE: ENG APPR. SIZE A COMMENTS: FINISH 5 NAME For Catalog HF3395 PROJECT/ACCT. NO. PLOTFILE: 12/22/2015 SCALE: 1:2 2 DWG. NO. REV FILE NO. DO NOT SCALE DRAWING 1 SHEET 1 OF 1 CAN CONFIGURATION GUIDE CUSTOMER: Firmware : 520-413 Rev A PART#: HF3395 ID Selection Check mark as required Fill in as required #1 11 BIT #2 FILL IN 1 TX AND 1 RX IDENTIFIER FOR EACH WIRE COMBINATION AT RIGHT TX is from Joystick to bus MSB Select Orange Blue WIRE WIRE G G Address 0 LSB RX is from bus to Joystick TX Address 1 G RX IDENTIFIER (CAN2.0A) TX RX CAN ID #3 TX Address 2 G RX #4 TX Address 3 RX #1 TX 0 0 F D D 7 0 0 FILL IN 1 TX AND 1 RX IDENTIFIER FOR RX 29 BIT #2 G G TX 0 0 F D D 7 0 1 TX is from Joystick to bus RX is from bus to Joystick Address 1 0 0 F D D 7 0 2 Address2 0 0 F D D 7 0 3 Address 3 G RX IDENTIFIER (CAN2.0B) Address 0 EACH WIRE COMBINATION AT RIGHT #3 TX G RX #4 TX RX 8 8 BYTE TX DATA FRAME 1 7 1 1 1 1 1 1 1 1 6 1 1 1 1 1 1 1 Z 5 Z Z Z Z Z Z Z Z Z Z Z Z L L R R N N Y Y Y Y Y Y Y Y Y Y U U D D N N X X X X X X X X X X R R Z Z Z 4 3 Y Y Y Y Y Y 2 1 X X X X X L L N X
HF3395 价格&库存
很抱歉,暂时无法提供与“HF3395”相匹配的价格&库存,您可以联系我们找货
