HFX33R13
HFX33R13
    APEM(埃斐)
    HFX33R13
HFX33R13 数据手册
1.91in (48.51mm) 0.96in (24.38mm) 0.69in (17.53mm) TOP VIEW 1.38in (35.05mm) Ø0.12in (3.05mm) R 0.25in (6.35mm) Ø0.22in (5.59mm) SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE 5.0V DC 2.5V DC 10mA max/axis 2mA max/axis 2V – 3V DC ±2% MECHANICAL OPERATING TRAVEL CENTERING BREAKOUT FORCE OPERATING FORCE MAXIMUM FORCE OPERATING TEMP LIFE EXPECTANCY 36° (18° from center) Single spring, omnidirectional 0.109Nm 0.151Nm 0.169Nm -40°C to +85°C 10 million operations Ø1.39in (35.31mm) SIDE VIEW 4.26in (108.20mm) 0.32in (8.13mm) 1.64in (41.66mm) 1.32in (33.53mm) 1.51in (38.35mm) Ø1.62in (41.15mm) WIRING RED BLACK BLUE YELLOW GREEN Supply voltage Ground X-Axis Y-Axis Z-Axis Ø1.62in (41.15mm) BOTTOM VIEW 1.91in (48.51mm) RoHS compliant P/N CH Products DESCRIPTION HFX-33R13 REV Series I – 3 Axes, no Button PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED. A
HFX33R13 价格&库存
很抱歉,暂时无法提供与“HFX33R13”相匹配的价格&库存,您可以联系我们找货
HFX33R13
  • 1+5397.326871+701.63503
  • 5+4706.787235+611.86711
  • 10+4436.6375510+576.74853
库存:9
