1.50in
(38.10mm)
2.51in
(63.75mm)
Top View
1.50in
(38.10mm)
0.20in
(5.08mm)
YX+
Y+
X-
Front View
SPECIFICATIONS
ELECTRICAL
SUPPLY VOLTAGE
CENTER VOLTAGE
SUPPLY CURRENT
OUTPUT CURRENT
EFFECTIVE OUTPUT
OUTPUT TOLERANCE
MECHANICAL
OPERATING TRAVEL
CENTERING
BREAKOUT FORCE
OPERATING FORCE
MAXIMUM FORCE
OPERATING TEMP
LIFE EXPECTANCY
WIRING
RED
BLACK
BLUE
YELLOW
ORANGE
VIOLET
WHITE
RoHS compliant
5.0V DC
2.5V DC
10mA max/axis
2mA max/axis
0V – 5V DC
±2%
40° (20° from center)
Single spring,
omnidirectional
0.544Nm
0.653Nm
1.306Nm
-40°C to +85°C
10 million operations
Supply voltage
Ground
X-Axis
Y-Axis
Switch 1
Switch 2
Switch common
5.80in
(147.32mm)
0.20in
(5.08mm)
0.19in
(4.83mm)
8.58in
(217.93mm)
2.58in
(65.53mm)
2.19in
(55.63mm)
2.13in
(54.10mm)
2.51in
(63.75mm)
Bottom View
2.51in
(63.75mm)
Brass ultraserts 6-32 x 0.25
Screw 6-32 x 7/8 PH PAN s/s
4 places
2.01in
(51.05mm)
Note: Actual strain relief position
may vary from specifications.
CH
Products
P/N
DESCRIPTION
MS-42N20S000
REV
A
Series III – 2 Axes, Stock Grip, 2 Top Buttons
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY
OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT
THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED.
很抱歉,暂时无法提供与“MS-42N20S000”相匹配的价格&库存,您可以联系我们找货
