HFX2-11S10
HFX2-11S10
    APEM(埃斐)
    JOYSTICK SERIES2 2AXIS NO BUTTON
HFX2-11S10 数据手册
2.05in (52.07mm) 1.025in (26.035mm) TOP VIEW + 0.75in (19.05mm) 1.50in (38.10mm) Ø0.12in (3.05mm) Ø0.22in (5.59mm) R 0.275in (6.99mm) Ø0.83in (21.08mm) SIDE VIEW SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE MECHANICAL OPERATING TRAVEL CENTERING BREAKOUT FORCE OPERATING FORCE MAXIMUM FORCE OPERATING TEMP LIFE EXPECTANCY WIRING RED BLACK BLUE YELLOW 5.0V DC 2.5V DC 10mA max/axis 2mA max/axis 0V – 5V DC ±2% 40° (20° from center) Single spring, omnidirectional 0.257Nm 0.128Nm 0.385Nm -40°C to +85°C 10 million operations 4.09in (103.89mm) 0.15in (3.81mm) 0.16in (4.06mm) 1.79in (45.47mm) 1.48in (37.59mm) 0.18in (4.57mm) Ø1.80in (45.72mm) BOTTOM VIEW Ø1.80in (45.72mm) Supply voltage Ground X-Axis Y-Axis 2.05in (52.07mm) RoHS compliant CH Products P/N DESCRIPTION HFX2-11S10 REV Series II – 2 Axes, no Button PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED. A
HFX2-11S10 价格&库存
很抱歉,暂时无法提供与“HFX2-11S10”相匹配的价格&库存,您可以联系我们找货
