MS-10N00S000
MS-10N00S000
    APEM(埃斐)
    JOYSTICK SERIES III BALL TIP
MS-10N00S000 数据手册
2.51in (63.75mm) 1.75in (44.45mm) Top View 1.75in (44.45mm) Y+ X- Y- X+ 3.70in (93.98mm) Side View 0.20in (5.08mm) 0.19in (4.83mm) 6.28in (159.51mm) SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE MECHANICAL OPERATING TRAVEL CENTERING BREAKOUT FORCE OPERATING FORCE MAXIMUM FORCE OPERATING TEMP LIFE EXPECTANCY WIRING RED BLACK BLUE YELLOW RoHS compliant 5.0V DC 2.5V DC 10mA max/axis 2mA max/axis 0V – 5V DC ±2% 40° (20° from center) Single spring, omnidirectional 0.544Nm 0.653Nm 1.306Nm -40°C to +85°C 10 million operations Supply voltage Ground X-Axis Y-Axis 2.58in (65.53mm) 2.19in (55.63mm) 0.05in (1.27mm) 2.13in (54.10mm) 2.51in (63.75mm) Bottom View 2.01in (51.05mm) 2.51in (63.75mm) Brass ultraserts 6-32 x 0.25 Screw 6-32 x 7/8 PH PAN s/s 4 places Note: Actual strain relief position may vary from specifications. CH Products P/N DESCRIPTION MS-10N00S000 REV Series III – 2 Axes, Ball Tip PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED. A
MS-10N00S000 价格&库存
很抱歉,暂时无法提供与“MS-10N00S000”相匹配的价格&库存,您可以联系我们找货
