TBF-PO
TBF-PO
    APEM(埃斐)
    TBF-PO
TBF-PO 数据手册
Low Voltage SPECIFICATIONS ELECTRICAL SUPPLY VOLTAGE CENTER VOLTAGE SUPPLY CURRENT OUTPUT CURRENT EFFECTIVE OUTPUT OUTPUT TOLERANCE MECHANICAL OPERATING TRAVEL CENTERING OPERATING FORCE OPERATING TEMP LIFE EXPECTANCY 5.0V DC 2.5V DC 6mA max 2mA max 0V – 5V DC ±2% 63° (31.5° from center) Friction clutch 0.115Nm -40°C to +85°C 10 million operations 2.32in (58.93mm) 1.44in (36.58mm) 31.5° 0.19in (4.83mm) 31.5° 0.30in (7.62mm) 0.57in (14.48mm) Ø0.17in (4.32mm) Solder Lugs 3 places: 1. +5V 2. Output 3. Ground Front View 4-40 Threaded Hole (Brass Ultrasert) 2 places High Voltage 0.77in (19.56mm) 3.76in (95.50mm) 0.77in (19.56mm) Ø0.63in (16.00mm) 1.62in (41.15mm) 1 2 3 1.28in (32.51mm) 0.89in (22.61mm) 0.25in (6.35mm) 2 places 2.95in (74.93mm) Side View Top View RoHS compliant CH Products P/N DESCRIPTION TBF-PO REV T-Bar Fader PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED. A
TBF-PO 价格&库存
很抱歉,暂时无法提供与“TBF-PO”相匹配的价格&库存,您可以联系我们找货
