Membrane 3x4 Matrix Keypad + extras - 3x4
Product ID: 419
Punch in your secret key into this numeric matrix keypad. This keypad has 12 buttons,
arranged in a telephone-line 3x4 grid. It's made of a thin, flexible membrane material with
an adhesive backing (just remove the paper) so you can attach it to nearly any thing. The
keys are connected into a matrix, so you only need 7 microcontroller pins (3 -columns and
4-rows) to scan through the pad. Check the tutorials tab for links to an Arduino library and
example code.
We include a 7-pin extra-long header strip so you can plug this into a breadboard with
ease.
Check out our detailed guide with wiring diagrams, libraries and example sketches for all
sorts of matrix keypads.
Technical Details
Weight: 7.5 grams
Keypad dimensions: 70mm x 77mm x 1mm (2.75" x 3" x 0.035")
Length of cable + connector: 85mm
7-pin 0.1" pitch connector
https://www.adafruit.com/product/419 9-22-22
很抱歉,暂时无法提供与“419”相匹配的价格&库存,您可以联系我们找货
