WE1KT103
WE1KT103
    STORMINTERFACE
    SWITCH KEYPAD 12 KEY NON-ILLUM
WE1KT103 数据手册
The Secure Alternative t orm Secure Keypads for access control With rising crime rates and an increasing incidence of assaults on personnel, the need to control access to buildings or work areas has never been greater. It is essential to provide free access to authorised personnel, whilst securing premises against those who are not. The high risk practice of issuing duplicate door keys is no longer acceptable or economically viable. Keys (or cards) are regularly lost, stolen or copied. If a breach in security is suspected, locks must be changed and new keys (or cards) issued. This is not practical on a repeated or routine basis. The fitting of a STORM AXS Keypad provides a secure, efficient and cost effective solution. Authorised personnel can be allocated a ‘Personal Identification Number’ (PIN) which, when entered into the keypad, triggers an electrically operated strike or lock. This permits instant access through a normally locked door or barrier. PIN codes can be regularly changed to maintain system security, or can be withdrawn at any time to discontinue an individual’s access to the secured area. Code holders can be given access to selected areas and debarred from others. For example; an office worker’s PIN code can be programmed to allow access to an administration centre but prohibit access to a stores area; whereas the Store Manager’s PIN code can be programmed to access both the administration centre and the stores area. PIN codes can be programmed to unlock a door and leave it unlocked (latched) until the code is re-entered. Alternatively they can be programmed to unlock the door for a pre-set time allowing just one person to enter before the door re-locks. Robust, responsive keypad STORM AXS Keypads provide rapid and reliable access control in technology, professional ‘high-traffic’ proven in applications. Constructed to withstand hard use and military, abuse the keypads can industrial be fitted in exposed outdoor locations. Available in both ‘general and public service’ and ‘vandal resistant’ environments. specifications, complying with current and forthcoming mandatory standards, STORM AXS Keypads are ideal for use in all indoor and outdoor installations. Secure and simple to install. t orm Secure Keypads for access control STORM AXS Keypads include sophisticated electronic controllers. These controllers, utilising the latest developments in microprocessor technology, are securely housed within the keypad casing. The keypads include high level protection against static discharge damage. They can be selected to achieve direct, local control of door locking mechanisms (Strike Master) or to provide electronic communication with centralised alarm and access control systems (Code Master). The STORM AXS Strike Master keypad includes an electronic sensor that detects any attempt to remove or tamper with the keypad. This feature provides high level system security whilst maintaining the advantages of a self-contained, compact, ‘one-box’ installation. A CHOICE OF ELECTRONIC INTERFACES Strike Master Code Master Secure, self-contained keypad and controller for electrically operated locks and strikes. Authorised personnel can use their PIN code to open either one or two normally locked doors. Up to 50 different 4, 5 or 6 digit codes can be individually programmed. Each code can be set to trigger an electric lock or strike for a pre-set time (allowing just one person to access), or to ‘latch’ the door in an unlocked condition (requiring the code to be re-entered to ‘unlatch’ or re-lock the door). If the Strike Master keypad is used to control a single door, the ‘forced door alarm’, ‘anti-tamper alarm’ and ‘duress alarm’ features can be enabled. • Up to 50 user programmable PIN codes • 4, 5 or 6 digit PIN codes • Indexing permits the secure allocation and re-allocation of PIN codes • One or two door control • Anti-tamper alarm • PIN code entered under duress alarm • Forced door alarm • Timed release or latched door option for each PIN code • Fail (open) Fail (closed) option • Timed lock out for repeated invalid code input • Remote exit switch facility • Hidden PIN code feature • All weather resistant • LED and audible tone status indication • Requires 11 to 28V DC or 9 to 20V AC supply • Quick and easy to install • Three protection levels: i) Anti-vandal keypad for exposed, unsupervised hostile, public locations ii) Vandal resistant keypad for unsupervised, public, outdoor locations iii) Robust keypad for outdoor/indoor location Converts codes entered via the keypad into industry standard (Weigand) data. Suitable for use as a replacement for (or in conjunction with) most standard card readers. Intended for use with integrated access control / security systems, the keypad’s electronic interface is user programmable for 26 or 32 bit (Weigand) data output. • • • • • • • Selectable ‘keypress’ audible tone Selectable ‘code accepted’ audible tone All weather resistant LED status indication Requires 5V to 12V DC supply Quick and easy to install Three protection levels: i) Anti-vandal keypad for exposed, unsupervised hostile, public locations ii) Vandal resistant keypad for unsupervised, public, outdoor locations iii) Robust keypad for outdoor/indoor location -COM A Secure, self contained, two way voice communication system in 1 and 4 doorbell/callbutton versions The Secure Alternative t orm (Fixing hardware, sealing gaskets and comprehensive installation / operating instructions supplied) Secure Keypads for access control 1 PRODUCT SPECIFICATIONS 2 3 4 5 6 7 8 9 0 Four tamper-resistant stainless steel security screws Twin diode (2 colour) LED indicator 19.00 Strike Master 30.00 1 2 3 4 5 6 Door Sensor 19.00 4 5 6 7 8 9 Remote/ Exit Switch 93.00 3 10. Remote Switch - To open door 1 from within secure area 9. Door Sensor - Used to monitor door 1 condition (open/closed) 118.50 2 82.50 1 Door Strike 8. Door/Call Bell - Open collector gate 7. Alarm/Door 2 Release Relay - Fully floating (volts free contact) 7 8 9 6. Alarm/Door 2 Release Relay - Fully floating (volts free contact) 5. Door 1 Release Relay - Relay output (normally closed) 4. Common - Relay common Door/call Bell 0 3. Door 1 Release Relay - Relay output (normally open) 2. Supply - Range 11 to 28 volts dc or 9 to 20 volts ac. Alarm Bell/ Klaxon 1. Return - Zero volts 0 13.35 Overall 63.50 11.1 10.50 8 2.5 74.00 99.50 Power Supply +V 0V All dimensions in mm Four tamper-resistant stainless steel security screws Twin diode (2 colour) LED indicator 19.00 Code Master 30.00 1 2 3 4 5 6 19.00 4 5 6 7 8 9 5. Indicator input (LED) 4. Weigand data 1 118.50 3 93.00 2 82.50 1 System 3. Weigand data 0 2. Supply - Range 5V to 12V DC 7 1. Return - Zero volts 8 9 0 CLR ENT 13.35 Overall 63.50 11.1 10.50 8 2.5 74.00 99.50 PRODUCT FEATURES ANTI VANDAL VANDAL RESISTANT GENERAL SERVICE K E Y P A D K E Y P A D K E Y P A D Strike Master DE1KT1 DEPLXT2 DE2KT1 Code Master WE1KT1 WEPLXT2 WE2KT1 > 4 Million > 4 Million > 4 Million -20°C to +70°C -20°C to +70°C -20°C to +70°C Chromed Zinc Super Impact Polymer Super Impact Polymer Silver Black Mid Grey Chromed Zinc Chromed Zinc Super Impact Polymer Silver Silver Light Grey Engraved Engraved Laser Marked Black Black Dark Grey Key Life (cycles) Service Temp (Dry) Keypad Material Keypad Colour Keytop Material Keytop Colour Keytop Legends Legend Colour Carbon / Gold Carbon / Gold Carbon / Gold Weather Sealed IP65 IP65 IP65 Resistance to Static Discharge > 12.5 KV > 12.5 KV > 12.5 KV Contact Materials Connect to access control / security system (refer to manufacturer’s instructions for connection details). 0 All dimensions in mm All STORM AXS Keypads incorporate the proven STORM switching technology ensuring rapid, reliable and responsive data entry. Specified to survive in different service environments, ranging from exposed, unsupervised public environments to general service / indoor installations. Keypads in the STORM AXS range are dimensionally and electrically interchangeable. This allows users, entering codes at all outdoor or indoor access points, to establish and maintain familiarity with the keypad features. Whilst every effort is made to ensure details are correct at time of print, specifications are subject to change without notice. Storm is a trademark of Keymat Technology Ltd Storm Interface is a trading name of Keymat Technology Ltd MAY 1999 AXS-LIT-01 1SS.3 003 FM 39602 Storm Interface products include technology protected by international patents and design registration. All rights reserved. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Storm Interface: DE1KT103 WE1KT103 WE2KT103 WEPLXT203
WE1KT103 价格&库存
很抱歉,暂时无法提供与“WE1KT103”相匹配的价格&库存,您可以联系我们找货
