EZB6-430003
EZB6-430003
    STORMINTERFACE
    NAV-BAR,6KEYS,USBINTERFACE
EZB6-430003 数据手册
CIVIC CORPORATE ADA compliant, tactile keypad for audible system navigation RETAIL Nav-Bar TM Storm Assistive Technology Products provide improved accessibility for those with impaired vision, restricted mobility or limited fine motor skills. Kiosks, ATMs, ticketing machines and voting terminals usually present information about available products and services via a visual display or touch screen. Nav-Bar™ is a highly tactile interface that improves accessibility, making audio navigation and selection of screen based menus possible. An audio description of available menu options is transmitted to the user through a headset, handset or cochlea implant. When the desired menu page or menu option is located it can be selected by the press of a distinctive tactile button. Successful implementation of the Nav-Bar™ requires a compliant host application featuring synthesized or recorded human voice audio-tags. Nav-Bar™ was developed in association with the Trace Research & Development Center with support from the University of Wisconsin. Nav-Bar™ is a compliant tactile interface device for use as part of an ADA audible menu navigation system or EZ-Access® implementation. 37 208 16 • Space efficient horizontal format for use with contemporary touch-screen kiosks. All dimensions in mm Performance Vibration & Shock: Impact Resistance: Sealing: Operational Key Life: Certification: ETSI 6M3 IK09 (10J Rating) (when correctly installed to a panel top surface) IP65 (when correctly installed to a panel top surface) >4 million cycles per key CE / FCC / UL Environmental Operational temperature: Weather Resistance: -20ºC to +70ºC (dry) IP65 (when panel mounted) Specification Rating: Connection: Audio: Ground: USB Cable Interconnect Cable 5V +/- 0.25V (USB 2.0) Mini USB B Socket 3.5mm Audio Jack Socket (Illuminated) 150mm ESD ground wire fitted Not included 0.75m cable (Nav-Bar to Audio-Module) included with Audio-Module • Easy to navigate and makes audio references to a key’s position and function easier to understand. For example: The circular shaped ‘select’ key is the second key from the right. • Internal colour coded illumination makes location of individual keys much easier for those with partial vision. • The keytop’s distinctive shape and tactile symbols provide the primary means of identifying a key’s specific function. • The intensity of keytop illumination can be adjusted or turned off when not in use. • Each keytop is illuminated by a dedicated LED light source. Each LED is independently controllable. • By use of the Nav-Bar™ utility software, default illumination status and ‘wake-up’ behaviour can be selected. USB key-press codes can also be changed. • Optional Audio-Module includes sound volume controls and an illuminated jack plug socket for headset connection. (Audio-Module supplied separately). • The Audio-Module can be positioned separately from the Nav-Bar™ to optimize system ergonomics. • Nav-Bar™ is connected to the Audio-Module via a ribbon cable (supplied). • Nav-Bar™ is connected to the host system via a single USB cable (supplied separately). Storm, Storm ATP, Storm Interface, Nav-Bar and Audio-Module are trademarks of Keymat Technology Ltd. All rights reserved, EZ Access® is a trademark of the Wisconsin Alumni Research Foundation. Nav-Bar Top View Nav-Bar™ Dimensional Details End View 37 208 16 Side View (shown with 2mm thick panel) Fix with Qty 6, M3 x 8 panhead screws 16 Rear View 171 27 108.5 Socket for 750mm Link Cable (ferrite is located at Nav-Bar™ end of cable) Audio-Module Dimensional Details 83 Mini-B USB socket for connection to host Top View Side View Rear View 26 44 119 107.5 32.5 Note that the raised headphone symbol will be rotated 90° clockwise for horizontal version M3 x 20 weld stud 4 places Whilst every effort is made to ensure details are correct at time of print, specifications are subject to change without notice. Part Numbers Nav-Bar™ Audio-Module for Nav-Bar™ & Interconnect Cable EZB6-43000 EZB2-40500 Audio-Module for Nav-Bar™ & Interconnect Cable EZB2-405H0 Spare Interconnect Cable 0.75m USB Cable Mini-B to Type A 0.95m (not included) EZB2-01 4500-01 (Vertical installation) (Horizontal installation) M3 thread ASD ground to case (150mm ground wire not shown) For more information & to order: www.storm-interface.com Storm Interface products include technology protected by international patents and design registration. All rights reserved. Storm is a trademark of Keymat Technology Ltd Storm Interface is a trading name of Keymat Technology Ltd Nav-Bar Dec 2016 Designed & produced by NIK Design Ltd www.nikdesign.co.uk FM 39602 TM Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Storm Interface: EZB2-405H06 EZB2-405H03 EZB6-430003 EZB6-430006 EZB2-405006 EZB2-405003
EZB6-430003 价格&库存
很抱歉,暂时无法提供与“EZB6-430003”相匹配的价格&库存,您可以联系我们找货
EZB6-430003
  • 1+2371.118191+296.29423
  • 10+1976.4331010+246.97450
  • 25+1853.3460625+231.59358
  • 50+1772.5813150+221.50124
库存:5
