27944
27944
    PARALLAXINC.
    KEYPAD MATRIX 4X4
27944 数据手册
CONDUCTIVE RUBBER KEYPADS SERIES 96 FEATURES • Quality, Economical Keyboards • Easily Customized Legends • Termination Mates With Standard Connectors • Tactile Feedback to Operator • 3,000,000 Operations per Button • Compatible With High Resistance Logic Inputs HOUSING KEYPAD BOOT PC BOARD The Series 96 is Grayhill's most economical 3x4 and 4x4 keypad family. The contact system utilizes conductive rubber to mate the appropriate PC board traces. Matrix and single pole/ common bus circuitry is offered. Built with quality component parts. The Series 96 is subjected to our rigid statistical process control to insure that it meets our reliability standards. An ISO-9001 Company 561 Hillgrove Avenue • LaGrange, Illinois 60525 • USA • Phone: (708) 354-1040 • Fax: (708) 354-2820 • http://www.grayhill.com C-4 CONDUCTIVE RUBBER KEYPADS DIMENSIONS In inches (and millimeters) 3x4 Front Mount Keyboard 3 4 5 6 7 8 9 10 11 12 321 .125 (3,18) .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD .150 (3,81) 2.400 (60,96) GRAYHILL INC .062 (1,57) R. 2 PLS. .125 (3,18) DIA. 2 PLS. LABEL LABEL .100 (2,54) DIA. 4 PLS. .100 (2,54) DIA. 4 PLS. .150 (3,81) 1.700 (43,18) 1.700 (43,18) TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 3 2 1 0 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .098 (2,49) REF. TERMINAL PIN HEADER 3x4 Rear Mount Keyboard Matrix Output Single Pole/Common Bus .030 (0,76) 2.200 ± .015 (55,88 ± 0,38) 2.000 (50,8) .340 ± .015 (8,64 ± 0,38) .030 (0,76) .025 ± .002 (0,64 ± 0,05) SQ. PIN .750 (19,05) .650 (16,51) .500 (12,7) .600 (15,24) .700 (17,78) .025 ± .002 (0,64 ± 0,05) SQ. PIN 1.200 (30,48) .400 (10,16) 321 2 3 4 5 6 7 8 9 10 11 12 .495 (12,57) .308 (7,82) SQ. BUTTON 12 PLS. REAR PANEL MOUNT CUTOUT 2.800 (71,12) 987654321 .200 (5,08) .500 (12,7) .200 (5,08) 1.500 (38,1) GRAYHILL INC GRAYHILL INC 1.000 (25,4) SW. POS. ID 2.800 (71,12) 3.000 ± .015 (76,2 ± 0,38) 1.990 + .000 –.005 (50,55 + 0,00 –0,13) .050 (1,27) 2.000 (50,8) .150 + .000 –.005 R. (3,81 + 0,00 –0,13) 4 PLS. .340 ± .015 (8,64 ± 0,38) .150 (3,81) R. 4 PLS. .600 (15,24) 1.000 (25,4) 1 .150 (3,81) .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER .250 (6,35) 4 PLS. .200 (5,08) .125 (3,18) MAXIMUM PANEL THICKNESS RECOMMENDED 2.690 + .000 .595 –.005 (15,11) (68,33 + 0,00 –0,13 987654321 2.400 (60,96) GRAYHILL INC 1.700 (43,18) .500 (12,7) .250 (6,35) 1.200 (30,48) 1.000 (25,4) .308 (7,82) SQ. BUTTON 12 PLS. 2.400 (60,96) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) 2.700 1.500 ± .015 (38,1) (68,58 ± 0,38) SWITCH POSITION IDENTIFICATION FRONT PANEL MOUNT CUTOUT .550 (13,97) .600 (15,24) .600 (15,24) .500 (12,7) .030 (0,76) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) R. 4 CORNERS .500 (12,7) 2 Single Pole/Common Bus .030 (0,76) 2.000 ± .015 (50,8 ± 0,38) .500 (12,7) 1.000 (25,4) 1 Matrix Output .062 (1,57) .200 (5,08) .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD LABEL .093 (2,36) DIA. 4 PLS. 2.700 (68,58) .100 (2,54) R. 4 PLS. LABEL .093 (2,36) DIA. 4 PLS. .100 (2,54) REF. TERMINAL PIN HEADER .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 3 2 1 0 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .062 (1,57) MAXIMUM PANEL THICKNESS RECOMMENDED .098 (2,49) REF. TERMINAL PIN HEADER .100 (2,54) R. 4 PLS. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .093 (2,36) DIA., 4 PLS. OR 2-56 X .250 (6,35) LONG STUD See page C-7 for code and truth tables, specifications, standard legends and ordering information. C-5 An ISO-9001 Company 561 Hillgrove Avenue • LaGrange, Illinois 60525 • USA • Phone: (708) 354-1040 • Fax: (708) 354-2820 • http://www.grayhill.com CONDUCTIVE RUBBER KEYPADS DIMENSIONS In inches (and millimeters) 4x4 Front Mount Keyboard 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 .700 (17,78) 76 .150 (3,81) 2.400 (60,96) GRAYHILL INC GRAYHILL INC 1.000 (25,4) 2.200 (55,88) LABEL .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD .308 (7,82) SQ. BUTTON 12 PLS. .125 (3,18) LABEL .100 (2,54) DIA. 4 PLS. TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .098 (2,49) REF. TERMINAL PIN HEADER 4x4 Rear Mount Keyboard .500 (12,7) .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION 8 7 6 5 4 3 2 1 .125 (3,18) DIA. 2 PLS. Matrix Output Single Pole/Common Bus .030 (0,76) .340 ± .015 (8,64 ± 0,38) .150 (3,81) R. 4 PLS. .030 (0,76) .025 ± .002 (0,64 ± 0,05) SQ. PIN .750 (19,05) .700 (17,78) .650 (16,51) 1 2 3 4 1.600 (40,64) .900 (22,86) 5 6 7 8 9 10 11 12 13 14 15 16 .495 (12,57) REAR PANEL MOUNT CUTOUT 2.500 (63,5) 2.800 (71,12) .150 + .000 –.005 R. (3,81 + 0,00 –0,13) 4 PLS. 987654321 .200 (5,08) 1.500 (38,1) GRAYHILL INC GRAYHILL INC 1.000 (25,4) SW. POS. ID .308 (7,82) SQ. BUTTON 12 PLS. 321 .400 (10,16) .200 (5,08) .500 (12,7) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN 76 2.690 + .000 .595 –.005 (15,11) (68,33 + 0,00 –0,13 .150 (3,81) 2.200 (55,88) .100 (2,54) REF. TERMINAL PIN HEADER .125 (3,18) MAXIMUM PANEL THICKNESS RECOMMENDED 2.700 ± .015 (68,58 ± 0,38) 2.500 (63,5) 1.500 (38,1) 1.000 (25,4) .100 (2,54) DIA. 4 PLS. .150 (3,81) 2.200 (55,88) .250 (6,35) 4 PLS. .200 (5,08) .062 (1,57) R. 2 PLS. 2.400 (60,96) .500 (12,7) 987654321 321 2.400 (60,96) SWITCH POSITION IDENTIFICATION .600 (15,24) .250 (6,25) 1.600 (40,64) .150 (3,81) 2.700 1.500 ± .015 (38,1) (68,58 ± 0,38) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .750 (19,05) .600 (15,24) .500 (12,7) .030 (0,76) .340 ± .015 (8,64 ± 0,38) .025 ± .002 (0,64 ± 0,05) SQ. PIN .150 (3,81) R. 4 CORNERS .500 (12,7) FRONT PANEL MOUNT CUTOUT Single Pole/Common Bus .030 (0,76) 2.500 ± .015 (63,5 ± 0,38) 1.500 (38,1) 1.000 (25,4) .500 (12,7) Matrix Output 2.800 (71,12) 3.000 ± .015 (76,2 ± 0,38) 2.490+ .000 –.005 (63,25 + 0,00 –0,13) .050 (1,27) .062 (1,57) .200 (5,08) .075 (1,91) BUTTON HEIGHT .020 (0,51) HIGH BUTTON GUARD LABEL .093 (2,36) DIA. 4 PLS. .100 (2,54) R. 4 PLS. .093 (2,36) DIA. 4 PLS. .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION 8 7 6 5 4 3 2 1 2.700 (68,58) LABEL .100 (2,54) REF. TERMINAL PIN HEADER TERMINAL PIN IDENTIFICATION 7 6 5 4 3 2 1 0 9 8 7 6 5 4 3 2 1 .100 (2,54) TYP. .062 (1,57) MAXIMUM PANEL THICKNESS RECOMMENDED .098 (2,49) REF. TERMINAL PIN HEADER .100 (2,54) R. 4 PLS. .100 (2,54) TYP. .098 (2,49) REF. TERMINAL PIN HEADER .093 (2,36) DIA., 4 PLS. OR 2-56 X .250 (6,35) LONG STUD See page C-7 for code and truth tables, specifications, standard legends and ordering information. An ISO-9001 Company 561 Hillgrove Avenue • LaGrange, Illinois 60525 • USA • Phone: (708) 354-1040 • Fax: (708) 354-2820 • http://www.grayhill.com C-6 CONDUCTIVE RUBBER KEYPADS CODE AND TRUTH TABLES Dots in the chart indicate connected terminals when switch is closed. Terminals are identified on the keyboard. 12 Button Keypads Matrix • • • • • • • • • • • • • • • • • • 4x4 Single Pole/Common Bus • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• BUTTON LOCATION BUTTON LOCATION 3x4 1 2 3 4 5 6 7 8 9 10 11 12 16 Button Keypads CODES 5 6 7 1 2 3 4 5 9 13 4 8 12 3 7 11 2 6 10 1 TERMINAL LOCATION 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 CODES Single Pole/Common Bus Matrix • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • 5 6 7 8 1 2 3 4 • • • • • • • • • • • • • • • • • • • • • • • • • • • • • •• 4 9 13 17 3 7 12 16 2 6 10 15 1 5 11 14 8 TERMINAL LOCATION SPECIFICATIONS ORDERING INFORMATION Rating Criteria Rating at 12 Vdc: 5 milliamps for .5 seconds Contact Bounce: < 12 milliseconds Contact Resistance: < 100 ohms (@ stated operating force) Voltage Breakdown: 250 Vac between components Mechanical Operation Life: 3,000,000 operations per key Insulation Resistance: > 1012 ohms @ 500 Vdc Push Out Force Per Pin: 5 lbs. Operating Features Travel: .040 minimum Operating Force: 175 ± 40 grams Operating Temperature: -30°C to +80°C Material and Finishes Terminal Pin: Phosphor bronze, solder plated PC Board: FR-4 glass cloth epoxy Keypad: Silicone rubber, durometer 50 ± 5 Housing: ABS, cycolac “KJW” Housing Color: Black Grayhill Series Number Size Option A=3x4 B=4x4 Circuitry B2=Matrix (terminal pin header) C2=Single Pole/Common Bus 96AB2-102-F Mounting Option F=Front panel mount R=Rear panel mount Standard Legend Choices 12 Position legends 102=Black legends on a white button 152=White legends on a black button 16 Position legends 006=Black legends on a white button 056=White legends on a black button Available from your local Grayhill Distributor For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. STANDARD LEGENDS 12 Position -102 Legend: Black legends on white button -152 Legend: White legends on black button 16 Position -006 Legend: Black legends on white button -056 Legend: White legends on black button See page C-4 for Standard Legend configurations. C-7 An ISO-9001 Company 561 Hillgrove Avenue • LaGrange, Illinois 60525 • USA • Phone: (708) 354-1040 • Fax: (708) 354-2820 • http://www.grayhill.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Parallax: 27944
27944 价格&库存
很抱歉,暂时无法提供与“27944”相匹配的价格&库存,您可以联系我们找货
  • 1+232.984981+30.28103
