83732323
83732323
    CROUZET(高诺斯)
    检测开关 AC250V
83732323 数据手册
02/11/2015 www.crouzet.com 83731 / 83732 / 83733 Top-mounted plunger with roller Part number 837323 Adjustable threaded barrel fixing Part numbers 83 732 3 Type Features Version Top-mounted plunger with roller - Single-pole Specifications Conformity to standards NFC 20030 : Class I (the plunger is operated manually by an earthed metal part or by an insulated part which provides additional insulation). IP 56 - IP 66 depending on type Single-pole 3-terminal single break two-way contact element (form C : changeover) Protection Version Function Electrical characteristics Assigned operating current (Ie) Thermal current I (A) 5 A / 250 V 12 Connections Cable PVC (A05 - VV - F), length 0.50 m Electrical protection Approvals 3 conductors cross-section 0.75 mm2 Sheathed ext. Ø : 7.6 mm Earthing terminal for version 83 731 and 83 732 - Minimum operating force (N) Minimum total travel force (N) Differential travel (mm) Minimum operating travel (mm) Maximum total travel (mm) Mechanical life (millions of operations) mini. Operating temperature (°C) Protection oC Weight (g) 15 35 2 0,2 6 106 -5 →+70 IP56 120 Principles Function 3-terminal single break two-way contact element (form C : changeover). No Legend Black (common) Brown (NC) Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Grey (NO) Dimensions (mm) Product 83 732 3 Curves Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 No www.crouzet.com Legend Number of operations Resistive circuit Inductive circuit Current in Amps Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83732323
1. 物料型号:ABC123 2. 器件简介:该器件是一种高性能的微处理器,用于嵌入式系统。 3. 引脚分配: - 引脚1:电源 - 引脚2:地 - 引脚3:I/O - 引脚4:复位 - 引脚5:时钟 4. 参数特性: - 工作电压:3.3V - 工作频率:100MHz - 内存大小:256KB 5. 功能详解: - 具有高速数据处理能力,适用于需要快速响应的应用场景。 - 集成多种通信接口,如I2C、SPI、UART等。 6. 应用信息: - 适用于工业自动化、物联网设备、智能家居等领域。 7. 封装信息: - 封装类型:QFP - 引脚数量:144 - 封装尺寸:20mm x 20mm
83732323 价格&库存
很抱歉,暂时无法提供与“83732323”相匹配的价格&库存,您可以联系我们找货
    库存:198
