83870102
83870102
    CROUZET(高诺斯)
    检测开关 DC125V AC120V
83870102 数据手册
02/11/2015 www.crouzet.com 83870 with cable output Metal plunger Part number 83870102 IP 66/67 Metal case cUL approval Part numbers 83 870 102 Type Characteristics Type of output Metal plunger Standard Cable length 2 m Specifications Conformity to standards Protection against electric shocks Degree of protection IEC 60529 Degree of protection according to NEMA 250 IEC / EN 60947.5.1 Dimensional conformity : NFC 63145 Low voltage directive : 73/23/EEC and 93/68/EEC Electric shock protection : NFC 20030 ou IEC 60536 class 1, degree of pollution 3 Type 1, 3, 4, 6, 13 Electrical characteristics Connection Operating temperature (°C) Assigned impulse voltage (Uimp) - V Assigned insulation voltage Ui (V) Thermal current I (A) Low-load switching - Minimum voltage (V) Low-load switching - Minimum current (mA) Assigned working characteristics (EN 60 947.5.1, UL 508) Electrical life according to IEC 947-5-1 appendix C Electrical protection Approvals -25 →+70 °C 2500 500 10 10 100 A300 = AC15 240 V 3 A / 120 V 6 A Alternating current Q150 = DC13 125 V 0.55 A Direct current 250 V 3 A AC15 500,000 operations 24 V 8 W DC13 500,000 operations Integral protective earth conductor Short-circuit protection device : IEC/EN 60947-5-1 Fuse 6 AgG UL 508, UL 50 Mechanical characteristics Sequence Snap action Minimum operating force (N) Minimum operating force (Nm) Minimum total travel force (N) Minimum total travel force (Nm) Min. positive opening travel (N) Min. positive opening travel (Nm) Mechanical life (millions of operations) Vertical approach speed Horizontal approach speed (30° cam) 10 30 28 10 1 mm/min →0,5 m/s - Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Weight (g) 170 Principles Function Four-terminal double break two-way contact element (form Zb) with positive opening NC contacts. The 2 moving contacts are electrically isolated from one another. No Legend Brown Black Blue Green-yellow Dimensions (mm) Product 83 870 1 83 870 0 No Legend POP marking See sequence diagram Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Rear output on request Ø 8 x 4.3 - 4 counterbores Other information For other accessories and special contacts, or special modes of operation : please consult us. Product adaptations Contact type Rear output Protective scraper seal Length of cable/connector/stripping Special marking Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83870102 价格&库存
很抱歉,暂时无法提供与“83870102”相匹配的价格&库存,您可以联系我们找货
