83589031
    CROUZET(高诺斯)
    SWITCH SNAP ACTION SPDT 8A 250V
83589031 数据手册
11/03/2013 www.crouzet.com 83589 Top-mounted plunger Part number 83589031 Press button protected by O-ring and scraper seal Part numbers Type 83 589 031 Top-mounted plunger Housing Features Thermoplastic Standard Specifications Conformity to standards Version Protection NFC 20030 class I (the plunger is operated manually by an earthed metal part, or by an insulated part which provides additional insulation). Single-pole IP66 resistant to hydrocarbons and saline mist (400 hours) Electrical characteristics Electrical endurance Standard : 8 A 250 VAC : 30,000 operations 200 mA 24 V DC relay load L / R = 3 ms 107 operations Dual-current : 1 mA 4 VAC : 107 operations Dual-current 200 mA 24 V DC relay load L / R = 3 ms 5 x 106 operations 5 A 250 VAC : 30,000 operations This version is designed to operate both on dual-current (1 mA 4 V minimum) and medium-current (5A) circuits. However, a given product should only be used to switch one type of circuit during its working life. Connections Cable Mounting PVC Ø5 - 3 x 0.75 mm2 Length 0.50 m Conforming to NFR 13414/13415 Max. tightening torque 9 Nm Mechanical characteristics Minimum operating force (N) Minimum total travel force (N) Minimum operating travel (mm) Differential travel (mm) Maximum total travel (mm) Mechanical life (millions of operations) mini. Operating temperature (°C) Protection rating Weight (g) 10 15 2 0,1 4,5 107 -40 →+85 IP66/67 80 Additional characteristics Material - Case : Thermoplastic polyester - Plunger : Stainless steel - Contact : Agcdo - AgNi (gold-plated) - Nuts : Galvanized steel Sealing - O-ring : Silicon - Scraper seal : Teflon PU resin Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 11/03/2013 www.crouzet.com Principles Function Single break two-way contact element (form C : changeover) No Legend Black (common) Grey (NC) Blue (NO) Dimensions (mm) Product Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 11/03/2013 No www.crouzet.com Legend Operating travel Total travel Cable Ø5 - 3 x 0.75 mm2 Length 0.50 m 21 across flats Direction of operation Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected
83589031 价格&库存
很抱歉,暂时无法提供与“83589031”相匹配的价格&库存,您可以联系我们找货
库存:13
83589031
    • 1+691.18051
    • 5+616.05219
    库存:13
    83589031
    • 1+455.042951+54.63550
    • 5+432.455505+51.92350
    库存:13
