83731310
    CROUZET(高诺斯)
    LMTSW 2.0M THRDED BRL PSHBTN
83731310 数据手册
Automotive Limit Switches Series 83 731 / 83 732 / 83 733 Conform to the following standards : IEC 356.1 - EN 60204.1 NFC 20030 : Class I - 83 731 - 83 732 Class III - 83 733 Degree of protection : IP 56 - IP 66 depending on type Version : 1 pole Function : 3-terminal single break twoway contact element (form C: inverter). Principle : Electrical characteristics : 83 731 3 Control mechanisms Top-mounted plunger Top-mounted plunger with roller Mechanical characteristics Minimum operating N (oz.) force Minimum total travel N (oz.) force Minimum operating travel mm (in.) 83 732 3 83 733 3 ● ● ● 15 (53) 15 (53) 6 (21.2) 35 (123.4) 35 (123.4) 25 (88.2) 2 (.079) 2 (.079) 1.5 (.059) Differential travel Max. total travel mm (in.) 0.2 (.008) 0.2 (.008) 0.2 (.008) mm (in.) 6 (.236) 6 (.236) 4 (.157) Mechanical life Temperature limits Degree of protection Weight Operations °C (°F) °C (°F) g (oz.) 106 - 5 + 70 IP 66 110 (3.9) 106 - 5 + 70 IP 66 110 (3.9) 106 - 5 + 70 IP 56 70 (2.5) Dimensions Assigned operating current (Ie) 83 731 - 83 732 : 5 A 250 V 83 733 : 5 A 50 V Thermal rating (Ith) : 12 A 1 Types 83 731 3 mm 83 732 3 83 733 3 Operating curve : Operations Resistive circuit Inductive circuit L = 5 ms R a cos ϕ = 0.8 c { A Connections : PVC cable (A05 - VV - F) 0.50 m long 3 conductors cross-section 0.75 mm2 Sheathed, ext. Ø : 7.6 mm Core connections : 1 : black (common) 2 : brown (NC) 4 : blue (NO) Electrical protection : Earthing terminal for version 83 731 and 83 732. Approvals : CSA A300. Other information For other versions, functions and special contacts or special modes of operation : please consult us. To order, specify : 1/2 meter cable 83731316 83732323  83733315 Standard products, non stocked 1 meter cable 83731319 83732315 83733314 1 2 meter cable 83731310 83732327 83733310 Type Example : Limit switch - 83 731 319
83731310
物料型号:83 731、83 732、83 733
器件简介:限位开关,具有1极3端单断点双向接触元件(C型:反相器)。
引脚分配:1号端子黑色(公共端),2号端子棕色(常闭NC),4号端子蓝色(常开NO)。
参数特性: - 操作力:83 731和83 732为15N(53oz),83 733为6N(21.2oz)。 - 总行程力:83 731和83 732为35N(123.4oz),83 733为25N(88.2oz)。 - 操作行程:83 731和83 732为2mm(.079in),83 733为1.5mm(.059in)。 - 机械寿命:10^10次操作。
功能详解:限位开关具有不同的控制机制,包括顶部安装的柱塞和带滚轮的柱塞。
应用信息:适用于需要限位检测的汽车应用。
封装信息:IP66防护等级(83 731和83 732),IP56防护等级(83 733)。重量和尺寸信息也提供。
电气特性:额定操作电流为5A,83 731和83 732适用于250V,83 733适用于50V。热额定电流为12A。
连接信息:PVC电缆,0.5米长,3芯,截面积0.75mm²,外部直径7.6mm。
电气保护:83 731和83 732版本有接地端子。
认证:CSA A300。
订购信息:提供不同长度电缆的选项,例如2米或1米。
83731310 价格&库存
很抱歉,暂时无法提供与“83731310”相匹配的价格&库存,您可以联系我们找货
库存:17
