| | www.crouzet-switches.com
|| 1
| | microswitches
| | 05/2016
Microswitches - Sealed, Positive break
PBX - 8324
› Double-break snap-action mechanism with electrically separated circuits (form Zb)
› Positive opening action according to IEC 60947-5-1 Annex K
› Long overtravel, also after the positive opening position
› Protection of mechanism: IP67/IP65, or IP40 with sealed plunger
› Operating temperature -50 °C to +85 °C
› Ratings from 1 mA 4 Vc to 6 A 250 Va - Rating codes: A300, Q150
› Very long mechanical life
› Choice of connections - Mounting plates and roller lever (pre-assembled or
retrofittable)
› cURus and CCC approved - Meet applicable railway standards
Main specifications
Standard
83240
Degree of protection
Connections
IP40
IP40
IP40
IP40
IP40
IP67
IP67
IP67
IP67
IP 67
Electrical characteristics
W3
W3/90B
W5
W5/IP20
W1
W3
W3/90B
W5
W5/IP20
W1
83240000
83240010
83240020
83240030
Rating nominal / 250 Va (A)
Rating nominal / 250 Vc (A)
Rating Thermal (A)
Mechanical characteristics
Maximum operating force (N)
Minimum release force (N)
Minimum positive opening force (N)
Maximum rest position (mm)
Operating position (mm)
Positive opening position (mm)
Maximum total travel position (mm)
Differential travel (mm)
Operating temperature (°C)
Mechanical life - IP40 versions (operations)
Mechanical life - IP67 versions (operations)
Contact gap (mm)
Weight (g)
High force
83242
83242000
83242010
83242020
83242030
Dual-current
83244
Dual-current
High force
83245
83244000
83245000
83244020
83244030
83245020
83245030
83240200
83240210
83240220
83240230
83242200
83245200
83242220
83242230
83244200
83244210
83244220
83244230
83245220
83245230
6
0.6
10
6
0.6
10
6*
0.6*
10
6*
0.6*
10
4.5
0.6
28
8.9
6.6 ±0.25
4.4
3.4
1 ±0.3
-50 ➞ +85
107
4x106
2x1
22
6.5
2.5
28
8.9
6.6 ±0.25
4.4
3.4
1±0.3
-50 ➞ +85
107
4 x 106
2x1
22
4.5
0.6
28
8.9
6.6 ±0.25
4.4
3.4
1 ±0.3
-50 ➞ +85
107
4 x 106
2x1
22
6.5
2.5
28
8.9
6.6 ±0.25
4.4
3.4
1 ±0.3
-50 ➞ +85
107
4 x 106
2x1
22
Additional characteristics
- Case: PC GF (UL 94-V2 / GWFI 960 °C / GWIT 775 °C)
- Button: PBT GF (UL 94-V0 / GWFI 960 °C)
- Membrane: silicone rubber
- Contacts: silver alloy, micro-profile
gold alloy on silver alloy, micro-profile (dual-current)
- Terminals: brass (silver-plated brass : on request)
- Screws: stainless steel
- Levers: stainless steel, polyamide roller
- Degree of protection: IP65/IP67 or IP40 (mechanism)
- Recommended min actuating speed: 0.5 mm/s
- Rated insulation voltage Ui: 400 V
- Impulse withstand voltage Uimp: 4 kV
- Pollution degree: 3
- Protection against electric shock: Button and actuators of IP67 versions have
reinforced insulation
- Dimensional conformity: DIN 41636 F
- Fire/smoke resistance: EN 45545, NFF 16101/102-I3F1
- Approvals: cURus (A300, Q150), CCC
Product adaptations
› IP67 wire lead or cable outputs, EN 50306 halogen-free versions
› Special connections: W3 QC tabs with specific folding angles, double QC tabs, W5 without screws, …
› Special levers: special shapes and lengths
› AgPd contacts for infrequent switching in corrosive atmospheres up to 1A (83241/83243)
› Maintained action variant (bistable reset switch), with plunger or lever
› Two-pole DPDT assemblies with common lever
› IP40 protective cover/housing on connections
Standard product
Product made to order
Contact us
|| 2
| | microswitches
| | 05/2016
Principles
Double break snap-action switch with electrically separated circuits and with positive opening action on NC contacts (21-22)
Changeover - SPDT (form Zb)
13
14
21
22
Both circuits can be used at opposite polarities
Curves
Operating curve for category AC15 Operating curve for category DC13
1
1
7
7
10
10
5
5
24/48 V~
2
6
10
6
125 V~
5
48 V
5
250 V~
2
24 V
2
10
2
125 V *
5
5
10
10
0,1
0,5 1
2
2
5 10
1
Number of operations
2
Current in Amps
0,05 0,1
0,5 1
2
5
2
For IP67 versions used in 125 V DC, please consult us.
* Models 83244 and 83245 are designed to operate equally well on low-current (1 mA 4 V minimum recommended) or medium to high current circuits.
However, a given product should only be used to switch one type of circuit during its working life.
Dimensions (mm)
Product
30 Max
4.6
3.5 ±0.1
1
12 0/-0.4
3.8 min / 5.1max
2.2
4.1± 0,05
Positions
8324
28 ± 0,15
50 Max
42 ± 0,15
2
1 Fixing screw threaded length
2 Fixing nuts 2 x M3
Max. tightening torque of fixing screws: 1.3 N.m on ∅ 4.1 holes
0.9 N.m on M3 nuts
|| 3
| | microswitches
| | 05/2016
Connections
W3 quick-connect 6.3 x 0.8
W3/90B quick-connect 6.3x0.8, 90° downward
folding
W5 screw with clamp
W1 screw with washer
62 max
21.6
12.56
73 max
23.8
23.8
90
16
17
4 x M3 screws - PZ1 type
34.6 Max
W5/IP20 screw with clamp and IP20
protection
58.6 Max
Mounting accessories
67
58
67
58
10 ± 0,1
PE mounting plates with notches
10 ± 0,1
PT mounting plates with holes
± 0,1
3.5
± 0,1
3.5
Thickness: 1 mm
Thickness: 1 mm
Actuators
LG roller lever
8 x 6.8 mm
Mechanical characteristics on roller
R 25
±0.2
11.4
12.1
0.2
Positions
2.55 ±0.35
Min. positive opening force (N)
83240/83244
83242/83245
3
0.3
19
21
16,6±0,5
13,2
12
1,8±0,55
4
1.3
19
21
16,6±0,5
13,2
12
1,8±0,55
13.6
17
48 max
|| 4
| | microswitches
| | 05/2016
Actuators and mounting accessories
PBX 8324 with referenced accessories
Roller lever
Mounting plates
Accessory kit
83240
IP40
IP67
83242
IP40
IP67
83244
IP40
IP67
W3
W3/90B
W5
W5/IP20
W3
W3/90B
W5
W5/IP20
W3
W3/90B
W5
W5/IP20
W3
W3/90B
W5
W5/IP20
W3
W3/90B
W5
W5/IP20
W3
W3/90B
W5
W5/IP20
LG
79552456
83240003
83240013
83240023
83240033
83240203
83240213
83240223
83242003
83242023
83242223
83244003
83244013
83244023
83244203
83244213
83244223
LG
PT
79552457
83240004
83240014
83240024
83240034
83240224
83242004
83242014
83242024
83242224
83244004
83244014
83244024
83244034
LG
PE
79552458
83240005
83240015
83240225
83242005
PT
79552459
83240221
83242011
PE
79552460
Installation recommendations
See “Basic technical concepts”
How to order
Use the 8 digit part numbers when they are defined
Other cases, precise: Type of microswitch - Degree of protection - Connection - Actuator* - Mounting accessories* - Adaptation*
* if needed
Example: 83240 IP67 W3/90B LG PE
Examples of special adaptations
Two-pole DPDT assembly with
linked levers
Short roller lever
Mixed connections: NO quickconnect 6.3 x 0.8 / NC screw
with clamp
Economic version (839930):
SPDT form Za without positive
opening, Ø 3.2 mounting holes
on top face, screw terminals
Standard product
Contact us
Mixed connections: NO screw
with clamp / NC quick-connect
6.3 x 0.8, 90°downward folding
很抱歉,暂时无法提供与“83240000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+415.1854810+53.75410
