Miniature Limit Switches Series 83 800
Type
Degree of protection : IP 55 or IP 65 - Nema 4, 12, 13
Plug in version
Version : SPDT - double break
Function : Four terminal double break contact element (form Za). The
contacts must be of the same polarity.
Layout :
A - For 83 803
B - Other types
Electrical characteristics :
Assigned insulation voltage (Ui): 250 V
Current Rating
Assigned working currents (Ie): 5 A
Features
Top mounted plunger
Top mounted plunger with threaded barrel
Top mounted roller plunger with threaded barrel
Side rotary head - momentary
Flexible metal spring
Fiberglass Rod
Mechanical Characteristics
Operating force
Total travel force - min.
Operating Travel - min
Movement differential
Total travel - max
Mechanical life
Operating temp.
Weight
N (oz)
N (oz)
mm (in)
mm (in)
mm (in)
operation
C˚ (F˚)
grams (oz)
Operating curve :
Accessories for 83 803 - Sold separately
Resistive circuit
Inductive circuit
* Lever settings or positions dictated by direction in which block is fitted
L = 5 ms
R
cos ϕ = 0.8
Adjustable in 6° steps
Adjustable in 90° steps
107
5
2
106
5
2
105
5
Dimensions
Axis of head rotation
2
104
0.1 0.2 0.5 1 2
5 10 16
25.5 (1)
25 (.98)
19 (.75)
Ø8
(.315)
21.5
(.85)
11
(.43)
Connections :
- Plug in :
- Non Plug in :
Connection :
For N° 9 sealing gland, 15.2 dia., 1.411 pitch
-25356113 - metal
-25356109 - plastic
13
(.51)
2x04.2
(.08x.17)
60.5 (2.38)
Screw terminals - max. wire section 2.5 mm2
Solder tags (able to accept 2.8 x 0.5 mm clips).
Contact Crouzet for part # and availability
22 (.87)
27 (1.06)
Approvals: UL cUL
mm(in)
Other information
For other accessories and special contacts, or special modes of operation, please contact factory.
Low temperature version available.
Products and specifications subject to change without notice.
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
3/44
1
83800151
83801051
83802051
83803051
83805051
83806051
83807051
10 (35.3)
22 (77.6)
1.5 (.06)
0.4 (.016)
5 (.2)
107
-10 to 70 (-14 to 158)
IP 55
50 (1.8)
10 (35.3)
22 (77.6)
1.5 (.06)
0.4 (.016)
5 (.2)
107
-20 to 70 (- 4 to 158)
IP 55
57 (2)
7 NcM 10 in.oz.
18 NcM 25 in.oz.
15˚
6˚
60˚
107
IP 55
60 (2.1)
10 (35.3)
22 (77.6)
1.5 (.06)
0.4 (.016)
5 (.2)
107
IP 55
57 (2)
10 (35.3)
22 (77.6)
1.5 (.06)
0.6 (.24)
5 (.2)
107
IP 65
50 (1.8)
1.2 (4.23)
2.5 (8.8)
8˚
2˚
10˚
107
-10 to 70 (14 to 158)
IP65
50 (2.65)
.8 (2.8)
2 (7.05)
8˚
2˚
10˚
107
IP65
60 (2.1)
2
Galvanized, passivated steel roller arm. Thermoplastic roller.
Lever supplied with nut, washer and locating block (loose).*
79 210 997
79 210 998
Bent roller lever R: 1 1/8
(30mm)
Straight roller lever R:11/8”
(30mm)
79 215 332
Adjustable
1 3/16” ➞ 2 7/8”
(28 ➞ 72mm)
3
Dimensions
26.3
(1.04)
83 807
(08)
mm(in)
4
(113)
R30
(1.18)
17/8"
(50)
83 807
83 806
11/16"
12.3
(.48)
(Ø15)
7 "
8
83 806
11/2"
(26.3)
(Ø11x3.4)
Ø 7/ 16"x 1/8"
(163)
(36.3)
83 805
7 "
8
15/16"
(37.5)
11/2"
79 215 332
36.3 (1.42)
50.3 (1.98)
(33)
(22)
7maxi
(.28)
42 (1.65)
79 210 998
56 (2.2)
Ø20x6
(.79x.24)
83 803
M16x1
(28 ➞ 72)
79 210 997
Ø 5/16"
2.75" max. (7 max.)
(42)
15/8"
(23)
1"
32.3 (1.27)
(Ø8)
Ø11x3.4
(.43x.13)
M5x5
83 802
M16x1
(22.5)
83 801
Ø15
(.59)
Ø8
(.315)
13/16" ➞ 27/8
83 800
To order, specify:
Standard products
1
Part number
Example: 83 800 151
Standard products,
non stocked
1
Part number
2
Accessory
Example: 83 803 0 - Actuator 79 210 997
3/45
很抱歉,暂时无法提供与“83806051”相匹配的价格&库存,您可以联系我们找货
