■ Rolling blind
■ Electrical distribution
■ PCB applications
M i c ro sw i t ch e s
subminiature
V4D
Microswitches subminiature V4D
Crouzet
Presentation
■ Adaptation
p. 3
■ Customisation is our business
p. 4
■ V4D Advantages
p. 5
■ Ordering information
p. 5
■ Basic technical principles
p. 5
■ Main specifications
p. 6
■ Additional specifications
p. 6
■ Principle
p. 7
■ Dimensions
p. 7
■ Product adaptations
p. 7
■ Connections
p. 8
■ Actuators
p. 8
2
To suit your design requirements, Crouzet continues to develop its
capabilities as a specialist in customisation, offering you solutions
specifically adapted to all your applications. Because our top most
priority is nothing be left to chance, our quality and environmental
management systems are certified to ISO 9001 and ISO 14001.
About Custom Sensors & Technologies
■ Mechanical characteristics
with actuators
Crouzet has been a recognised supplier of quality position sensors,
micro-switches and limit switches for more than 30 years. Today,
Crouzet offers you a new range of micro-switches designed to fulfill
the toughest of OEMs’ requirements.
p.10
■ Mounting-Operation
p.10
■ Selection guide
p.11
Headquartered in Moorpark, CA - Custom Sensors &
Technologies (CST) is comprised of industry-leading
brands including Crouzet, Kavlico, Crydom, and
former divisions of BEI Technologies – Newall and Systron Donner
CST provides sensors, controls, and actuation products for the
Transportation, Industrial and Aerospace & Defense markets.
Crouzet
Adaptation
To meet the growing demand for
customisation, Crouzet’s expertise
in terms of adapting products and
their corresponding accessories is
available to all customers.
■ All our expertise in sensing design ■ A complete range of standard
and industrialisation placed at your
microswitches available immediately
service, to respond to a specific
to create your sensing application.
need dedicated to your application.
Crouzet can customise its products
for use in any type of environment
or application to ensure perfect
integration into any equipment.
Because quality is at the heart of our
approach, our quality control and our
environmental management system
ISO 14001 respectively.
Specific
products
Standard
components
Custom
products
Components
with added value
■ Defined in coordination with our
technical sales teams, these custom
products have the corresponding
performance and functionality.
■ Standard products complemented
by factory-mounted auxiliaries
or accessories (levers, cables,
connectors, etc) in order to assist
integration in your equipment,
simplify your logistics and maximise
the reliability of your installation.
Crouzet
Process
■ Customer needs
■ R&D department
■ Production
■ Quality
3
Crouzet
■ Control devices
Even more adaptation for
easier actuating
4
■ Connections
AConnections
complete electrical
function
Special button shapes
which compensate for any faults or
positioning drift of the control actuator.
Special connectors, customised
wiring, customer bundles,
dedicated terminals…
■ Seals
■ Special levers
Even more solutions for
demanding environments
Obtain the control data
Numerous components available
to provide effective protection for your
contacts, including caps, boot seals,
membranes, sealing resin, wiper seals.
Angled, curved, extended or
retractable... these special lever
types can be used to extend the
control device for easier adjustment,
increase the operating force, resist
high actuation torque or provide
totally safe electrical isolation.
■ Special contacts
■ Special fixings
The right contact
for every environment
No effort is spared to make
mounting easier
High or low current, AC or DC, type of
load (inductive or resistive), industrial
or corrosive atmosphere, occasional or
intensive use. The best metals, silver,
silver nickel, silver palladium, goldplated silver, solid gold.
Snap-on fixing, screw-fixing, crimping
or pins are just a few examples of the
numerous solutions available to meet
all your requirements.
V4D Advantages
■ Wide range of switching ratings from 0.1 A to 12 A
■ V4 standard size
■ Approved to ENEC (EN 61058-1) and UL/CSA
■ Compliant to RoHS
■ Glow wire test withstanding to EN 60335-1: GWFI 850°C
and GWIT 775°C
■ Various applications areas: Industry, Consumer equipment,
Home appliances, HVAC, …
■ A high capacity to adapt levers, connections,
fixing elements, upon request
Ordering Information
Model Number Legend
8
3
2
7
X
X
X
X
1
2
3
4
■ 1 - Ratings /
Operating force max
■ 2 - Functions
■ 3 - Connections
■ 4 - Actuators
0: 10 A / 1.5 N
0: Changeover
0: W2 solder
1: Plunger
1: 12 A / 1.5 N
6: Normally closed
1: W7A5 for 2.8 x 0.5mm clips
2: Flat lever 270A R16.8
2: 5 A / 1.5 N
8: Normally open
2: X1A straight for PCB
3: Flat lever 270A R22.5
4: 5 A / 0.5 N
3: X1S symetrical straight for PCB
4: Flat lever 270A R41
8: 0.05 A / 1.5 N
4: X2A rear side for PCB
5: Flat lever 270A R60
9: 0.05 A / 0.5 N
6: X3A front side for PCB
6: Dummy roller 270F R18
8: W7S symetrical for 2.8 x 0.5mm clips
7: Roller lever 270E R18.5
8: Roller lever 270E R24.1
9: Mushroom-head button
■ See our Position Sensors Catalogue
5
Nominal ratings from 0.1 A to 12 A
Operating temperature up to + 150°C
Approved to ENEC and UL/CSA
Large choice of actuators
Main specifications
83270
83271
83272
83274
R (normally closed)
Connections
W2 - W7A5 - W7S - X1A
X1S- X2A - X3A
W2 - W7A5
C (normally open)
W2 - W7A5
Function
I (changeover)
Electrical characteristics
Rating nominal / 250 V AC (A)
Rating thermal / 250 V AC (A)
Rating nominal / 5 ➞ 24 V AC/DC (A)
10
12
12
15
5
6
5
6
Maximum operating force (N)
1.5
1.5
1.5
0.5
Min. Release force (N)
0.3
0.3
0.3
0.1
Maximum total travel force (N)
2
2
2
1
Max. permitted overtravel force (N)
10
10
10
10
Maximum rest position (mm)
9.2*
9.2*
9.2*
9.2*
Tripping point (mm)
8.4±0.3 **
8.4±0.3 **
8.4±0.3 **
8.4±0.3 **
Maximum differential travel (mm)
0.15
0.15
0.15
0.15
Min. overtravel (mm)
0.5
0.5
0.5
0.5
Ambient operating temperature (°C)
-20 ➞ +85
-20 ➞ +85
-20 ➞ +125
-20 ➞ +125
Mechanical life for 2/3 OT (operations)
500 000
500 000
500 000
1 000 000
Contact gap (mm)
0.4
0.4
0.4
0.4
Weight (g)
2
2
2
2
10 (2) A
250 V AC
12 (6) A
250 V AC
# 5 (1) A
250 V AC
# 5 (1) A
250 V AC
10 000
10.1 A 1/4 HP
125.250 V AC
6 000
10 000
12 A 125.250 V AC
(contact us)
6 000
50 000
5 A 125.250 V AC
1/4 HP 250 V AC
6 000
50 000
5 A 125.250 V AC
1/4 HP 250 V AC
6 000
Approvals
EN 61058-1
UL 1054
Rating for T 85° C
# T 125° C
## T 150° C
Number of cycles
Rating
Number of cycles
Comments
* 10.8 for mushroom head button
** 9.9 ± 0.3 for mushroom head button
Component Materials
6
Housing/cover/button: polyester UL 94V0-GWIT 775°C / GWFI 850°C
Contacts: silver alloy or gold plated
Terminals : silver-plated brass
Actuators: stainless steel, glass filled polyamide roller
Principle
Single break changeover switch
83278
Dimensions (mm)
83279
1.5
0.5
0.3
0.1
2
1
10
10
9.2**
9.2**
8.4±0.3 ***
8.4±0.3 ***
0.15
0.15
0.5
0.5
-20 ➞ +150
-20 ➞ +150
500 000
1 000 000
0.4
0.4
2
2
19.8 ± 0.2
R0.95
3.3 ± 0.1
0.001 ➞ 0.05
Ø 5.5
R3.6 Spherical
7.5 ± 0.2
1.9 ± 0.1
5.0 ± 0.1
Ø 2.2 ± 0.1
1
2.2 ± 0.1
1
4
2
2.4 ± 0.1
0.001 ➞ 0.05
Asymetrical version
0.3 ± 0.1
7.2 ± 0.1
6.4 ± 0.2
3.4 ± 0.1
Ø 2.5 ± 0.1
2
0.5 ± 0.03
3.05 ± 0.1
8.9 ± 0.1
1
2
4
2
Total Travel Position =9.1 Max.
3.3 ± 0.1
± 0.1
9.5
12.2 ± 0.1
## 0.1 (0.04) A
250 V AC
## 0.1 (0.04) A
250 V AC
50 000
0.1 A 125 V AC
50 000
0.1 A 125 V AC
6 000
6 000
1
Total Travel Position =7.6 Max.
Symetrical version
1
4
2
7.62 ± 0.2 7.62 ± 0.2
Product adaptations
Special levers
Special connections
Specific fixing
High operating temperature
2.35 mm diameter fixing holes
7
Connections
W7A5 / W7S
X1A / X1S
30 ° +5
-0 °
7.9 - 00.15
Ø 1.2 +- 0.1
1.6 ± 0.15
10.8 +- 00.1
1.3 +0.1
-0
4.3 ± 0.2
6.0 ± 0.15
W2
0.6 +- 00.15
2.4 +- 0.15
4.1 - 0.15
3.5 ± 0.2
5.0 ± 0.2
1.0 ± 0.1
2.8 ± 0.1
1.3 ± 0.05
2.8 ± 0.1
1.0 ± 0.1
1.3 ± 0.05
X3A / X3S
5.0 ± 0.2
X2A / X2S
1.3 ± 0.05
3.5 ± 0.2
3.6 -+0.2
-0
Actuators
➜ Levers
270 A
270 F
270 E
R2.5
R
0.3x4
R
0.3x4
Actuator mounting position
6.1
4.3
8
Ø 4.8x3
R
3
Mechanical characteristics with actuators
Lever 270A
R16.8
Lever 270A
R22.5
Lever 270A
R41
Lever 270A
R60
Length of
actuator
(mm)
Maximum
operating
force (N)
Minimum
release force
(N)
Tripping
point (mm)
Minimum
overtravel
(mm)
Maximum
differential
travel (mm)
Maximum
total travel
(mm)
83270
16.8
0.5
0.09
9.7±1.4
0.8
0.6
5.5
83271
16.8
0.5
0.09
9.7±1.4
0.8
0.6
5.5
83272
16.8
0.5
0.09
9.7±1.4
0.8
0.6
5.5
83274
16.8
0.16
0.03
10±1.4
1.1
0.5
5.5
83278
16.8
0.5
0.09
9.7±1.4
0.8
0.6
5.5
83279
16.8
0.16
0.03
10±1.4
1.1
0.5
5.5
83270
22.5
0.35
0.06
10.1±1.7
1.2
1.1
7
83271
22.5
0.35
0.06
10.1±1.7
1.2
1.1
7
83272
22.5
0.35
0.06
10.1±1.7
1.2
1.1
7
83274
22.5
0.12
0.02
10.6±1.7
1.7
0.7
7
83278
22.5
0.35
0.06
10.1±1.7
1.2
1.1
7
83279
22.5
0.12
0.02
10.6±1.7
1.7
0.7
7
83270
41
0.20
0.03
11.1±3
3.1
2.1
15
83271
41
0.20
0.03
11.1±3
3.1
2.1
15
83272
41
0.20
0.03
11.1±3
3.1
2.1
15
83274
41
0.07
0.01
12.4±3
4.4
1.4
15
83278
41
0.20
0.03
11.1±3
3.1
2.1
15
83279
41
0.07
0.01
12.4±3
4.4
1.4
15
83270
60
0.13
0.02
11.6±5
3.6
3.5
23
83271
60
0.13
0.02
11.6±5
3.6
3.5
23
83272
60
0.13
0.02
11.6±5
3.6
3.5
23
83274
60
0.05
0.01
14±5
6
2.3
23
83278
60
0.13
0.02
11.6±5
3.6
3.5
23
83279
60
0.05
0.01
14±5
6
2.3
23
9
Lever 270F
R18
Lever 270E
R18.5
Lever 270E
R24.1
Length of
actuator
(mm)
Maximum
operating
force (N)
Minimum
release force
(N)
Tripping
point (mm)
Minimum
overtravel
(mm)
Maximum
differential
travel (mm)
Maximum
total travel
(mm)
83270
18
0.45
0.08
12.6±1.5
0.8
0.7
6
83271
18
0.45
0.08
12.6±1.5
0.8
0.7
6
83272
18
0.45
0.08
12.6±1.5
0.8
0.7
6
83274
18
0.15
0.03
12.9±1.5
1.1
0.6
6
83278
18
0.45
0.08
12.6±1.5
0.8
0.7
6
83279
18
0.15
0.03
12.9±1.5
1.1
0.6
6
83270
18.5
0.45
0.08
15.2±1.4
0.9
0.7
6
83271
18.5
0.45
0.08
15.2±1.4
0.9
0.7
6
83272
18.5
0.45
0.08
15.2±1.4
0.9
0.7
6
83274
18.5
0.15
0.03
15.5±1.4
1.2
0.6
6
83278
18.5
0.45
0.08
15.2±1.4
0.9
0.7
6
83279
18.5
0.15
0.03
15.5±1.4
1.2
0.6
6
83270
24.1
0.35
0.06
15.7±1.8
1.3
1.2
8
83271
24.1
0.35
0.06
15.7±1.8
1.3
1.2
8
83272
24.1
0.35
0.06
15.7±1.8
1.3
1.2
8
83274
24.1
0.12
0.02
16.2±1.8
1.8
0.8
8
83278
24.1
0.35
0.06
15.7±1.8
1.3
1.2
8
83279
24.1
0.12
0.02
16.2±1.8
1.8
0.8
8
Mounting - Operation
To conform to the leakage paths and air gaps required in the standard EN/IEC 61058-1 - EN/IEC 60947-5-1:
■ An insulation pad must be inserted between the microswitch and the fixing surface
if the fixing surface is metal.
■ Manual operation of a metal actuator must only be carried out with the help of
a secondary actuator made of insulating material.
The installer must ensure adequate protection against direct contact with the output terminals.
10
Selection guide
Rating / Force
Type
Actuators
Plunger
Lever 270A
R16.8
10 A / 1.5 N
12 A / 1.5 N
5 A / 1.5 N
5 A / 0.5 N
0.05 A / 1.5 N
0.05 A / 0.5 N
83270
83271
83272
83274
83278
83279
Function
Connection
I
W2
83270001
83271001
83272001
83274001
83278001
83279001
I
W7A5
83270011
83271011
83272011
83274011
83278011
83279011
I
X1A
83270021
83271021
83272021
83274021
83278021
83279021
I
X1S
83270031
83271031
83272031
83274031
83278031
83279031
I
X2A
83270041
83271041
83272041
83274041
83278041
83279041
I
X3A
83270061
83271061
83272061
83274061
83278061
83279061
I
W7S
83270081
83271081
83272081
83274081
83278081
83279081
R
W2
83270601
83271601
83272601
83274601
83278601
83279601
R
W7A5
83270611
83271611
83272611
83274611
83278611
83279611
C
W2
83270801
83271801
83272801
83274801
83278801
83279801
C
W7A5
83270811
83271811
83272811
83274811
83278811
83279811
I
W2
83270002
83271002
83272002
83274002
83278002
83279002
I
W7A5
83270012
83271012
83272012
83274012
83278012
83279012
I
X1A
83270022
83271022
83272022
83274022
83278022
83279022
I
X1S
83270032
83271032
83272032
83274032
83278032
83279032
I
X2A
83270042
83271042
83272042
83274042
83278042
83279042
I
X3A
83270062
83271062
83272062
83274062
83278062
83279062
I
W7S
83270082
83271082
83272082
83274082
83278082
83279082
R
W2
83270602
83271602
83272602
83274602
83278602
83279602
R
W7A5
83270612
83271612
83272612
83274612
83278612
83279612
C
W2
83270802
83271802
83272802
83274802
83278802
83279802
C
W7A5
83270812
83271812
83272812
83274812
83278812
83279812
Function
Connection
I
Changeover
W2
solder
R
Normally closed
W7A5
for 2.8 mm clips
C
Normally open
W7S
symetrical for 2.8 x 0.5 mm clips
X1A
straight for PCB
X1S
X2A
rear side for PCB
X3A
front side for PCB
11
Rating / Force
Type
Actuators
Lever 270A
R22.5
Lever 270A
R41
12
10 A / 1.5 N
12 A / 1.5 N
5 A / 1.5 N
5 A / 0.5 N
0.05 A / 1.5 N
0.05 A / 0.5 N
83270
83271
83272
83274
83278
83279
Function
Connection
I
W2
83270003
83271003
83272003
83274003
83278003
83279003
I
W7A5
83270013
83271013
83272013
83274013
83278013
83279013
I
X1A
83270023
83271023
83272023
83274023
83278023
83279023
I
X1S
83270033
83271033
83272033
83274033
83278033
83279033
I
X2A
83270043
83271043
83272043
83274043
83278043
83279043
I
X3A
83270063
83271063
83272063
83274063
83278063
83279063
I
W7S
83270083
83271083
83272083
83274083
83278083
83279083
R
W2
83270603
83271603
83272603
83274603
83278603
83279603
R
W7A5
83270613
83271613
83272613
83274613
83278613
83279613
C
W2
83270803
83271803
83272803
83274803
83278803
83279803
C
W7A5
83270813
83271813
83272813
83274813
83278813
83279813
I
W2
83270004
83271004
83272004
83274004
83278004
83279004
I
W7A5
83270014
83271014
83272014
83274014
83278014
83279014
I
X1A
83270024
83271024
83272024
83274024
83278024
83279024
I
X1S
83270034
83271034
83272034
83274034
83278034
83279034
I
X2A
83270044
83271044
83272044
83274044
83278044
83279044
I
X3A
83270064
83271064
83272064
83274064
83278064
83279064
I
W7S
83270084
83271084
83272084
83274084
83278084
83279084
R
W2
83270604
83271604
83272604
83274604
83278604
83279604
R
W7A5
83270614
83271614
83272614
83274614
83278614
83279614
C
W2
83270804
83271804
83272804
83274804
83278804
83279804
C
W7A5
83270814
83271814
83272814
83274814
83278814
83279814
Function
Connection
I
Changeover
W2
solder
R
Normally closed
W7A5
for 2.8 mm clips
C
Normally open
W7S
X1A
straight for PCB
X1S
X2A
rear side for PCB
X3A
front side for PCB
Rating / Force
Type
Actuators
Lever 270A
R60
Lever 270F
R18
10 A / 1.5 N
12 A / 1.5 N
5 A / 1.5 N
5 A / 0.5 N
0.05 A / 1.5 N
0.05 A / 0.5 N
83270
83271
83272
83274
83278
83279
Function
Connection
I
W2
83270005
83271005
83272005
83274005
83278005
83279005
I
W7A5
83270015
83271015
83272015
83274015
83278015
83279015
I
X1A
83270025
83271025
83272025
83274025
83278025
83279025
I
X1S
83270035
83271035
83272035
83274035
83278035
83279035
I
X2A
83270045
83271045
83272045
83274045
83278045
83279045
I
X3A
83270065
83271065
83272065
83274065
83278065
83279065
I
W7S
83270085
83271085
83272085
83274085
83278085
83279085
R
W2
83270605
83271605
83272605
83274605
83278605
83279605
R
W7A5
83270615
83271615
83272615
83274615
83278615
83279615
C
W2
83270805
83271805
83272805
83274805
83278805
83279805
C
W7A5
83270815
83271815
83272815
83274815
83278815
83279815
I
W2
83270006
83271006
83272006
83274006
83278006
83279006
I
W7A5
83270016
83271016
83272016
83274016
83278016
83279016
I
X1A
83270026
83271026
83272026
83274026
83278026
83279026
I
X1S
83270036
83271036
83272036
83274036
83278036
83279036
I
X2A
83270046
83271046
83272046
83274046
83278046
83279046
I
X3A
83270066
83271066
83272066
83274066
83278066
83279066
I
W7S
83270086
83271086
83272086
83274086
83278086
83279086
R
W2
83270606
83271606
83272606
83274606
83278606
83279606
R
W7A5
83270616
83271616
83272616
83274616
83278616
83279616
C
W2
83270806
83271806
83272806
83274806
83278806
83279806
C
W7A5
83270816
83271816
83272816
83274816
83278816
83279816
Function
Connection
I
Changeover
W2
solder
R
Normally closed
W7A5
for 2.8 mm clips
C
Normally open
W7S
X1A
straight for PCB
X1S
X2A
rear side for PCB
X3A
front side for PCB
13
Rating / Force
Type
Actuators
Lever 270E
R18.5
Lever 270E
R24.1
14
10 A / 1.5 N
12 A / 1.5 N
5 A / 1.5 N
5 A / 0.5 N
0.05 A / 1.5 N
0.05 A / 0.5 N
83270
83271
83272
83274
83278
83279
Function
Connection
I
W2
83270007
83271007
83272007
83274007
83278007
83279007
I
W7A5
83270017
83271017
83272017
83274017
83278017
83279017
I
X1A
83270027
83271027
83272027
83274027
83278027
83279027
I
X1S
83270037
83271037
83272037
83274037
83278037
83279037
I
X2A
83270047
83271047
83272047
83274047
83278047
83279047
I
X3A
83270067
83271067
83272067
83274067
83278067
83279067
I
W7S
83270087
83271087
83272087
83274087
83278087
83279087
R
W2
83270607
83271607
83272607
83274607
83278607
83279607
R
W7A5
83270617
83271617
83272617
83274617
83278617
83279617
C
W2
83270807
83271807
83272807
83274807
83278807
83279807
C
W7A5
83270817
83271817
83272817
83274817
83278817
83279817
I
W2
83270008
83271008
83272008
83274008
83278008
83279008
I
W7A5
83270018
83271018
83272018
83274018
83278018
83279018
I
X1A
83270028
83271028
83272028
83274028
83278028
83279028
I
X1S
83270038
83271038
83272038
83274038
83278038
83279038
I
X2A
83270048
83271048
83272048
83274048
83278048
83279048
I
X3A
83270068
83271068
83272068
83274068
83278068
83279068
I
W7S
83270088
83271088
83272088
83274088
83278088
83279088
R
W2
83270608
83271608
83272608
83274608
83278608
83279608
R
W7A5
83270618
83271618
83272618
83274618
83278618
83279618
C
W2
83270808
83271808
83272808
83274808
83278808
83279808
C
W7A5
83270818
83271818
83272818
83274818
83278818
83279818
Function
Connection
I
Changeover
W2
solder
R
Normally closed
W7A5
for 2.8 mm clips
C
Normally open
W7S
X1A
straight for PCB
X1S
X2A
rear side for PCB
X3A
front side for PCB
Rating / Force
Type
Actuators
Mushroom head button
10 A / 1.5 N
12 A / 1.5 N
5 A / 1.5 N
5 A / 0.5 N
0.05 A / 1.5 N
0.05 A / 0.5 N
83270
83271
83272
83274
83278
83279
Function
Connection
I
W2
83270009
83271009
83272009
83274009
83278009
83279009
I
W7A5
83270019
83271019
83272019
83274019
83278019
83279019
I
X1A
83270029
83271029
83272029
83274029
83278029
83279029
I
X1S
83270039
83271039
83272039
83274039
83278039
83279039
I
X2A
83270049
83271049
83272049
83274049
83278049
83279049
I
X3A
83270069
83271069
83272069
83274069
83278069
83279069
I
W7S
83270089
83271089
83272089
83274089
83278089
83279089
R
W2
83270609
83271609
83272609
83274609
83278609
83279609
R
W7A5
83270619
83271619
83272619
83274619
83278619
83279619
C
W2
83270809
83271809
83272809
83274809
83278809
83279809
C
W7A5
83270819
83271819
83272819
83274819
83278819
83279819
Function
Connection
I
Changeover
W2
solder
R
Normally closed
W7A5
for 2.8 mm clips
C
Normally open
W7S
X1A
straight for PCB
X1S
X2A
rear side for PCB
X3A
front side for PCB
15
AMERICA
BRAZIL
Custom Sensors &
Technologies
Crouzet Latinoamerica
Alameda Rio Negro
1084 - cj.A31
CEP 06454-000 - Alphaville SP BRASIL
Tel. : +55 (11) 4191 9797
Fax : +55 (11) 4191 9136
E-mail : info@cst-latinoamerica.com
www.crouzet.com.br
www.cst-latinoamerica.com
USA/CANADA/MEXICO
Custom Sensors &
Technologies - Crouzet
7230 Hollister Avenue
Goleta, CA, 93117
USA
Tel. : +1 (800) 677 5311
Fax : +1 (800) 677 3865
FRANCE
Crouzet Automatismes SAS
2 rue du Docteur Abel - BP 59
26902 Valence CEDEX 9
FRANCE
Tel. : +33 (0) 4 75 44 88 44
Fax : +33 (0) 4 75 55 98 03
E-mail : com-fr@crouzet.com
www.crouzet.fr
Customer service
0 825 333 351
0 810 610 102
GERMANY
Crouzet GmbH
Otto-Hahn-Str. 3, 40721 Hilden
Postfach 203, 40702 Hilden
DEUTSCHLAND
Tel. : +49 (0) 21 03 9 80-171
Fax : +49 (0) 21 03 9 80-222
E-mail : info-direkt@crouzet.com
www.crouzet.de
E-mail : customer.service@us.crouzet.com
www.crouzet.com
OTHER COUNTRIES
Custom Sensors &
Technologies
Alameda Rio Negro
1084 - cj.A31
www.crouzet.com.br
EUROPE
MIDDLE EAST
AFRICA
Headquartered in Moorpark, California-USA, Custom
Sensors & Technologies (CST) is made up of the leading
brands of Crouzet, Kavlico and Crydom, as well as the
former divisions of BEI Technologies, including Newall
and Systron Donner. CST provides sensors, controls,
and actuation products to the transportation, industrial,
and aerospace & defense markets.
www.cstsensors.com
AUSTRIA
Crouzet GmbH
Zweigniederlassung Österreich
Spengergasse 1/3
1050 Wien
ÖSTERREICH
Tel. : +43 (0) 1 36 85 471
Fax : +43 (0) 1 36 85 472
ITALY
Crouzet Componenti s.r.l.
Via Viganò De Vizzi, 93/95
20092 Cinisello Balsamo (Mi)
ITALIA
Tel. : +39 (02) 66 599 250
Fax : +39 (02) 66 599 258
E-mail : crz-it-sensori-micro@crouzet.com
www.crouzet.it
SPAIN/PORTUGAL
Crouzet Ibérica
C/ Aragón 224, 2° 2a
08011 Barcelona
ESPAÑA
Tel. : +34 (93) 484 39 70
Fax : +34 (93) 484 39 73
E-mail : es-consultas@crouzet.es
www.crouzet.es
THE NETHERLANDS
Crouzet BV
Industrieweg 17
2382 NR Zoeterwoude
NEDERLAND
Tel. : +31 (0) 71-581 20 30
Fax : +31 (0) 71-541 35 74
E-mail : com-nl@crouzet.com
www.crouzet.nl
www.crouzet.at
BELGIUM
Crouzet NV/SA
Dieweg 3 B
B - 1180 Uccle
BELGIUM
Tel. : +32 (0) 2 462 07 30
Fax : +32 (0) 2 461 00 23
E-mail : com-be@crouzet.com
www.crouzet.be
UNITED KINGDOM
Crouzet Ltd
8 Cedarwood
Chineham Business Park
Crockford Lane
Basingstoke, Hampshire
RG24 8WD
UNITED KINGDOM
Tel. : +44 (0)1256 318 900
Fax : +44 (0)1256 318 901
E-mail : info@crouzet.co.uk
www.crouzet.co.uk
Distributed by:
SWITZERLAND
Crouzet AG
Gewerbepark - Postfach 56
5506 Mägenwil
SCHWEIZ
Tel. : +41(0) 62 887 30 30
Fax : +41(0) 62 887 30 40
www.crouzet.ch
Creation-Design: 3C Evolution, Crouzet Automatismes
FRANCE
Editing-Publishing: 3C Evolution
www.crouzet.com
CRZ BR 43/A EN
Ref. 67231009 EN
11/2009
Photos-Graphics: Ginko, Daniel Lattard, Schneider Electric
Printing:
OTHER COUNTRIES
FRANCE
Tel. : +33 (0) 475 802 102
Fax : +33 (0) 475 448 126
E-mail : com-ex@crouzet.com
www.crouzet.com
ASIA
PACIFIC
CHINA & HONG KONG
Custom Sensors &
Technologies Asia
(Shanghai) Limited Crouzet
2 Floor, Innovation Building
No. 1009, Yi Shan Road
Shanghai 200233
CHINA
Tel. : +86 (21) 2401 7766
Fax : +86 (21) 6249 0701
E-mail : china@cstsensors.com
www.crouzet.cn
www.cstsensors.com
INDIA
Custom Sensors &
Prestige Meridian II
No. 30, 13th Floor,
Unit No: 1301 & 1302
Mahatma Gandhi Road
Bangalore 560 001
INDIA
Tel. : +91 (0) 80 4113 2204/05
Fax : +91 (0) 80 4113 2206
E-mail : crz_bangalore@crouzet.com
www.crouzet.co.in
www.cstsensors.com
TAIWAN
Custom Sensors &
3F, No. 39, Ji-Hu Road
Nei-Hu Dist. - Taipei 114
TAIWAN
Tel. : +886 (0)2 8751 6388
Fax : +886 (0)2 2657 8725
E-mail : taiwan@cstsensors.com
www.crouzet.tw
www.cstsensors.com
KOREA & JAPAN
Custom Sensors &
5F, Jeil Bldg.
94-46 Youngdeungpo-dong
7-ga Youngdeungpo-gu
Seoul 150-037
SOUTH KOREA
Tel. : +82 (0)2 2629 8312
Fax : +82 (0)2 2629 8310
E-mail : korea@cstsensors.com
www.crouzet.tw
www.cstsensors.com
SOUTH EAST ASIA
& PACIFIC
Custom Sensors &
TAIWAN
E-mail : eap@cstsensors.com
www.crouzet.tw
www.cstsensors.com
Warning:
The product information contained in this
catalogue is given purely as information
and does not constitute a representation,
warrantly or any form of contractual
commitment. CROUZET Automatismes and
its subsidiaries reserve the right to modify their
products without notice. It is imperative that
we should be consulted over any particular
use or application of our products and it is
the responsability of the buyer to establish,
particularly through all the appropriate tests,
that the product is suitable for the use or
application. Under no circumstances will
our warranty apply, nor shall we be held
responsible for any application (such as
any modification, addition, deletion, use in
conjunction with other electrical or electronic
components, circuits or assemblies, or any
other unsuitable material or substance) which
has not been expressly agreed by us prior to
the sale of our products.
