DG23-B3RA
DG23-B3RA
    ZF
    插件
    SWITCH SNAP ACTION SPDT 50MA 30V
DG23-B3RA 数据手册
snap switches DG sub-subminiature switch Technical specifications Contact configuration S.P.D.T. Contact gap 1 x 106 operation Electrical life (max. load) see table Ambient temperature – 25 °C to + 85 °C Materials Base PPS (UL 94V-0) Cover PBT (UL 94V-0) Actuator PBT (UL 94V-0) Auxiliary actuator Stainless steel Termials CuZn striped silver-plated Contacts DG 1/4 DG2 AgNi Features Auxiliary actuator options „„ Very small size (only 12.8 x 5.8 x 6.5 mm) Auxiliary actuator Type Max. operating force Max. pretravel (cN) (mm) Min. overtravel (mm) Differential travel max. (mm) Max. rest position (mm) Operating point (mm) Without auxiliary actuator DG 1,2 B DG 2,4 C 140 75 0,5 0,5 0,2 0,2 0,1 0,1 5,9 5,9 5,4 5,4 Auxiliary actuator straight „„ High mechanical operating life, depending on the model > 1.000.000 actuations DG 1,2 B DG 2,4 C 45 30 1,8 1,8 0,55 0,55 0,5 0,5 9,4 9,4 6,8 +0,8/-0,4 6,8 +0,8/-0,4 Auxiliary actuator roller DG 1,2 B DG 2,4 C 60 35 1,5 1,5 0,55 0,55 0,5 0,5 13,9 13,9 12,4 12,4 Electrical rating and operating life Preferred parts „„ Depending on the model, the breaking capacity ranges from small switching currents and voltages to low-voltage applications up to 3 A 125 V AC „„ Optionally available with or without auxiliary actuator „„ Use on circuit boards with connections to the left or right and standing Electrical rating according to UL Order code Operating life Nominal load UL mechanical Housing mark 3 A, 125 V AC 2 A, 30 V DC 6.000 1 x 106 DG 1 0,05 A, 30 V DC 6.000 1 x 106 DG 2 1 A, 125 V AC 1 A, 30 V DC 6.000 1 x 106 DG 4 AgNi, gal. Au Electrical rating Terminals Operating Operating force point (cN) (mm) Auxiliary actuator Max. pretravel (mm) Min. overtravel (mm) 0,2 0,2 0,5 0,5 Differential travel max. (mm) DG13-B1LA 3 A, 125 V AC; 2 A, 30 V DC PCB terminal straight Auxiliary actuator straight 45 6,8 +0,8 / – 0,4 1,8 0,55 0,5 DG13-B1RA 3 A, 125 V AC; 2 A, 30 V DC PCB terminal straight Auxiliary actuator roller 60 12,4 ± 0,5 0,55 0,5 1,5 DG13-B2LA 3 A, 125 V AC; 2 A, 30 V DC PCB terminal straight Auxiliary actuator straight 45 6,8 +0,8 / – 0,4 1,8 0,55 0,5 DG23-B1LA 0,05 A, 30 V DC PCB terminal straight Auxiliary actuator straight 45 6,8 +0,8 / – 0,4 1,8 0,55 0,5 DG23-B1RA 0,05 A, 30 V DC PCB terminal straight Auxiliary actuator roller 60 12,4 ± 0,5 0,55 0,5 1,5 DG23-B2LA 0,05 A, 30 V DC PCB terminal right Auxiliary actuator straight 45 6,8 +0,8 / – 0,4 1,8 0,55 0,5 DG23-B3LA 0,05 A, 30 V DC PCB terminal left Auxiliary actuator straight 45 6,8 +0,8 / – 0,4 1,5 0,55 0,5 Approvals Degree of protection (switch interior) IP40 For detailed information and the layout of the details described above, please do not hesitate to ask for our technical specifications and drawing. Dimensions in mm Terminals Solder terminal PCB terminal right PCB terminal left Drilling pattern Rest position 1,8 0,6 0,9 Operating point 3,1 Auxiliary actuator options 52 53
DG23-B3RA 价格&库存
很抱歉,暂时无法提供与“DG23-B3RA”相匹配的价格&库存,您可以联系我们找货
