2M1-DP1-T2-B4-M6RE
2M1-DP1-T2-B4-M6RE
    CARLING
    插件
    钮子开关 双刀双掷 5万次 直插 400mA 20V -30℃~+85℃
2M1-DP1-T2-B4-M6RE 数据手册
2M-Series Miniature Toggles Switches P ROD UC T W E BP A GE request sample, configure part The 2M family of miniature toggle switches is composed of three switch series; the 2M1-Series miniature toggle switch, the 2MS-Series sealed miniature toggle switch, and the 2M1H-Series premium sealed miniature toggle switch. These series all feature PC mounting and offer a variety of ratings, circuits, contact materials, terminal platings, toggle styles and lengths, and optional color caps. 1-2 Poles Typical Applications ∙ Instrumentation ∙ Telecommunications www.carlingtech.com ∙ Networking ∙ Medical Equipment 860.793.9281 .4-5 125, 250 Amps ∙ Military sales@carlingtech.com VAC 28 VDC Tech Specs 2M1H-Series 2MS-Series Premium Sealed Miniature Toggle Switch 2M1-Series Sealed Miniature Toggle Switch Electrical Miniature Toggle Switch Material Contact Rating refer to ordering scheme Electrical Life 50,000 make & break cycles @ full load Contact Resistance 10 mΩ max. initial @ 2-4 VDC 100mA for both silver & gold plated contacts Insulation Resistance 1000 MΩ min. Dielectric Strength 1500 Volts RMS @ sea level Case 2M1H-Series & 2M1-Series: Dially phthalate (DAP) (UL 94V-0) 2MS-Series: Glass filled nylon 6/6,flame retardant, heat stabilized (UL 94V-0) Toggle 2M1H-Series: Brass, black finish with o-ring seal 2MS-Series: Brass, chrome plated, internal o-ring sealed 2M1-Series: Brass, chrome plated Bushing 2M1H-Series: Brass, black finish with o-ring seal 2MS-Series: Glass filled nylon 6/6,flame retardant, heat stabilized (UL 94V-0) 2M1-Series: Brass, nickel plated Housing Stainless Steel Bracket 2MS-Series: Nylon (UL 94V-0) 2M1-Series: Stainless Steel Actuator Retainer 2MS-Series: Stainless Steel Switch Support Brass, tin plated Terminal Seal Epoxy Physical Operating Temperature -30°C to +85°C Index of Protection 2M1H-Series: IP67 2MS-Series: IP67 Solder Heat Resistance MIL-STD-202, Method 210 Actuator Travel 25° Ordering Scheme Sample Part Number Selection 2M1H - DP1 TJ - BK - M2 R 1 2 3 1. SERIES 5. TERMINATION 2. POLES / CIRCUIT M1 Solder Lug M2 PCB M3 Quick Connect 2M1H Premium Sealed Miniature Toggle Switch ( ) - momentary Position: 1 2 2-3, 5-6 Connected Terminals SP1 ON NONE SP2 ON NONE SP3 ON OFF SP4 (ON) OFF SP5 ON OFF DP1 ON NONE DP2 ON NONE DP3 ON OFF DP4 (ON) OFF DP5 ON OFF DP6 * ON ON DP7 * (ON) ON DP8 * ON ON *Center position connects 2-3, 5-4 3. ACTUATOR STYLE TJ .709” [18 mm] length 4. BUSHING TK BK .386” [9.80 mm] threaded, flat 2. 4 3 2-1, 5-4 ON (ON) ON (ON) (ON) ON (ON) ON (ON) (ON) ON (ON) (ON) .512” [13.00 mm] length 5 6 E 7 7 M51 M52 M53 M54 Wire Wrap, .750” [19.05mm] length Wire Wrap, .964” [24.48mm] length Wire Wrap, .425” [10.80mm] length Wire Wrap, 1.062” [25.97mm] length 6. CONTACTS / TERMINALS Contact Material Terminal Plating Rating Approvals gold over silver 5A 125VAC or 28VDC, , IP67 G silver 1 2A 250VAC 2,5 4,7 K gold tin 0.4VA max 20V max (AC/DC) IP67 P silver 1,6 tin 4,7 5A 125VAC or 28VDC, , IP67 2A 250VAC Q silver 1 silver 1 5A 125VAC or 28VDC, , IP67 2A 250VAC R gold 2 gold 3 0.4VA max 20V max (AC/DC) IP67 7. EPOXY SEAL E Epoxy Seal Notes: Switches supplied with (1) 2M1-HDW4 hex nut and (1) 3MNH-WCP-0872 O-Ring 1 Movable contact and terminal platings: silver over copper alloy 2 Movable contact and terminal platings: gold over nickel over copper alloy 3 Terminal platings: gold over nickel over copper alloy 4 Terminal platings: tin over copper alloy 5 Terminal contact platings: gold over nickel alloy 6 Terminal contact platings: silver over nickel alloy 7 Tin option not available with M1 & M3 terminations. Configure Complete Part Number > *Manufacturer reserves the right to change product specification without prior notice. Browse Standard Parts > Ordering Scheme Sample Part Number Selection 2MS - WSP 1 - T1 - B4 - M1 G E 1 2 3 4 1. SERIES M1 4 Solder Lug M2 PCB M3 Quick Connect M51 Wire Wrap, .750” [19.05mm] M52 Wire Wrap, .964” [24.48mm] M53 Wire Wrap, .425” [10.80mm] M54 Wire Wrap, 1.062” [25.97mm] M6 Right Angle, PC Thru-Hole M61 Right Angle, Snap-In M7 Vertical, Right Angle, PC Thru-Hole M71 Vertical, Right Angle, Snap-In VS2 Vertical, .461” [11.70mm] 2. POLES WSP Single pole - uses terminals 1, 2 & 3 WDP Double pole - uses terminals 1, 2, 3, 4, 5 & 6 W3P Three pole - uses terminals 1, 2, 3, 4, 5, 6, 7, 8 & 9 3. CIRCUIT 2 Connected Terminals NONE NONE OFF OFF OFF 4. ACTUATOR STYLE T1 Round Bat T2 Round Short Bat T9 Long Black Plastic .492” length 5. BUSHING B1 3 2-1, 5-4 ON (ON) ON (ON) (ON) Contact Material G silver 1 K gold 2 P silver 1 R gold 2 P1 Plastic Anti-Static .496” length P2 Plastic Anti-Static .299” length Selection 2 3 2M1 Miniature Toggle Switch 2. POLES Single pole - uses terminals 1, 2 & 3 Double pole - uses terminals 1, 2, 3, 4, 5 & 6 Three pole - uses terminals 1, 2, 3, 4, 5, 6, 7, 8 & 9 Four pole - uses terminals 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 & 12 E 2 3 Connected Terminals 2-1, 5-4, 8-7, 11-10 NONE ON NONE (ON) OFF ON OFF (ON) OFF (ON) ON ON ON (ON) ON (ON) *Available with DP and 4P switches only. Center position connects 2-3, 5-4, 8-9, 11-10 4. ACTUATOR STYLE T1 T2 T3 T4 TA T5 T6 3. Round Bat Round Short Bat Paddle Medium Paddle Locking Lever Long Paddle Flat (B1,B2,B5,BA,BB,BE) 0 Epoxy Seal Configure Complete Part Number > 4 5 without Epoxy Seal Browse Standard Parts > - M1 Q E 6 7 8 B1 Threaded Standard, keyway B9 Splashproof B2 Non-Threaded Standard, keyway B0 15/32” Threaded (Standard B3 Threaded Short, keyway for T7 & T8 actuator styles) B4 Non-Threaded Short, keyway BA Threaded for T6 B5 High Torque, 7.5mm, flat BA Threaded for T6 B6 High Torque, 8.0mm, keyway BB Non-Threaded for `T6 B7 Long threaded BE Threaded Hi Torque for T6 B8 Metric BL Threaded, Locking 6. TERMINATION 3. CIRCUIT ( ) - momentary Position: 1 2-3, 5-6, 8-9, 11-12 1 ON 2 ON 3 ON 4 (ON) 5 ON 6* ON 7* (ON) 8* ON Rating Approvals 5A 125VAC or 28VDC, , IP67 250VAC 0.4VA max 20V max (AC/DC) IP67 5A 125VAC or 28VDC, , IP67 250VAC 0.4VA max 20V max (AC/DC) IP67 5. BUSHING 1. SERIES SP DP 3P 4P VS21 Vertical, Snap-In, .460” [11.70mm] VS3 Vertical, .630” [16mm] VS31 Vertical, Snap-In, .630” [16mm] U2 Vertical, .551” [14mm] only 3PDT VS4 Vertical, .461” [11.70mm] VS41 Vertical, Snap-In, .461” [11.70mm] U4 Vertical, .551” [14mm] - only 3PDT VS5 Vertical, .630” [16mm] VS51 Vertical, Snap-In, .630” [16mm Terminal Plating gold over silver 2A tin 3, 4 tin 3, 4 2A gold 2 2M1 - SP 1 - T1 - B1 1 8 8. EPOXY SEAL Notes: B1 Bushing switches supplied with (2) 2M1-HDW2 nuts, (1) 2M1-HDW11 washer and (1) 2M1-HDWI5 locking ring. See page 76-77. 1 Movable contact & terminal platings: silver over copper alloy 2 Movable contact & terminal platings: gold over nickel over copper alloy 3 Terminal platings: tin over nickel over copper alloy 4 Tin option not available with M1 terminal Sample Part Number 7 7. CONTACTS / TERMINALS B4 Unthreaded, Short, Keyway, Flat Threaded, Keyway 6 6. TERMINATION 2MS Sealed Miniature Toggle Switch ( ) - momentary Position: 1 2-3, 5-6 1 ON 2 ON 3 ON 4 (ON) 5 ON 5 T7 Large Bat (B0 bushing) T8 X-Large Bat (B0 bushing) T9 Black Plastic T0 Rectangular TA Locking Lever TI Locking Lever TL Locking Lever Notes: B1 Bushing switches supplied with (2) 2M1-HDW2 nuts, (1) 2M1-HDW11 washer and (1) 2M1-HDWI5 locking ring. 1 Movable contact & terminal platings: silver over copper alloy 2 Movable contact & terminal platings: gold over nickel over copper alloy 3 Terminal platings: tin over nickel over copper alloy 4 Tin option not available with M1 terminal Movable contact & terminal platings: silver over copper alloy 5 Movable contact & terminal platings: gold over nickel over copper alloy 6 Terminal platings: tin over nickel over copper alloy 7 Tin option not available with M1 terminal M1 4 Solder Lug M2 PCB M3 Quick Connect M51 Wire Wrap, .750” [19.05mm] M52 Wire Wrap, .964” [24.48mm] M53 Wire Wrap, .425” [10.80mm] M54 Wire Wrap, 1.062” [25.97mm] M6 Right Angle, PC Thru-Hole M61 Right Angle, Snap-In M7 Vertical, Right Angle, PC Thru-Hole M71 Vertical, Right Angle, Snap-In VS2 Vertical, .461” [11.70mm] VS21 Vertical, Snap-In, .460” [11.70mm] VS3 Vertical, .630” [16mm] VS31 Vertical, Snap-In, .630” [16mm] U2 Vertical, .551” [14mm] only 3PDT VS4 Vertical, .461” [11.70mm] VS41 Vertical, Snap-In, .461” [11.70mm] U4 Vertical, .551” [14mm] - only 3PDT VS5 Vertical, .630” [16mm] VS51 Vertical, Snap-In, .630” [16mm] 7. CONTACTS / TERMINALS Contact Material Terminal Plating G silver 1 gold over silver K gold 2 tin 3, 4 P silver 1 tin 3, 4 Q silver 1 silver 1 2 R gold gold 2 Rating Approvals 5A 125VAC or 28VDC, , , IP67 2A 250VAC 0.4VA max 20V max (AC/DC) N/A 5A 125VAC or 28VDC, , , IP67 2A 250VAC 5A 125VAC or 28VDC, , , IP67 2A 250VAC 0.4VA max 20V max (AC/DC) N/A 8. EPOXY SEAL E Epoxy Seal 0 Configure Complete Part Number > without Epoxy Seal Browse Standard Parts > Ordering Scheme Accessories 2M-Series Accessories To order accessories assembled on a switch, specify the switch number followed by the accessory part number and the word “assembled”. Ex: 2M1-SP1-T1-B1-M1QE-T12 ASSEMBLED. To order accessories in bulk, specify the Series, followed by the accessory. Ex: 2M1-T12. See page 76 for dimensional specifications. Optional Toggle Cap Sample Part Number Selection 2M1 - TI 2 1 1. SERIES 2M1 2 Fits 2M1H, 2MS or 2M1 2. TOGGLE CAP SIZE T1 3 T2 10.6 mm 7.6 mm 3. CAP COLOR 1 2 3 5 6 7 White Black Red Yellow Green Blue Optional Dress and Knurled Nuts Sample Part Number 2M1 - HDW3 1 Selection 2 1. SERIES 2M1 Fits 2M1H, 2MS or 2M1 2. NUT HDW3 Dress nut for 1/4” bushing HDW5 Knurled nut for 15/32” bushing (2M1-Series only) Optional Rubber Seals Sample Part Number 2M1 - E1A 1 Selection 2 1. SERIES 2M1 Fits 2M1H, 2MS or 2M1 2. RUBBER BOOT SEAL E1A K1 YE1D YE1E 1/4 - 40” UNS bushing (Not available for B0 bushing option) Metric M6 bushing (B8 bushing only) 15/32 - 32” UNS bushing (TJ, TK and B0 bushings only) 15/32 - 32” UNS bushing 1/2 boot (T7, T8, TJ, TK and B0 bushings only) Sample Part Number 3MNH - WCP-0872 1 Selection 1. SERIES 3MNH Fits 3MNH or 2M1H 2. RUBBER O-RING WCP-0872 For 15/32 bushing option 4. 2 Dimensional Specs inches [millimeters] Single Pole Double Pole FLAT THD. .433 [11.00] .709 [18.00] .445 [11.30] .413 [10.50] .030 [0.75] .519 [13.18] .185 [4.70] Anti-rotational actuator 2 1 .331 [8.40] .030 [0.75] .185 [4.70] .116 [2.95] O-ring .563 [14.30] .102 [2.60] Anti-rotational actuator .205 [5.20]DIA Internal O-ring sealed 15/32-32UNS 3 .413 [10.50] .570 [14.48] Internal O-ring sealed .630 [16.00] .445 [11.30] .709 [18.00] FLAT THD. 6 3 5 2 4 1 15/32-32UNS O-ring Epoxy Seal Epoxy Seal .189 [4.80] .205 [5.20]DIA Actuator Options DIM "A" Bushing Options & Mounting .469 [11.90]DIA 15/32-32 UNS FLAT-CUT TJ .709 [18.00] TK .512 [13.00] BK DIM "A" .059 [1.50] .386 [9.80] .209 [5.30] Termination Options M1 Standard Solder Lug M2 PC Thru-Hole .080 [2.02] 047 [1.20] THK .030 [0.75] 5. .260 [6.60] .156 [3.95] .080 [2.03] M3 Quick Connect .050 [1.26] .260 [6.60] .062 [1.57] THK .030 [0.75] M5 Wire Wrap THK .030 [0.75] 'A' .050 [1.26] THK .030 [0.75] OPTION CODE DIM.'A' M5-1 .750 [19.05] M5-2 .964 [24.48] M5-3 .425 [10.80] M5-4 1.062 [26.97] Dimensional Specs inches [millimeters] Single Pole .299 .250 [7.60][6.35] .240 [6.10]DIA EPOXY SAEL .260 [6.60] .413 [10.50] .500 [12.70] .106 [2.70]DIA .050 [1.26] Double Pole EPOXY SEAL .299 .250 [7.60][6.35] .240 [6.10]DIA .413 [10.50] .449 [11.40] .030 [0.75] .500 [12.70] .185 [4.70] .106 [2.70]DIA .191 [4.84] Three Pole .240 [6.10]DIA .299 .250 [7.60][6.35] .472 [12.00] .050 [1.26] .190 [4.83] EPOXY SEAL .030 [0.75] .650 [16.50] 9 8 .185 [4.70] .106 [2.70]DIA 6 5 7 .191 [4.84] 3 2 4 .190 [4.83] 1 .500 [12.70] .050 [1.26] Actuator Options T1 118 [3.00] DIA 496 [12.60] T2 T9 with Plastic Cap 106 [2.70] DIA .067 [1.70] DIA 299 [7.60] .764 [19.40] P1 Plastic Toggle P2 Plastic Toggle 1 2 3 4 5 6 7 8 9 106 [2.70] DIA 118 [3.00] DIA 496 [12.60] .492 [12.50] NO. 299 [7.60] .630 [16.00] GLOSS PLASTIC CAP * Shown with B4 bushing. Subtract 0.75” (1.90mm) from actuator height for B1 bushing. 6. COLOR White Black(std.) Red Orange Yellow Green Blue Brown Gray Dimensional Specs inches [millimeters] Bushing Options B4 B1 1/4-40UNS .350 [8.90] .250 [6.35] Termination Options M1 Standard Solder Lug M2 PC Thru-Hole .078 [1.98] EPOXY SEAL EPOXY SEAL .144 [3.65] .191 [4.84] .050 [1.26] .047 [1.20] .080 [2.03] M3 Quick Connect M6 Single Pole .299 [7.60] .240 [6.10]DIA .663 [16.85] M6Double Pole .299 [7.60] .240 [6.10]DIA .663 [16.85] .106 [2.70]DIA .200 [5.08] M6 Three Pole .500 [12.70] .299 [7.60] .240 [6.10]DIA .030 [0.75] P.C.MOUNTING .185 [4.70] EPOXY SEAL .721 [18.30] .150 [3.81] .500 [12.70] .150 [3.81] P.C.MOUNTING .500 [12.70] .185 [4.70] .650 [16.50] .240 [6.10] .200 [5.08] .106 [2.70]DIA P.C.MOUNTING .260 [660] .030 [0.75] .150 [3.81] .500 [12.70] .250 [6.35] .050 [1.26] 7. .185 [4.70] EPOXY SEAL .663 [16.85] .500 [12.70] .030 [0.75] .150 [3.81] .299 [7.60] .500 [12.70] .073 [1.85] DIA .200 [5.08] EPOXY SEAL .565 [14.35] .106 [2.70]DIA M7 Single Pole .073 [1.85] DIA .500 [12.70] .200 [5.08] .320 [8.14] .200 [5.08] .425 [10.80] .185 [4.70] .050 [1.26] .050 [1.26] .964 [24.48] M5-3 .050 [1.26] .224 [5.70] .050 [1.26] M5-2 .185 [4.70] .260 [6.60] .500 [12.70] .750 [19.05] P.C.MOUNTING .500 [12.70] EPOXY SEAL DIM.'A' M5-1 M5-4 1.062 [26.97] THK .030 [0.75] .050 [1.26] .106 [2.70]DIA .200 [5.08] OPTION CODE .050 [1.26] THK .030 [0.75] .137 [3.47] .050 [1.26] EPOXY SEAL .260 [6.60] .062 [1.57] THK .030 [0.75] THK .030 [0.75] M5 Wire Wrap EPOXY SEAL .150 [3.81] .050 [1.26] .073 [1.85] DIA .200 [5.08] .500 [12.70] Dimensional Specs inches [millimeters] Termination Options M7 Double Pole P.C.MOUNTING EPOXY SEAL .299 [7.60] .240 [6.10]DIA .663 [16.85] .106 [2.70] DIA .200 [5.08] M7 Three Pole .500 [12.70] .150 [3.81] .073 [1.85] DIA .050 [1.26] .030 [0.75] .721 [18.30] P.C.MOUNTING .050 [1.26] .565 [14.35] .200 [5.08] P.C.MOUNTING .299 [7.60] .230 [5.85] EPOXY SEAL .050 [1.26] .125 [3.18] .020 [0.50] .185 [4.70] .321 [8.15] .030 [0.75] .125 [3.18] OPTION CODE DIM.'A' VS2 .461 [11.70] VS3 .630 [16.00] .620 [15.75] VS2-VS3 Double Pole .106 [2.70]DIA OPTION CODE DIM.'A' VS2 .461 [11.70] VS3 .630 [16.00] EPOXY SEAL .020 [0.50] .185 [4.70] .321 [8.15] .030 [0.75] .620 [15.75] U2-VS3 Three Pole .106 [2.70]DIA EPOXY SEAL .321 [8.15] .020 [0.50] .185 [4.70] .185 [4.70] .620 [15.75] .073 [1.85] DIA .190 [4.83] .125 [3.18] .230 [5.85] .125 [3.18] .073 [1.85] DIA P.C.MOUNTING .299 [7.60] .050 [1.26] .185 [4.70] .125 [3.18] .230 [5.85] .125 [3.18] .620 [15.75] P.C.MOUNTING .299 [7.60] .050 [1.26] .190 [4.83] .565 [14.35] .190 [4.83] .150 [3.81] VS2-VS3 Single Pole .106 [2.70]DIA .150 [3.81] .073 [1.85] DIA .050 [1.26] .106 [2.70]DIA .200 [5.08] .650 [16.50] .500 [12.70] .250 [6.35] .500 [12.70] .200 [5.08] .190 [4.83] EPOXY SEAL .299 [7.60] .240 [6.10]DIA 8. .150 [3.81] .500 [12.70] .250 [6.35] .050 [1.26] .190 [4.83] .449 [11.40] .030 [0.75] .030 [0.75] .620 [15.75] OPTION CODE DIM.'A' U2 .551 [14.00] VS3 .630 [16.00] .620 [15.75] .180 [4.83] .185 [4.70] .073 [1.85] DIA Dimensional Specs inches [millimeters] Termination Options VS4-VS5 Single Pole .106 [2.70]DIA P.C.MOUNTING .299 [7.60] .250 [6.35] .230 [5.85] OPTION CODE DIM.'A' VS4 .461 [11.70] VS5 .630 [16.00] EPOXY SEAL .050 [1.26] .020 [0.50] .250 [6.35] .185 [4.70] .362 [9.20] .030 [0.75] .750 [19.05] .073 [1.85] DIA VS4-VS5 Double Pole P.C.MOUNTING .106 [2.70]DIA .250 [6.35] .299 [7.60] .230 [5.85] EPOXY SEAL .050 [1.26] .030 [0.75] .020 [0.50] .250 [6.35] .362 [9.20] .185 [4.70] .750 [19.05] OPTION CODE DIM.'A' VS4 .461 [11.70] VS5 .630 [16.00] .106 [2.70]DIA .073 [1.85] DIA .190 [4.83] P.C.MOUNTING .299 [7.60] .250 [6.35] .230 [5.85] EPOXY SEAL .030 [0.75] .020 [0.50] .250 [6.35] .185 [4.70] .362 [9.20] OPTION CODE DIM.'A' U4 .551 [14.00] VS5 .630 [16.00] .750 [19.05] .750 [19.05] .190 [4.83] VS21, VS31 .063 [1.60] .110 [2.80] .050 [1.26] .043 [1.10] .050 [1.26] M71 .020 [0.50] VS41, VS51 .050 [1.26] .070 [1.78] .110 [2.80] .050 [1.26] .043 [1.10] .020 [0.50] * PC Mounting for M61, M71, VS21, VS31, VS41, VS51 refer to M6, M7, VS2, VS3, VS4, VS5 respectively. 9. .185 [4.70] .073 [1.85] DIA Snap-In Termination Options M61 .185 [4.70] .750 [19.05] U4-VS5 Three Pole .050 [1.26] .185 [4.70] .750 [19.05] Dimensional Specs inches [millimeters] Single Pole Double Pole KEYWAY THIS SIDE 409 [10.40] KEYWAY .347 .354 [9.00] [8.80] .030 [0.75] .185 [4.70] .500 [12.70] .156 [3.95] .260 [6.60] Three Pole .156 [3.95] .190 [4.83] 1/4-40UNS Four Pole KEYWAY THIS SIDE KEYWAY .118 [3.00]DIA .449 [11.40] 1/4-40UNS KEYWAY THIS SIDE .030 [0.75] .402 [10.20] .185 [4.70] .500 [12.70] .118 [3.00]DIA .354 [9.00] 409 [10.40] KEYWAY 409 [10.40] KEYWAY .354 [9.00] .476 [12.10] .030 [0.75] .185 [4.70] .500 [12.70] .118 [3.00]DIA .850 [21.60] .156 [3.95] .190 [4.83] 1/4-40UNS 1/4-40UNS Actuator Options for Panel Rear Mount T1 T2 .118 [3.00]DIA T3 .409 [10.40] T7 P7 Anti-Rotation T8 P8 Anti-Rotation .236 [6.00]DIA .236 [6.00]DIA .461 [11.70] 15/32-32UNS .843 [21.40] T9 Plastic NO. COLOR .067 [1.70] DIA .689 [17.50] .677 [17.20] .492 [12.50] 15/32-32UNS .443 [11.25] KEYWAY .443 [11.25] KEYWAY .130 [3.30]DIA T5 .650 [16.50] .559 [14.20] .213 [5.40] .130 [3.30]DIA T4 .134 [3.40]DIA .106 [2.70]DIA T6 KEYWAY THIS SIDE 1 White 2 Black(std.) 3 Red 4 Orange Yellow 5 Green 6 7 Blue Brown 8 9 Gray T0 .098 [2.50]DIA .417 [10.60] * T6 actuator is available with B1, B2, B5, B6, BA, BB & BE bushing. Actuator length shown for T1-T5,T9 and T10 is with B1 bushing. T7, P7, P8 does not require a bushing code. Locking Lever TA Locking Lever TI .614 [15.60] Locked .559 [14.20] Locked FOR SP-1,DP-1 3P-1,4P-1 ONLY .551 [14.00] Locked FOR SP-3,DP-3 3P-3,4P-3 ONLY FOR SP-1,DP-1 3P-1,4P-1 ONLY Locking Lever TL .547 [13.90] Locked .573 [14.56] Locked FOR SP-3,DP-3 3P-3,4P-3 ONLY .573 [14.56] Locked FOR SP-1,DP-1 3P-1,4P-1 ONLY FOR SP-3,DP-3 3P-3,4P-3ONLY Bushing Options B1 Threaded B2 Non-Threaded .039 [1.00] .024 [0.60] .240 [6.10] DIA 1/4-40UNS .039 [1.00] .026 [0.65] .244 [6.20]DIA B5 High Torque .280 [7.10] .244 [6.20]DIA .315 [8.00]DIA 1/4-40UNS 1/4-40UNS .354 [9.00] 10. B3 Threaded B4 Non-Threaded .295 [7.50] .224 [5.70] B6 High Torque 1/4-40UNS Mfg. OptionRelief or Imperf.Thd. .039 [1.00] .315 [8.00]DIA .039 [1.00] .315 [8.00] .028 [0.70] .244 [6.20]DIA Mfg. OptionRelief or Imperf. Thd. .039 [1.00] Dimensional Specs inches [millimeters] B7 Long B8 Metric .039 [1.00] .244 [6.20]DIA .315 [8.00]DIA 1/4-40UNS .232 [5.90]DIA M6P 0.75 THD Mfg. Option Relief or Imperf.Thd. .039 [1.00] .039 [1.00] .315 [8.00] .059 [1.50] .033 [0.85] .250 [6.35]DIA .022 [0.56] BB High Torque for T6 .315 [8.00] .059 [1.50] .240 [6.10] .059 [1.50] 15/32 INCH BUSHING .250 [6.35]DIA .150 [3.81]DIA .496 [11.91]DIA .065 [1.65] .110 [2.80]DIA .234 [5.95] .240 [6.10]DIA 1/4-40UNS Panel Mounting 1/4 INCH BUSHING .378 [9.60] ON-OFF-ON & ON-ON-ON model .240 [6.10] DIA .315 [8.00] .250 [6.35]DIA .059 [1.50] .028 [0.70] BB Non-Threaded for T6 .240 [6.10] DIA 1/4-40UNS .378 [9.60] ON-ON model 1/4-40UNS .059 [1.50] BA Threaded for T6 .059 [1.50] .221 [5.60] .295 [7.50] .354 [9.00] BL Locking Lever .465 [11.80]DIA SEALS .024 [0.60] .244 [5.70] .378 [9.60] B9 Splash-Proof .315 [8.00]DIA .031 [0.79] .496 [11.91]DIA .378 [9.60] Termination Options M1 Standard Solder Lug M2 PC Thru-Hole .156 [3.95] .080 [2.02] .080 [2.03] THK .030 [0.75] M3 Quick Connect .260 [6.60] .244 [6.20]DIA .051 [1.30] M6 Double Pole .264 .280 [6.70] [7.10] THK .030 [0.75] .200 [5.08] 11. .051 [1.30] .106 [2.70]DIA .500 [12.70] 1.062 [26.97] .185 [4.70] .500 [12.70] .185 [4.70] .200 [5.08] .030 [0.75] .150 [3.81] .425 [10.80] M5-4 P.C.MOUNTING .449 [11.40] .228 [5.80] .964 [24.48] M5-3 .073 [1.85]DIA .500 [12.70] .050 [1.26] .750 [19.05] M5-2 .200 [5.08] .185 [4.70] .264 .280 [6.70] [7.10] M5-1 .500 [12.70] .030 [0.75] .500 [12.70] .185 [4.70] DIM.'A' P.C.MOUNTING .500 [12.70] .050 [1.26] .260 [6.60] .106 [2.70]DIA .244 [6.20]DIA 050 [1.26] THK .030 [0.75] .134 [3.40] .200 [5.08] 'A' .062 [1.57] THK .030 [0.75] M6 Single Pole OPTION CODE .260 [6.60] .050 [1.26] .047 [1.20] M5 Wire Wrap .073 [1.85]DIA .150 [3.81] Dimensional Specs inches [millimeters] M6 Three Pole Termination Options .244 [6.20]DIA .264 .280 [6.70] [7.10] P.C.MOUNTING .500 [12.70] .050 [1.26] .565 [14.35] .652 [16.55] .326 [8.28] .051 [1.30] .200 [5.08] M7 Single Pole .073 [1.85] DIA .030 [0.75] .106 [2.70]DIA P.C.MOUNTING .260 [6.60] .030 [0.75] .264 .280 [6.70] [7.10] .051 [1.30] .106 [2.70]DIA .244 M7 Double Pole [6.20]DIA .500 [12.70] .150 [3.81] .264 .280 [6.70] [7.10] .030 [0.75] M7 Three Pole .050 [1.26] .500 [12.70] .264 .280 [6.70] [7.10] .244 [6.20]DIA .106 [2.70]DIA .051 [1.30] .073 [1.85] DIA P.C.MOUNTING .565 [14.35] .030 [0.75] P.C.MOUNTING .850 [21.60] .565 [14.35] .051 [1.30] .150 [3.81] .500 [12.70] .251 [6.38] .200 [5.08] .190 [4.83] .073 [1.85] DIA .190 [4.83] .150 [3.81] .264 .280 [6.70] [7.10] .150 [3.81] .200 [5.08] .050 [1.26] M7 Four Pole .244 [6.20]DIA .190 [4.83] .500 [12.70] .565 [14.35] .150 [3.81] .200 [5.08] .652 [16.55] .030 [0.75] .251 [6.38] .200 [5.08] .073 [1.85] DIA .500 [12.70] .190 [4.83] .150 [3.81] .150 [3.81] P.C.MOUNTING .449 [11.40] .500 [12.70] .106 [2.70]DIA .200 [5.08] .050 [1.26] .251 [6.38] .200 [5.08] .500 [12.70] .500 [12.70] .251 [6.38] .200 [5.08] .150 [3.81] .185 [4.70] .565 .150 [14.35] [3.81] .244 [6.20]DIA .051 [1.30] .185 [4.70] .200 [5.08] .565 [14.35] .106 [2.70]DIA .150 [3.81] .050 [1.26] .190 [4.83] .190 [4.83] .200 [5.08] .073 [1.85] DIA VS2-VS3 Single Pole .244 [6.20]DIA .264 [6.70] .280 [7.10] .185 [4.70] .050 [1.26] .125 [3.18] 12. .321 [8.15] .050 [1.26] .020 [0.50] .185 [4.70] .030 [0.75] .620 [15.75] P.C.MOUNTING OPTION CODE DIM.'A' VS2 .461 [11.70] VS3 .630 [16.00] .125 [3.18] .620 [15.75] .185 [4.70] .073 [1.85] DIA Dimensional Specs inches [millimeters] Termination Options VS2-VS3 Double Pole .106 [2.70]DIA .264 [6.70] .280 [7.10] .185 [4.70] .050 [1.26] .321 [8.15] .030 [0.75] .020 [0.50] .185 [4.70] .125 [3.18] P.C.MOUNTING OPTION CODE DIM.'A' VS2 .461 [11.70] VS3 .630 [16.00] .125 [3.18] .185 [4.70] .620 [15.75] .073 [1.85] DIA .190 [4.83] .620 [15.75] VS4-VS5 Single Pole .106 [2.70]DIA .264 [6.70] .280 [7.10] .185 [4.70] .050 [1.26] .020 [0.50] .050 [1.26] .250 [6.35] .185 [4.70] .362 [9.20] .030 [0.75] P.C.MOUNTING OPTION CODE DIM.'A' VS4 .461 [11.70] VS5 .250 [6.35] .630 [16.00] P.C.MOUNTING .264 [6.70] .280 [7.10] .185 [4.70] .050 [1.26] .362 [9.20] .030 [0.75] .020 [0.50] .185 [4.70] .250 [6.35] .073 [1.85] DIA .750 [19.05] VS4-VS5 Double Pole .106 [2.70]DIA .185 [4.70] .750 [19.05] OPTION CODE DIM.'A' VS4 .461 [11.70] VS5 .630 [16.00] .250 [6.35] .185 [4.70] .750 [19.05] .073 [1.85] DIA .190 [4.83] .750 [19.05] Snap-In Termination Options M61 (available with SP & DP) .051 [1.30] .020 [0.50] M71 (available with SP & DP) .051 [1.30] .020 [0.50] VS21, VS31 .050 [1.26] .110 [2.80] .043 [1.10] .020 [0.50] VS41, VS51 .050 [1.26] .110 [2.80] .043 [1.10] .020 [0.50] * PC Mounting for M61,M71,VS21,VS31,VS41,VS5 1 refer to M6,M7,VS2,VS3,VS4,VS5 respectively. 13. Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 14. © Carling Technologies, Inc. Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
2M1-DP1-T2-B4-M6RE
物料型号:2M系列,包括2M1系列、2MS系列和2M1H系列。
器件简介:2M系列微型拨动开关由三个开关系列组成,分别是2M1系列、2MS系列密封微型拨动开关和2M1H系列高级密封微型拨动开关。这些系列都采用PC安装方式,并提供多种额定值、电路、接触材料、端子镀层、切换杆样式和长度,以及可选的颜色帽。
引脚分配:文档中提到了不同的接线方式,例如M1 Solder Lug、M2 PCB、M3 Quick Connect和M5 Wire Wrap,具体接线长度和类型在文档中有详细说明。
参数特性: - 电气寿命:50,000次全负载开关周期。 - 接触电阻:最大10 mΩ,初始值,对于银和金镀接触,2-4 VDC 100mA。 - 绝缘电阻:最小1000 MΩ。 - 耐压:1500伏特RMS在海平面。
功能详解:开关具有不同的操作温度范围(-30°C至+85°C),保护等级(2MIH系列和2MS系列:IP67),焊接热抗性(MIL-STD-202, 方法210)和操作行程(25°)。
应用信息:典型应用包括仪器、电信、网络、医疗设备和军事领域。
封装信息:包括外壳材料(不锈钢)、支架材料(2MS系列:尼龙,2M1系列:不锈钢)、切换杆保持器(2MS系列:不锈钢)等。
订购方案:提供了详细的订购方案,包括系列、极/电路、操作器样式、衬套、端子/端子、接触/端子和环氧密封等选项的代码。
可选配件:包括可选的颜色帽、装饰螺母和六角螺母、可选的橡胶密封等。
2M1-DP1-T2-B4-M6RE 价格&库存
很抱歉,暂时无法提供与“2M1-DP1-T2-B4-M6RE”相匹配的价格&库存,您可以联系我们找货
2M1-DP1-T2-B4-M6RE
  • 1+73.010911+9.42427
  • 10+63.0495310+8.13845
  • 25+59.4518925+7.67407
  • 50+56.8638650+7.34000
  • 100+54.38623100+7.02019
  • 250+51.26864250+6.61777
  • 500+49.02509500+6.32817
  • 1000+46.875241000+6.05067
2M1-DP1-T2-B4-M6RE
    • 1+86.10840
    • 200+34.36560
    • 500+33.21000
