FT1G-2M-Z
FT1G-2M-Z
    NIDEC(尼得科)
    Toggle Switch SPDT Through Hole
FT1G-2M-Z 数据手册
FT ■ Terminal Pins : Kinked ■ Actuator Color : Yellow Washable Ultra-Miniature Toggle Switch RoHS Compliant ■Features ■ Specifications 1. Ultra-miniature toggle switch for high density mounting. 2. Washable. 3. Terminal pin pitch : 2.54 mm. 4. Independent detent mechanism ensures light operational feel. 5. Clip contact mechanism for long-term contact reliability. 6. Gold-plated contacts. Rating Max. 28VDC 0.4VA max. Min. 1μ A 20mVDC (1.5mA 200μ VAC) Initial contact resistance 100mΩ max. Dielectric strength 250VAC 1 minute Insulation resistance 500MΩ min. Electrical life 10,000 cycles at max. rating 50,000 cycles at min. rating (D,E type) 30,000 cycles at min. rating (F,G type) Operating temperature range Storage temperature range (250VDC) −40℃∼+85℃ −40℃∼+85℃ ■Part Numbering F  T  2  D  -  2  M - Z Series code Actuator shape Number of poles Code Type Fig. Number of poles T Toggle type 1 1 pole 2 2 poles Code Switching function D E F G Terminal style of「2」(Style:PC Terminal) (ON) :Momentary. Switching function ON ー ON ONーOFF ー ON ON ー (ON) (ON)ーOFFー(ON) Actuator shape Terminal style Code Actuator shape Fig. Terminal style 2 PC Straight 5 Right angle 4 Vertical mounting Terminal style of「4」(Style:V/M Terminal) M Standard Terminal style of「5」(Style:R/A Terminal) FT SPDT 4.5 φ4 Switching function Part number marking side 3 0.5 φ1.9 PC Straight (13.8) 5.4 1.6 3.8 (1) 2.54 30゚ 2.54 7 Part No. (2) (3) Key Way 0.5 MARKING 2.54 2.54 2.54 (1) Terminal numbers are not shown on the switch. DPDT 1.6 3.8 (13.8) 5.4 0.5 2.54 2.54 (1) (4) (2) (5) (3) (6) Part No.  FT2D-2M-Z ☆FT2E-2M-Z ★FT2F-2M-Z ★FT2G-2M-Z MARKING 2.54 2.54 Terminal numbers are not shown on the switch. (2) (3) (4) (5) (6) Connecting terminals 4.5 φ4 3.8 (11.8) 1.6 5.4 φ1.9 2.54 (2) 2.54 30゚ 7 (3) ON ON ON (ON) 2−3 5−6 − OFF − OFF ON ON (ON) (ON) 2−1 5−4 ON ON − OFF ON ON 2−1 − 2−3 ON ON 2−1 5−4 − OFF ON ON 2−3 5−6 − Connecting terminals (3) 2.54 (2) 2.54 0.5 5-φ1 (1) (13.85) 5.4 Key Way Switching function (3) (5) (2) (4) (1) Part No. 2.54 (6) 0.5 Part number marking side ☆FT2D-5M-Z ★FT2E-5M-Z 2.54 1.6 30゚ MARKING t=0.3 0.3 (2.45) 0.5 5.08 2.54 8-φ1 (3) (6) 2 .54 0.5 5.08 (2) (5) 2 .54 φ1.9 7 2−1 (Topview) PC hole Layouts 3.8 Terminal numbers are not shown on the switch. − 0.3 0.5 5.08 Terminal numbers are not shown on the switch. Right Angle Terminal  FT1D-5M-Z  FT1E-5M-Z MARKING t=0.3 4.5 φ4 Part No. (1) Key Way (2.45) 3.5 3 2−3 Switching function Part number marking side 5.08 DPDT ON ON (ON) (ON) (Topview) PC hole Layouts 0.5 Right Angle Terminal (1) 2.54 2.54 0.3 6-φ1 3.5 3 − OFF − OFF Switching function Part number marking side φ1.9 Key Way 0.5 SPDT Connecting terminals 3 30゚ 7 (3) ON ON ON (ON) (Topview) PC hole Layouts 4.5 φ4 PC Straight (2) 2.54 0.3 5-φ1  FT1D-2M-Z ☆FT1E-2M-Z ☆FT1F-2M-Z ★FT1G-2M-Z (1) (4) Connecting terminals − 0.3 2.54 (Topview) PC hole Layouts (ON) :Momentary. ☆:Semi-standard products. ★:Made to order products. FT SPDT Switching function キー溝 Key Way 5.6 4.5 Vertical mounting terminal 3.8 5.4 1.6 形名表示側 Part number marking side 0.5 Part No. ☆FT1D-4M-Z ★FT1E-4M-Z (2) (1) φ1.9 7 φ4 30゚ (3) 3 Connecting terminals 0.4 2.54 (2.5) 0.3 5.08 ON ON − OFF ON ON 2−3 − 2−1 ON ON 2−3 5−6 − OFF ON ON 2−1 5−4 0.5 2.54 2.54 2.54 2.54 5-φ1 0.3 5.08 (2) (3) 2.54 (1) Terminal numbers are not shown on the switch. (Topview) PC hole Layouts Switching function キー溝 Key Way DPDT 5.6 4.5 Vertical mounting terminal 3.8 1.6 5.4 形名表示側 Part number marking side φ1.9 30゚ 7 φ4 0.5 (6) (3) (5) (2) (4) (1) Part No.  FT2D-4M-Z ★FT2E-4M-Z 3 Connecting terminals 0.4 (2.5) 0.5 2.54 − 2.54 0.3 2.54 0.3 5.08 2.54 2.54 8-φ1 Terminal numbers are not shown on the switch. ■Soldering Specifications ⑴Manual Soldering Device:Soldering iron 380℃, Max.; 3 seconds, Max. ⑵Auto Soldering Device:Jet wave type or dip type 275℃, Max.; 6 seconds, Max. ・Pre-heating should be done at temperatures from 80 to 120℃ and within 120 sec. (1) (2) (3) (4) (5) (6) 2.54 2.54 5.08 (Topview) PC hole Layouts ■ Flux Cleaning ⑴Solvent : Fluorine or Alcohol type. ⑵Cleaning after soldering should be done after the PC board is exposed to room temperature (30℃ or below) for 1 to 2 hours. ⑶Do not use ultrasonic cleaning. [℃] 275 ■Packaging Specifications 100 pcs./pack 15 KU FU 231 ★:Made to order products. ☆:Semi-standard products. (ON) :Momentary. JI SO SO ⑶When soldering two or more terminals to a common land, use solder resist to separate them. Plastick Pack JI S 6 120 Pre-heating soldering FU 120 80 KU 196
FT1G-2M-Z 价格&库存
很抱歉,暂时无法提供与“FT1G-2M-Z”相匹配的价格&库存,您可以联系我们找货
