NOW PART OF
641-Series
Pushbutton Switches
PROD UC T WE BP A GE
request sample, configure part
The 641-Series represents the most compact offerings
of the Carling’s pushbutton switch line. These switches
are UL approved and meet ENEC spacing requirements.
Additionally, the new 3-pole switch affords the versatility
to control an extra function or indicator light.
1-3
Poles
2-5
Amps
125, 250
VAC
Typical Applications
∙ Music Equipment
∙ Test & Measurement
www.carlingtech.com
∙ Audio-Visual Equipment
∙ Appliances
860.793.9281
∙ Industrial Automation
sales@carlingtech.com
Tech Specs
Physical
Electrical
Rating
5A 125VAC, 2A 250VAC
Dielectric Strength
1500V RMS
Insulation Resistance
50 Megohms
Initial Contact Resistance
10 Milli Ohm max @ 4Vdc
Electrical Life
50,000 Cycles
Terminals
Solder Lug, Wire Leads
and PC
Environmental
2.
Vibration Sinusoidal
Mil STD 202G, Method 204D,
Test Condition A 0.06DA or 10G’s
10-500Hz
Shock
MIL-STD 2020G, Method 213B
Test Condition K, 30G’s
Handling Shock
1 Meter Drop onto Hard Surface,
all surfaces and planes
Thermal Shock
MIL-STD 2020G, Method 107G
Test Condition A -55 C to 85 C
Moisture Resistance
MIL-STD 2020G, Method 106F 10 25
C to 65 C Cycles 95% RH
Thermal Cycling
25 Cycles -40 C to 85 C
Operating Temperature
32°F to 185°F (0°C to +85°C)
Function Circuits
Three Pole Single Throw, TPST
Three Pole Double Throw, TPDT
Operation
Alternate Action, Push ON,
Push OFF
Button Travel
0.19 (4.83mm)
Actuation Force
3 to 5 LB, 1360 to 2268 g
Base
Polyester, PBT Glass Filled
Button
Brass, Nickel Plated
Bushing
Plunger
Top Plate
Stainless Steel
Actuator (Internal)
Nylon 6/6
Pin (Internal)1
Nylon 6/6
Driver
Cold Rolled Steel
Springs
Music Wire
Movable Contact
Copper
Terminals
Brass (tin plated)
Mounting
½” Dia. Hole, with and without
keyway, or with locking ring
Safety & Regulation
Agency
UL 61058, EN 61058 (3 Pole Version)
UL 1054 (1 & 2 Pole Version)
Materials
RoHS, REACH
*Manufacturer reserves the right to change product specification without prior notice.
Ordering Scheme
64111210
Sample
Part Number
1
Selection
1. SERIES
One Pole
2A 250VAC, 5A 125VAC
solder lug
PC term.
wire leads.
64111210
64111212
64111215
ON-OFF
64111220
64111222
64111225 ON-ON
Two Pole
Three Pole
solder lug
64112210
64112220
solder lug
64113210
64113220
PC term.
64112212
64112222
wire leads
64112215
64112225
PC term.
64113212
64113222
wire leads
64113215
64113225
Notes:
1
For 1 and 2 pole only. 3 Pole switches use brass Pin
Configure Complete Part Number >
Browse Standard Parts >
Dimensional Specs
inches [millimeters]
.396
[10.05]DIA
15/32-32UNS-2A
THREAD
.468
[11.90]
.378
[9.60]
1.783
[45.29]
.254
[6.45]
SOLDER LUG
WITH KEYWAY
3 POLE SHOWN WITH PC TERMINAL
.406
.406
.072 .038
[1.82]X [.965]
DP KEYWAY
15/32-32UNS-2A
THREAD
.562
.195
9/16HEX NUT
(FURN.
ASSEMBLED).
1.076
.500
[12.70]DIA
.125 DIA
[3.17]
WITH LOCKINGRING
.038
[.965]
DIA
MOUNTING HOLE
.072
.038
[1.82] X [.965]
DP KEYWAY
.216
.376
[9.55]
.378
15/32-32 UNS-2A
THREAD
WIRE LEAD
.062
[1.57]
.500[12.70]
.560
[14.22]
3 POLE SHOWN WITH SOLDER LUG
.160
[4.06]
TERMINAL TYPE
.500
[12.70] DIA
.670
[17.02]
.500
[12.70]
PC TERMINAL
9/16 HEX NUT
(1) REQ'D
.562
[14.27]
.562
6.000
[152.40]
.186
[4.72]DIA
.200
[5.08]
.072
[1.82] KEYWAY
X
.038
[.965] DP
.094
[2.38]
.093
[2.36] DIA
1 OR 2 POLE SHOWNWITHSOLDER LUG
9/16 HEX NUT
(FURN.
ASSEMBLED).
1.020
.195
.094
.160
.718
.718
NOTES:
1. KEYWAY TOWARD T3 AND 6 FOR
ONE AND TWO POLE SWITCHES
.800
1.121
.800
.272
2. KEYWAY TOWARD T4 FOR
THREE POLE SWITCHES.
[6.91]TYP
4 OUTSIDE
CORNER LOCATIONS
T1
.062
Ø [1.57]TYP
.276
.345
[7.01] TYP
4 OUTSIDE
CORNER LOCATIONS
T1[8.76]
.062
Ø [1.57] TYP
3.
.378
.254
1 AND 2 POLE PC TERMINAL
MOUNTING HOLES
.270
[6.86]
.270
[6.86]
.282 [7.16] TYP
2 MIDPOINT LOCATIONS
.296[4.37]TYP
3 POLE PC TERMINAL
.094
Authorized Sales Representatives and Distributors
Click on a region of the map below to find your local representatives and distributors
or visit www.carlingtech.com/findarep.
CANADA
EUROPE
USA
MIDDLE
EAST
MEXICO
AFRICA
ASIA-PACIFIC
OCEANIA
SOUTH
AMERICA
About Carling
Founded in 1920, Carling Technologies is a leading manufacturer of electrical and
electronic switches and assemblies, circuit breakers, electronic controls, power
distribution units, and multiplexed power distribution systems. With six ISO9001 and
IATF16949 registered manufacturing facilities and technical sales offices worldwide,
Carling Technologies Sales, Service and Engineering teams do much more than
manufacture electrical components, they engineer powerful solutions! To learn more
about Carling please visit www.carlingtech.com/company-profile.
To view all of Carling’s environmental, quality, health & safety certifications please visit
www.carlingtech.com/environmental-certifications.
4.
© Carling Technologies, Inc.
Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
很抱歉,暂时无法提供与“64111210”相匹配的价格&库存,您可以联系我们找货
