ES1S41653001
ES1S41653001
    APEM(埃斐)
    SWITCH PUSHBUTTON DPST-NC 1A 24V
ES1S41653001 数据手册
ES series Heavy-duty emergency stop Distinctive features and specifications ! New ❑ 3-pole configuration now available ❑ Rugged version : 100.000 cycle mechanical life ❑ Locked/unlocked status indicator ❑ Lower behind-panel depth ❑ IP65 sealing ❑ Complies with EN 60947-5-1 ELECTRICAL SPECIFICATIONS GENERAL SPECIFICATIONS • Electrical function : push-pull ON-ON • Current/voltage rating : 1A 24VDC DC-14 • Electrical life : 6.050 cycles • Contact resistance : 10 mΩ max. • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric stength : 1.000 Vrms 50 Hz min. between terminals 2.000 Vrms 50 Hz min. between poles and between terminals and frame ENVIRONMENTAL SPECIFICATIONS • Sealing : IP65 • Salt spray : 96 hours according to IEC 68-2-11 • Vibrations : 10-500 Hz - 10 g according to IEC 68-2-6 • Shock resistance : 50 g according to IEC 68-2-27 • Robustness (axial) : IK10 • Operating temperature : -40°C to +85°C • According to EN 60947-5-1 • Panel thickness : 6 mm (.236) max. • Low level or mechanical life : 100.000 cycles • Travel to lock : 2,20 mm ± 0,3 mm • Total travel : 4,20 mm ± 0,3 mm • Torque : 5 Nm min. - 14 Nm max. applied to nut • Operating force : 2P: Push : 30N ± 7N - pull : 25N ± 5N 3P: Push : 45N ± 7N - pull : 25N ± 5N MATERIALS • Case : diallylphthalate (DAP) • Actuator : aluminium, red anodised • Bushing : aluminium, yellow anodised • Contacts : silver, gold plated • Terminal seal : epoxy PANEL CUT-OUT ➀ O-ring ➁ Hole Note : the hole in the bushing is designed for insertion of a Ø 2 mm metal rod helping to fasten the switch on the panel. 2 pole 3 pole Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Tolerance : The general tolerance for dimensions in this brochure is ± 0,3 (.012). Dimensions, specifications and data shown in this brochure are subject to change without notice. APEM www.apem.com 1 ES series Heavy-duty emergency stop Overview ES Electrical functions SERIES 1 2 3 No of poles 2 NC (double pole only) 1 NO + 1NC (double pole only) 1 NO + 2NC (three pole only) P S 4 5 Actuator colour Double pole Three pole 6 Status indicator Red anodised 3 Other : on request Terminals Actuator diameter Straight PC Solder lug 1 35 mm (1.338) Other : on request. Bushing colour 5 Green Yellow anodised Options Blank None 001 PUSH PULL marking Other markings : on request NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 hex nut 25 (.984) across flats and 1 O-ring Packaging unit : 10 pieces 2 www.apem.com APEM ES series Heavy-duty emergency stop Straight PC terminal MODEL STRUCTURE Shown with solder lug terminals Double pole - 2 N.C. contacts C = common Solder lug terminals ES1S41653 Straight PC terminals ES1P41653 Double pole - 1 N.O. and 1 N.C. contacts C = common Solder lug terminals ES2S41653 Straight PC terminals ES2P41653 Three pole - 1 N.O. and 2 N.C. contacts C = common Solder lug terminals ES3S51653 Straight PC terminals ES3P51653 APEM www.apem.com 3 ES series Heavy-duty emergency stop STATUS INDICATOR COLOUR 3 Green Other : on request. OPTIONS Blank 001 None PUSH PULL marking Other markings : on request ES1204-R1-A 4 www.apem.com APEM
ES1S41653001 价格&库存
很抱歉,暂时无法提供与“ES1S41653001”相匹配的价格&库存,您可以联系我们找货
ES1S41653001
  • 1+1880.913811+241.24740
  • 10+1734.1378010+222.42180
  • 20+1711.0309720+219.45810
库存:12
ES1S41653001
    • 1+1439.96291
    • 5+1385.71723
    • 25+1347.81086
    • 50+1315.42383
    库存:2
