CTHS15CIC01ARROW
CTHS15CIC01ARROW
    VCC
    SWITCHPUSHCAPACITIVEILLUMSQ
CTHS15CIC01ARROW 数据手册
TM CTH Series Capacitive Touch Sensor Display 15.0 x 15.0 x 11.0 mm CTHS15CIC01 - Super Red Capacitive Touch Sensor Through Hole with a Display Size of 0.59 x 0.59 inches (15 x 15 mm) square Applications • Mobile communication devices • Touch Screen Monitors • Electronic devices • Portable Instruments • Point of sale Terminals • Media Players • Gaming • Medical devices • Industrial control displays • Appliances and consumer equipments Key Features • Integrated touch sensing and display technology • Enables the device interface to be more user friendly and intuitive • Mounting type: through hole (industry standard pitch 0.100”) • Available in one standard size: 15.0mm x 15.00mm x 11.00mm • Available in 5 colors: super red, white, pure green, blue or yellow • Touch sensor: integrated circuit (IC) • Uniform illumination and high optical clarity due to LED technology • Robust design due to no mechanical moving parts • Simplifies devices design and manufacturability • Optional overlay (icons): on/off, arrow, alarm • Custom overlay icon can be manufactured upon request - contact VCC • Compliant with RoHS and REACH requirements the first call for illuminated components www.vcclite.com 1  1.800.522.5546 11/16 Rev 1 Ordering Data The CTH Series (Cap Touch) is available in a range of standard features and options. To specify your Cap Touch Display, simply choose one option from each column. Series C Mounting Type Shape Dimension 15 TH S Polarity C 15 mm x 15 mm Square Color Integrated Circuit Cap Touch Through-Hole IC IC Common Cathode Super Red 01 White 04 Pure Green 05 Blue 06 Yellow 07 Overlay* ONOFF ON/OFF ARROW Arrow ALARM Alarm *Optional Overlay • Different LED colors can indicate the mode in which an electronic device is operating, depending on the icon associated with it. • Optional graphic overlay made with polished LEXAN™ Polycarbonate 8010 Film 0.007" (0.175 mm) thick has reverse printed translucent white icon, in order to still see it even when the back lighting is off. • Lexan 8010 is a transparent polycarbonate film and offers hardness, chemical and abrasion resistance, stiffness, and high temperature capability. • Three standard icons are available: alarm, arrow and on-off. Custom icons are also available upon request. • Capacitive Touch Display can also be mounted behind clear glass or plastic layer such as polycarbonate or acrylic, as shown in the picture below. Maximum thickness of acrylic/glass, 0.118” (3mm) Maximum distance between overlay and acrylic/glass: 0.015” (0.38mm) Overlay On/Off Overlay Arrow Overlay Alarm the first call for illuminated components www.vcclite.com 2 1.800.522.5546 11/16 Rev 1 6.50 0.256 10.01 0.394 11.02 0.434 Package Dimensions MARKING LABEL PIN 1 0.610 0.024 (4 PL) [2.54]X3 = 7.62 0.100X3 = 0.300 15.01 0.591 9.00 0.354 13.41 0.528 15.01 0.591 LUMINOUS ZONE 9.00 0.354 13.41 0.528 TOUCH PAD Dimensions in [mm] inches General tolerances unless otherwise specified: MARKING LABEL INFO CTHS15CICXX XXXX RoHS inches DATE CODE the first call for illuminated components www.vcclite.com 3 mm .X + .020 + .508 .XX + .010 + .254 .XXX + .005 + .127 1.800.522.5546 11/16 Rev 1 Internal Circuit Diagram PIN 3 PIN 1 VCC 1 PIN 2 1 Touch Pad OUT 2 Touch Pad IN 2 3 C4 U1 OUT LOWP VSS VDD IN VSS MCU 3 4 5 C3 6 R1 0/OPEN 0201 0.1uF 0805 D6 D7
CTHS15CIC01ARROW 价格&库存
很抱歉,暂时无法提供与“CTHS15CIC01ARROW”相匹配的价格&库存,您可以联系我们找货
CTHS15CIC01ARROW
  • 1+59.483101+7.69641
库存:98
CTHS15CIC01ARROW
  • 100+56.90209100+7.36246
