TM
CTH Series
Capacitive Touch Sensor Display
15.0 x 15.0 x 11.0 mm
CTHS15CIC04 - White Capacitive Touch Sensor Through Hole
with a Display Size of 0.59 x 0.59 inches (15 x 15 mm) square
Applications
• Mobile communication devices
• Touch Screen Monitors
• Electronic devices
• Portable Instruments
• Point of sale Terminals
• Media Players
• Gaming
• Medical devices
• Industrial control displays
• Appliances and consumer equipments
Key Features
• Integrated touch sensing and display technology
• Enables the device interface to be more user friendly and intuitive
• Mounting type: through hole (industry standard pitch 0.100”)
• Available in one standard size: 15.0mm x 15.00mm x 11.00mm
• Available in 5 colors: super red, white, pure green, blue or yellow
• Touch sensor: integrated circuit (IC)
• Uniform illumination and high optical clarity due to LED technology
• Robust design due to no mechanical moving parts
• Simplifies devices design and manufacturability
• Optional overlay (icons): on/off, arrow, alarm
• Custom overlay icon can be manufactured upon request - contact VCC
• Compliant with RoHS and REACH requirements
the first call for illuminated components
www.vcclite.com
1
1.800.522.5546
11/16 Rev 1
Ordering Data
The CTH Series (Cap Touch) is available in a range of standard features and options.
To specify your Cap Touch Display, simply choose one option from each column.
Series
C
Mounting
Type
Shape Dimension
15
TH
S
Polarity
IC
IC
C
Color
Integrated
Circuit
Cap Touch
15 mm x
15 mm
Through-Hole
Square
Common
Cathode
Super Red
01
White
04
Pure Green
05
Blue
06
Yellow
07
Overlay*
ONOFF
ON/OFF
ARROW
Arrow
ALARM
Alarm
*Optional
Overlay
• Different LED colors can indicate the mode in which an electronic device is operating,
depending on the icon associated with it.
• Optional graphic overlay made with polished LEXAN™ Polycarbonate 8010 Film 0.007"
(0.175 mm) thick has reverse printed translucent white icon, in order to still see it even
when the back lighting is off.
• Lexan 8010 is a transparent polycarbonate film and offers hardness, chemical and abrasion
resistance, stiffness, and high temperature capability.
• Three standard icons are available: alarm, arrow and on-off. Custom icons are also available
upon request.
• Capacitive Touch Display can also be mounted behind clear glass or plastic layer such as
polycarbonate or acrylic, as shown in the picture below.
Maximum thickness of acrylic/glass, 0.118” (3mm)
Maximum distance
between overlay
and acrylic/glass:
0.015” (0.38mm)
Overlay On Off
Overlay Arrow
Overlay Alarm
www.vcclite.com
2
1.800.522.5546
11/16 Rev 1
6.50
0.256
10.01
0.394
11.02
0.434
Package Dimensions
MARKING
LABEL
PIN 1
0.610
0.024 (4 PL)
[2.54]X3 = 7.62
0.100X3 = 0.300
15.01
0.591
13.41
0.528
9.00
0.354
15.01
0.591
LUMINOUS
ZONE
9.00
0.354
13.41
0.528
TOUCH PAD
MARKING LABEL INFO
Dimensions in [mm] inches
General tolerances unless otherwise specified:
CTHS15CICXX
XXXX RoHS
inches
DATE CODE
www.vcclite.com
3
mm
.X
+ .020
+ .508
.XX
+ .010
+ .254
.XXX
+ .005
+ .127
1.800.522.5546
11/16 Rev 1
Internal Circuit Diagram
PIN 3
PIN 1
VCC 1
PIN 2
MCU 3
U1
1
Touch Pad OUT 2
2
3
Touch Pad IN
4
OUT
LOWP
VSS
VDD
IN
VSS
5
C3
6 R1
0/OPEN 0201
C4
0.1uF 0805
D6
D7
很抱歉,暂时无法提供与“CTHS15CIC04ARROW”相匹配的价格&库存,您可以联系我们找货
