IZPP1F462
IZPP1F462
    APEM(埃斐)
    SWITCH PUSH SPST 0.1A 24V
IZPP1F462 数据手册
IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - metal - latching Distinctive features and specifications ❑ Rear mounting for easier installation ❑ Latching action metal models ❑ Fixed or variable panel thickness ❑ Illuminated or non-illuminated ❑ Flat actuator for optional marking ❑ Sealed to IP67 ENVIRONMENTAL AND GENERAL SPECIFICATIONS MATERIALS • Degree of protection : IP67 • Temperature range : -40°C to +85°C • Total travel : 2,5 mm (.098) • Mechanical life : 200.000 cycles • Case : thermpoplastic UL94-V0 • Plunger : polyamide • Bushing/bezel : brass, nickel plated • Contacts : silver, gold plated • Multi-wire lead AWG20, section 0,6 mm2 • LED wire : AWG26, section 0,12 mm2 • Lens : polycarbonate • Terminal seal : epoxy ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 100mA 24VDC - 200.000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.500 Vrms between terminals 1.000 Vrms between terminals and frame LED COMPONENT SPECIFICATIONS LED colour Forward current Typ. forward voltage Max. forward voltage Super red (L0S) 20mA 1,95V 1,95V Yellow (L0Y) 20mA 2V 2,05V Green (L0G) 20mA 3,2V 3,70V Blue (L0B) 20mA 3,2V 4V A resistor must be series-connected by the user. Resistor value = supply voltage - LED forward voltage LED forward current On flying lead versions, the LED resistor can be integrated by APEM on request. Dimensions : First dimensions are im mm while inches are shown as bracketed numbers. Tolerance : The general tolerance for dimensions in this brochure is ± 0,3 (.012). Overall dimension tolerance is ± 0,5 (.020). Dimensions, specifications and data shown in this catalogue are subject to change without notice. APEM www.apem.com 3 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - metal - latching Overview IZ Electrical function Model SERIES N M Metal, fixed panel thickness Metal, variable panel thickness 1 1 B 2 3 5 6 7 8 9 A Blue Dark blue Black Green Yellow Red White Bright chrome Orange Satin chrome OFF - ON Solder lugs Flying leads Straight PC Quick-connect Contacts 4 Silver, gold plated Round, curved Round, flat Bushing & bezel finish N S F P Z Actuator shape R P Actuator colour Terminals Nickel plated (standard) Other : on request. LED colour Blank L0S L0Y L0G L0B Non-illum. Super red Yellow Green Blue ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : - IZN : 1 castellated nickel plated brass nut U6911 + 1 O-ring - IZM : 1 castellated nickel plated brass nut U6911 + 1 silicone flat seal + 1 hex nut 19 mm (.748) across flats U4116. Packaging unit : 25 pieces for flying lead models - 40 pieces for other models 4 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - metal - latching Illuminated Straight P Solder lug S Quick-connect Z 2.80 (.110) 8.40 (.330) 1.40 (.055) 3.20 (.125) 2.40 (.094) 2.30 (.090) • Four LED colours • Tin plated LED terminals • Gold plated contacts 1.20 (.047) 2.80 (.110) MODEL STRUCTURE Plunger marking available on IZ•P models (symbol 10 mm max.). On request. Fixed panel thickness - solder lug terminals Curved actuator IZNR1S4 OFF - ON Flat actuator IZNP1S4 OFF - ON CIPNLF1COS CISCOSZ-A DESSIN ECH 0.9 DESSIN ECH 0.9 17.10.01 5-05-03 Photo Also available with straight PC terminals : IZN•1P4 & quick-connect terminals : IZN•1Z4. Fixed panel thickness - flying lead terminals Curved actuator IZNR1F4 OFF - ON Flat actuator IZNP1F4 OFF - ON Photo Wire colours : black : contact, red : LED anode(+), blue : LED cathode (-) Variable panel thickness - solder lug terminals Curved actuator IZMR1S4 OFF - ON Flat actuator IZMP1S4 OFF - ON Photo Also available with straight PC terminals : IZM•1P4 & quick-connect terminals : IZM•1Z4. APEM www.apem.com 5 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - metal - latching Illuminated Variable panel thickness - flying lead terminals Curved actuator IZMR1F4 OFF - ON Flat actuator IZMP1F4 OFF - ON Photo Wire colours : black : contact, red : LED anode(+), blue : LED cathode (-) ACTUATOR COLOUR 1 : blue - B : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7 : white - 8 : bright chrome - 9 : orange A : satin chrome BUSHING AND BEZEL COLOUR LED COLOUR N : nickel plated (standard) Other : on request. L0S : super red - L0Y : yellow - L0G : green L0B : blue 6 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - metal - latching Non-illuminated • Gold plated contacts Straight P Quick-connect Z 2.80 (.110) 8.40 (.330) 1.40 (.055) 3.20 (.125) 2.40 (.094) 2.30 (.090) Solder lug S 1.20 (.047) 2.80 (.110) MODEL STRUCTURE Plunger marking available on IZ•P models (symbol 10 mm max.). On request. Fixed panel thickness - solder lug terminals Curved actuator IZNR1S4 OFF - ON Flat actuator IZNP1S4 OFF - ON CIPNLF1COS CISCOSZ-A DESSIN ECH 0.9 DESSIN ECH 0.9 17.10.01 5-05-03 Also available with straight PC terminals : IZN•1P4 & quick-connect terminals : IZN•1Z4. Variable panel thickness - solder lug terminals Photo Curved actuator IZMR1S4 OFF - ON Flat actuator IZMP1S4 OFF - ON Also available with straight PC terminals : IZM•1P4 & quick-connect terminals : IZM•1Z4. Also available with straight PC terminals : IZM•1P4 & quick-connect For FLYING LEAD versions, refer to previous pages (illuminated models). Non-illuminated have 2 wires only. ACTUATOR COLOUR 1 : blue - B : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7 : white - 8 : bright chrome - 9 : orange A : satin chrome BUSHING AND BEZEL COLOUR N : nickel plated (standard) Other : on request. APEM www.apem.com 7 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - momentary Distinctive features and specifications ❑ Rear mounting for easier installation ❑ Momentary models ❑ Illuminated or non-illuminated ❑ Flat actuator for optional marking ❑ Sealed to IP67 ❑ Screw version available up to 4A ENVIRONMENTAL AND GENERAL SPECIFICATIONS MATERIALS • Degree of protection : IP67 • Temperature range : -40°C to +85°C • Total travel : 1,7 mm (.067) • Mechanical life : 1.000.000 cycles ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - Gold plated silver contacts (code 4) : 200mA 48VDC - 200mA 250VAC - Silver contacts (code 2) - screw terminals : 2A 250VAC - 4A 48VDC • Electrical life at full load : 500.000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz • Case : thermoplastic UL94-V0 • Plunger : polyamide • Bushing/bezel : polyamide • Contacts : 4 : silver, gold plated 2 : silver (screw terminals) • Multi-wire lead AWG20, section 0,6 mm2 • LED wire : AWG26, section 0,12 mm2 • Lens : polycarbonate • Terminal seal : epoxy LED COMPONENT SPECIFICATIONS LED colour Forward current Super red (L0S) 20mA Typ. forward voltage Max. forward voltage 2,1V 2,3V Yellow (L0Y) 20mA 2,1V 2,3V Green (L0G) 20mA 2,1V 2,3V Blue (L0B) 20mA 3,2V 3,8V White (L0W) 20mA 3,35V 4,25V A resistor must be series-connected by the user. Resistor value = supply voltage - LED forward voltage LED forward current On flying lead versions, the LED resistor can be integrated by APEM on request. 8 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - momentary Overview IZ Electrical function Model SERIES P Plastic 3 Normally open (NO) Actuator shape Round, curved Round, flat R P Actuator colour 1 B 2 3 5 6 7 8 9 A Blue Dark blue Black Green Yellow Red White Bright chrome Orange Satin chrome Bushing & bezel finish 2 Black (standard) Terminals Solder lugs Flying leads Straight PC (non-illuminated) Z Quick-connect (non-illuminated) V Screw (non-illuminated) S F P 4 2 Silver, gold plated Silver (screw term.) LED colour Blank L0S L0Y L0G L0B L0W Other : on request. Contacts Non-illum. Super red Yellow Green Blue White ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 castellated black plastic nut U4249 and 1 silicone flat seal. Packaging unit : 25 pieces for flying lead models - 40 pieces for other models APEM www.apem.com 9 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - momentary Illuminated • Five LED colours • Tin plated LED terminals • Gold plated contacts MODEL STRUCTURE Plunger marking available on IZPP models (symbol 10 mm max.). On request. ➞ Flat Solder lug terminals Curved actuator IZPR3S4 Normally Open Flat actuator IZPP3S4 Normally Open ➞ Flat Flying lead terminals - momentary Curved actuator IZPR3F4 Normally Open Flat actuator IZPP3F4 Normally Open Wire colours : black : NO contact, red : LED anode(+), blue : LED cathode (-) ACTUATOR COLOUR 1 : blue - B : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7 : white - 8 : bright chrome - 9 : orange A : satin chrome BUSHING AND BEZEL COLOUR LED COLOUR 2 : black (standard) Other : on request. L0S : super red - L0Y : yellow - L0G : green L0B : blue - L0W : white 10 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - momentary Non-illuminated Solder lug S Straight P Quick-connect Z MODEL STRUCTURE Plunger marking available on IZPP models (symbol 12 mm max.). On request. ➞ Flat Solder lug terminals - gold plated contacts Curved actuator IZPR3S4 Normally Open Flat actuator IZPP3S4 Normally Open Also available with straight PC terminals : IZP•3P4 and quick-connect terminals : IZP•3Z4. Sealed flying lead terminals - gold plated contacts Curved actuator IZPR3F4 Normally Open Flat actuator IZPP3F4 Normally Open ➞ Flat ➞ Flat Screw terminals - silver contacts Curved actuator IZPR3V2 Normally open Flat actuator IZPP3V2 Normally open Actuator colour and bushing/bezel colour : select the desired codes on previous page. APEM www.apem.com 11 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - latching action Distinctive features and specifications ❑ Rear mounting for easier installation ❑ Latching action models ❑ Illuminated or non-illuminated ❑ Flat actuator for optional marking ❑ Sealed to IP67 ENVIRONMENTAL AND GENERAL SPECIFICATIONS MATERIALS • Degree of protection : IP67 • Temperature range : -40°C to +85°C • Total travel : 2,5 mm (.098) • Mechanical life : 200.000 cycles • Case : thermoplastic UL94-V0 • Plunger : polyamide • Bushing/bezel : polyamide • Contacts : silver, gold plated • Multi-wire lead AWG20, section 0,6 mm2 • LED wire : AWG26, section 0,12 mm2 • Lens : polycarbonate • Terminal seal : epoxy ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : 100mA 24VDC - 200.000 cycles • Initial contact resistance : 100 mΩ max. • Insulation resistance : 1 GΩ min. at 500VDC • Dielectric strength : 1.500 Vrms between terminals LED COMPONENT SPECIFICATIONS LED colour Forward current Typ. forward voltage Max. forward voltage Super red (L0S) 20mA 1,95V 1,95V Yellow (L0Y) 20mA 2V 2,05V Green (L0G) 20mA 3,2V 3,70V Blue (L0B) 20mA 3,2V 4V A resistor must be series-connected by the user. Resistor value = supply voltage - LED forward voltage LED forward current On flying lead versions, the LED resistor can be integrated by APEM on request. 12 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - latching action Distinctive features and specifications IZ Electrical function Model SERIES P Plastic 1 Terminals ON - OFF S F P Z Actuator shape 1 B 2 3 5 6 7 8 9 A Blue Dark blue Black Green Yellow Red White Bright chrome Orange Satin chrome 4 Silver, gold plated Round, curved Round, flat R P Actuator colour Solder lugs Flying leads Straight PC Quick-connect Contacts Bushing & bezel finish 2 Black (standard) LED colour Blank L0S L0Y L0G L0B Other : on request. Non-illum. Super red Yellow Green Blue ABOUT THIS SERIES On the following pages, you will find successively : model structure of switches and options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketted numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied : 1 castellated black plastic nut U4249 and 1 silicone flat seal. Packaging unit : 25 pieces for flying lead models - 40 pieces for other models APEM www.apem.com 13 IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - latching action Illuminated Straight P Solder lug S Quick-connect Z 2.80 (.110) 8.40 (.330) 1.40 (.055) 3.20 (.125) 2.40 (.094) 2.30 (.090) • Four LED colours • Tin plated LED terminals • Gold plated contacts 1.20 (.047) 2.80 (.110) MODEL STRUCTURE Plunger marking available on IZPP models (symbol 10 mm max.). On request. ➞ Flat Solder lug terminals Curved actuator IZPR1S4 ON - OFF Flat actuator IZPP1S4 ON - OFF CIPNLF1COS CISCOSZ-A DESSIN ECH 0.9 DESSIN ECH 0.9 17.10.01 5-05-03 Also available with straight PC terminals : IZP•1P4 and quick-connect terminals : IZP•1Z4. ➞ Flat Sealed flying lead terminals Curved actuator IZPR1F4 ON - OFF Flat actuator IZPP1F4 ON - OFF Photo Wire colours : black : NO contact, red : LED anode(+), blue : LED cathode (-) ACTUATOR COLOUR 1 : blue - B : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7 : white - 8 : bright chrome - 9 : orange A : satin chrome BUSHING AND BEZEL COLOUR LED COLOUR 2 : black (standard) Other : on request. L0S : super red - L0Y : yellow - L0G : green L0B : blue 14 www.apem.com APEM IZ series Preliminary Rear mounted sealed pushbutton switches - bushing Ø 16 - latching action Non-illuminated • Gold plated contacts Straight P Quick-connect Z 2.80 (.110) 8.40 (.330) 1.40 (.055) 3.20 (.125) 2.40 (.094) 2.30 (.090) Solder lug S 1.20 (.047) 2.80 (.110) MODEL STRUCTURE Plunger marking available on IZPP models (symbol 10 mm max.). On request. ➞ Flat CIPNLF1COS Solder lug terminals Curved actuator IZPR1S4 ON - OFF Flat actuator IZPP1S4 ON - OFF CISCOSZ-A DESSIN ECH 0.9 DESSIN ECH 0.9 17.10.01 5-05-03 Also available with straight PC terminals : IZP•1P4 and quick-connect terminals : IZP•1Z4. ➞ Flat Sealed flying lead terminals Photo Curved actuator IZPR1F4 ON - OFF Flat actuator IZPP1F4 ON - OFF ACTUATOR COLOUR 1 : blue - B : dark blue - 2 : black - 3 : green - 5 : yellow - 6 : red - 7 : white - 8 : bright chrome - 9 : orange A : satin chrome I Z 0 9 0 9 A - P re l i m i n a r y BUSHING AND BEZEL COLOUR 2 : black (standard) Other : on request. APEM www.apem.com 15
IZPP1F462 价格&库存
很抱歉,暂时无法提供与“IZPP1F462”相匹配的价格&库存,您可以联系我们找货
IZPP1F462
  • 4+257.86481
  • 9+253.06468
  • 18+248.36128
  • 25+238.77312
  • 50+219.06478
库存:86
IZPP1F462
  • 1+490.372751+62.90017
  • 10+423.0164210+54.26036
  • 25+398.7586625+51.14882
  • 50+381.3012150+48.90955
  • 100+364.57464100+46.76403
  • 250+343.53367250+44.06510
库存:72
