301SZBE
301SZBE
    APEM(埃斐)
    SWITCH PUSH SPST-NO 0.4VA 20V
301SZBE 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE 300 & 400 SERIES - MINIATURE PUSHBUTTON SWITCHES L FEATURES Dry circuit through power ratings . Compact size SPST momentary and alternate action models with numerous options. Panel, panel & p.c. and p.c. mounting models, lighted and unlighted. SPECIFICATIONS Contact ratings & life: Initial contact resistance: Insulation resistance: Dielectric strength: Operating temperature range: (Q) power models - coin silver: 1 Amp at 125 VAC or 28 VDC or 0.5 Amps at 250 VAC - electric life 250,000 cycles min. 3 Amps at 125 VAC or 28 VDC, or 1.5 Amps at 250 VAC - electric life 10,000 cycles min. (All previous loads are resistive). (B) dry circuit models - gold over nickel over brass: 0.4 VA max. at 20 V max.electric life 250,000 cycles min. UL models - coin silver: 1 Amp at 125 VAC or 0.5 Amps at 250 VAC (75% power factor). UL file no. E66367. 10 milliohms max. at 3 VDC, 0.1 Amp. Greater than 10,000 megohms. 1000 Volts RMS min. at sea level. -30°C to +85°C MATERIALS Contacts: Actuator: Bushing: Base: Terminal seal: Support bracket: Spring mounting bracket: Bezel & cap: Hardware: LED: Coin silver for power & UL models. Gold over nickel over brass for dry circuit models. Nylon. Black color is standard for 300 Series. White is standard for 400 Series. Nickel plated brass DAP, color blue. Epoxy (standard) Brass or steel, tin plated Stainless steel Nylon. Available in black, red or white. Consult factory for other colors. See Miscellaneous section. Intensity: 2.0 mcd at 10 mA. Forward voltage: 2.0V (3.0V max.). Max. continuous forward current: 30 mA at 25°C. Red standard - yellow & green are optional. Specifications are subject to change without notice - consult factory. AGENCY RECOGNITION UL Marking: Switches ordered with '/UL' added at end of model no. are supplied with recognized mark. ABOUT THIS SERIES The material in this series is organized in the following sequence: a. Completely specified switch models & options b. 'build your own switch' order format c. Additional options & panel cut-outs L24 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com 300 & 400 SERIES - MINIATURE PUSHBUTTON SWITCHES SPST Momentary (Normally open or normally closed) White actuator optional - black is standard (Q) Power Model No. 301ZQE (B) Dry ckt. Model No. 301ZBE UL Model No. 301ZQE/UL 302ZQE 305ZQE 302ZBE 305ZBE 302ZQE/UL 305ZQE/UL 306ZQE 306ZBE 306ZQE/UL * indicates 'Q' option not available for these models L Switch caps optional - see Hardware section of catalog. 302 301 N.O. with overtravel Total travel: Overtravel: Actuation force: N.O. without overtravel Total travel: .060 Actuation force: 10 oz. ± 4 oz. 305 .110 .020 min. 8.5 oz. ± 4 oz. 306 N.O. with sealed contact area and maximum overtravel. Total travel: .310 Pretravel to contact closure: .025 Actuator force to contact closure: 1.5 oz. Overtravel: .250 minimum Actuation force at full travel: 9 oz. Note: Electrical or mechanical life for this model is 20,000 cycles. N.O. with more overtravel than 301 Total travel: .110 Pretravel to contact closure: .030 Actuation force to contact closure: 3 oz. Overtravel: .075 Actuation force at full travel: 8 oz. 400 SERIES (401 Push on/ push off, 402 N.O. momentary) Black actuator optional white is standard (Q) Power Model No. 401ZQE (B) Dry ckt. Model No. 401ZBE UL Model No. 401ZQE/UL 402ZQE 402ZBE 402ZQE/UL SNAP-ACTION MECHANISM Pretravel to contact clusure: .026 Travel to actuate switch .106 Total travel: .137 Force to actuate switch: 22 oz. Force at maximum travel: 35 oz. Mechanical life: 1,000,000 cycles minimum United States Patent 4,319,106 NOTE: When using sealing boot U5321 with 400 Series switches, add 'S1' to model number. Switchcaps optional - see Hardware section of catalog. OPTIONS Colored operating actuator Available in dyed nylon.To specify, add digit at end of model number 1 blue, 2 black, 3 green, 5 yellow, 6 red, 7/1 white or 9 orange. Black is standard for 300 Series. White is standard for 400 Series. Z C E (standard) Solder lug terminal Printed circuit terminal Epoxy seal L25 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE 300 SERIES 300 & 400 SERIES - MINIATURE PUSHBUTTON SWITCHES OPTIONS FOR SELECTIVE MODELS ONLY SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Options V30 For models 301, 302 & 305 only Straight p.c. terminals w/bracket MODEL NO. 301,305 302 *OPTION V30 V30 DIM. A .527 .527 DIM. B .173 .150 DIM C. .933 .910 DIM D. .237 .125 * Options V31 with crimped leg design also available see prior page. TO SPECIFY, ADD OPTION FROM BOX TO SWITCH MODEL NO. - EXAMPLE: 302V31BE L P.C. BOARD LAYOUT Options V & V-1 Right angle terminals w/bracket For models 301, 302, 305, 401 & 402 only MODEL NO. 301, 305 301, 305 302 302 401, 402 401, 402 OPTION V V-1 V V-1 V V-1 DIM. A .173 .173 .150 .150 .210 .210 DIM. B .439 .439 .327 .327 .653 .653 DIM C. .550 .550 .450 .450 .750 .750 DIM D. .700 .650 .600 .550 .900 .850 TO SPECIFY, ADD OPTION FROM BOX TO SWITCH MODEL NO. - EXAMPLE: 301V-1BE Support Bracket is Brass, Solder Coated. Available with B, N, or T Contact Materials. (See pg. C29) Supplied with Epoxy Sealed Terminals. L26 Note: Terminals are not fully bent, to facilitate spring retention in p.c. board. P.C. BOARD LAYOUT APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com 300 & 400 SERIES - MINIATURE PUSHBUTTON SWITCHES OPTIONS FOR SELECTIVE MODELS ONLY MODEL NO. 301,305 A .250 TO SPECIFY, ADD 'T1' TO SWITCH MODEL NO. - EXAMPLE: 301T1CQE6 Threaded bushing: Brass, nickel plated Actuator button: Nylon. Specify color - see order format. Supplied with 2 Hex Nuts, p/n A465 & 1 Lockwasher, p/n A466 (see Hardware section of catalog). Printed circuit or solder lug terminals available. L Option S Long actuator For models 301, 302, 305, 401 & 402 only TO SPECIFY, ADD 'S' TO SWITCH MODEL NO. - EXAMPLE: 301SCQE Actuator: Nylon Color: Black standard for 300 Series White standard for 400 Series. Other colors available - see options. NOTE: When using sealing boot U5321 with 400 Series switches, add 'S1' to model number. This option is not illustrated. 301 & 305 302 401 & 402 Additional ordering information: Commonly ordered models are shown above and on prior pages with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from all available options shown and filling in the boxes. 'BUILD YOUR OWN SWITCH' ORDER FORMAT Fill in boxes with selections shown for Model Structure, then add Options selections for complete model number. Allowable options are shown below each respective box with brief description - see option dwgs. & info. following. Notes: 'NONE' indicates box may be left empty. Not all combinations can be made - see other pages of Series. Model Structure: Series Actuators Bushings Terminations Contact materials Sealing E 3 3 3 3 4 4 0 0 0 0 0 0 1 2 5 6 1 2 Recognitions (NONE) /UL (NONE) S Long (see dwg. - specify for all models with bezelsnot available for 306). S 1 For 400 Series switches used with sealing boot U5321 only. (NONE) T 1 15/32" thd'd. (see dwg for 301, 303 & 305 only). Z Solder lug C Printed circuit V V - Right angle p.c. term1 inals for 301, 302, 305, 401 & 402 only (see dwg.). V 3 0 Straight p.c. terminals B Gold Q Coin silver (Not available with 303 & 304) N Economy gold T Economy silver Epoxy terminal seal is standard Switch caps for switches without bezels also available - see Hardware section of catalog. Example of completely specified model number: 301SZQE/UL Although most combinations of options are available, some may result in incompatibilities. Consult factory if there is any question. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com L27 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Option T1 15/32" bushing mounts from front or rear of panel For models 301, 303 & 305 only 300 & 400 SERIES - MINIATURE PUSHBUTTON SWITCHES CONTACT MATERIAL OPTIONS B Dry circuit - gold over nickel over brass. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 250,000 cycles minimum. Power circuit - coin silver. RATING: 1 Amp at 120 VAC or 28 VDC or 0.5 Amps at 250 VAC. ELECTRIC LIFE: 250,000 cycles minimum at full load. Also - 3 Amps at 120 VAC or 28 VDC or 1.5 Amps at 250 VAC. ELECTRIC LIFE: 10,000 cycles minimum at full load. Dry circuit or power circuit - gold over nickel over coin silver RATINGS & ELECTRIC LIFE: Same as B & Q above -i.e.- can be used in either dry circuit or power circuit, however once used in power circuit, switch cannot be re-used in dry circuit. This option permits customers to inventory one switch to satisfy either application, Dry circuit - gold over nickel over coin silver. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. Note- less gold than B option. ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. Power circuit - Silver plate over brass. RATING: 0.5 Amps at 120 VAC or 0.25 Amps at 250 VAC (resistive loads). ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Q G N T Solder dipped terminals and custom contact plating available - contact factory. UL OPTION /UL For power circuits - coin silver RATING: 1.0 Amps at 125 VAC or 0.5 Amps at 250 VAC (75% power factor). Underwriter Laboratories file no. E66367. Note - applicable only to terminations with coin silver contacts (Q or G options). HARDWARE HARDWARE SUPPLIED (See Hardware section of catalog) Panel mounted 300 Series switches with threaded 1/4" bushing are supplied with 1 Hex Nut A112 and 1 Lockwasher A115. Panel mounted 300 Series switches with threaded 15/32" bushing are supplied with 2 Hex Nuts A465 and 1 Lockwasher A466. Panel mounted 306 Series switches with threaded 5/16" bushing are supplied with 1 Hex Nut A713 and 1 Lockwasher A734. Panel mounted 400 Series switches with threaded bushing are supplied with 1 Panel Dress Nut A274 and 1 Lockwasher A115. PANEL CUT-OUTS Accepts all 1/4" threaded bushings L28 Accepts all 15/32" threaded bushings APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com L Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: 401ZQE2 302ZNE 301ZQE 303ZTE 402ZQE 305ZBE 301CBE 301SCBE 301SZBE 301ZBE 302CBE 302SZBEJ8182 302SZQE 302ZBE 306ZBE 306ZQE 401SZQE 402ZBE 402ZQE2 301T1ZQE2UL 301ZQEUL 301T1CBE2 301T1CQE2 301T1ZBE2 301T1ZQE2 302SCQE 302ZQE 306CBE 306CQE 401CQE2 401ZBE 402CQE 401 ZQE 402ZBE2 305CBE 305T1ZQE2 301CQE 401CQE 302V1NE 401ZQEUL 302SZQEJ8126UL 302V1BE 301T1ZQE6UL 302ZQEUL 401ZQEA112 301SZQEUL 402SCQEJ8122 402SCQEUL
301SZBE 价格&库存
很抱歉,暂时无法提供与“301SZBE”相匹配的价格&库存,您可以联系我们找货
301SZBE
  • 35+35.95926
  • 85+35.35530
  • 100+33.33127
  • 500+30.80123
  • 1000+29.49541
  • 2500+28.64662
  • 5000+28.04267
  • 10000+23.97828
库存:158
