PANEL SWITCHES
4
-9
SW
00
1
80
1
0-
9400-9600 series
Momentary pushbutton switches
DISTINCTIVE FEATURES
Two case lengths
Three electrical functions
Sealing options
Model X1146 with Ø 16 (.630) bushing
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- silver contact (A) : 1 A 30 VDC
- gold plated contacts (CD) : 100 mA 30 VDC
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength :
1,000 Vrms 50 Hz min. between terminals
1,500 Vrms 50 Hz min. between terminals and frame
• Electrical life : 250,000 cycles
GENERAL SPECIFICATIONS
• Total travel :
9600-9400-9400Y
9600N-9400N
Functions 3 and 5
Function 2
Function 3
1.3 mm
2 mm
0.9 mm
• Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut
• Operating temperature : -30 °C to +65 °C (-22 °F to +149 °F)
MATERIALS
• Case : thermoplastic UL94-V0
• Actuator : polyamide, glass filled
• Bushing : brass, nickel plated
• Contacts :
A : silver
CD : brass, gold plated
• Terminal seal : epoxy
APEM products may be recycled at end-of-life for the re-claiming of valuable metal components.
The company reserves the right to change specifications without notice.
1
PANEL SWITCHES
9400-9600 series
PANEL CUT-OUT
Ø6.50
(.255 DIA)
4.55
(.179)
8.70
(.342)
2.40
(.094)
TERMINALS
9600Z1
5.20
(.204)
2.80
(.110)
OSP
CIPCOSZ1
1.50
(.059)
1.20
(.047)
9600
4.55
(.179)
1.20
(.047)
5.20
(.204)
1.00
(.039)
1.00
(.039)
2.00
(.078)
C96COSSO-2
1.50
(.059)
4.55
(.179)
5.20
(.204)
C96COSPO-2
9400
1.00
(.039)
2.00
(.078)
C96COSPO-2
ELECTRICAL FUNCTIONS
FICHIER: C96COS-2
ECHELLE:1.5
LE 24-09-92
corrige le 07-01-2010
FICHIER: C96COS-2
Function 2 (NC)
ECHELLE:1.5
LE 24-09-92
Function 3 (NO)
2
Function 5 (combined)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
9
SERIES
NUMBER OF POLES
TERMINALS, CASE AND BUSHING
3
Case length 11.2 (.440)
2
Normally closed (NC)
4
Straight PC terminals
3
Normally open (NO)
6
Solder lug terminals
5
Combined (NC/NO)
4..Y
Single pole
Straight PC terminals, bracket mounting
Case length 8.5 (.334)
4..N
6..N
6..NZ1
Quick-connect terminals
All models have Ø 6.35 (1/4) threaded bushing.
OPTIONS
ORDER
SEPARATELY.
CONTACT MATERIALS
A
CD
Silver
Brass, gold
plated
SEALING
B
KB
SPECIAL OPTIONS
Epoxy sealed
terminals (standard)
X1146
Front panel sealing
by two O-rings not available with
9400Y.
X601
Bushing Ø 16 (.630)
Special contact,
lower rating
CAPS
U900
Ø 5 (.196)
U1140
Ø 8 (.314)
U1720
Ø 9.4 (.370)
U480
Ø 10 (.393) standard
U630
Ø 15 (.590)
U2430
Square - Height 4 (.157)
U2020
Square - Height 6 (.236)
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart.
Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Sealing boots are available to protect the switches against dust and water. See "Sealing Boots" section of website.
Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats and 1 lockwasher. Standard
and special hardware available is presented in the “Hardware“ section of website.
3
PANEL SWITCHES
9400-9600 series
6.00
(.236)
Ø4.00
(.157 DIA)
11.20
(.440)
2.00
(.078)
NO
NO Ø10.00
(.393 DIA)
NC Ø6.35-40UNS
(1/4-40UNS) 0.40
Ø9.00
(.015)
(.354 DIA)
5.08
(.200)
NO
NO
NC
0.40
Ø10.00
(.015)
(.393
DIA)
5.08
(.200)
Ø9.00 CK96DT-A
(.354 DIA)
5.20
(.204)
11.20
(.440)
11.20
(.440)
NO
EPOXY
5.20
(.204)
2.00
(.078)
Combined function
5.08
(.200)
NO
4.55
(.179)
NC
F5
0.40
(.015)
5.08
(.200)
15.75
(.620)
C94YDT-A
3.18
(.125)
8.50
(.334)
Ø9.50
(.374 DIA)
C94YDT-A
EPOXY
5.00
(.196)
5.08
(.200)
15.75
(.620)
Ø6.35-40UNS
(1/4-40UNS)
F5
0.40
(.015)
15.75
15.75
(.620)
(.620)
5.08
(.200)
NO
Ø1.60
(.062 DIA)
3.18
C94YDT-A
(.125)
NO
15.75
(.620)
8.20
(.322)
7.00
(.275)
Normally Open
15.75
(.620)
15.75
(.620)
4.10
(.161)
Ø4.00
(.157 DIA)
3.18
(.125)
Ø1.60
(.062 DIA)
NO
2.00
(.078)
1.50
(.059)
4.10
(.161)
0.40
(.015)
F2
5.08
3.18
(.200)
(.125)
NC
NC
3.18
0.40
3.18
(.015) (.125)
(.125)
5.08
(.200)F5
EPOXY
Ø1.60
(.062 DIA)
15.75
(.620)
NO
0.40 Ø6.35-40UNS
(.015) (1/4-40UNS)
0.40
(.015)
5.08
EPOXY
(.200)
F2
9633N B
5.08
(.200)
5.08
(.200)
13.00
(.511)
4.10
(.161)
13.00
(.511)
13.00
(.511)
3.18
F2
(.125)
1.17
(.046)
NO
NO
0.40 15.75
(.015) (.620)
1.17
8.20
(.046)
(.322)
6.00
(.236)
EPOXY
Ø4.00
(.157 DIA)
8.20
(.322)
SOLDER LUG TERMINALS
CASE LENGTH 8.5 (.334) : 9600N
Ø6.35-40UNS
(1/4-40UNS)
3.18
(.125)
1.17
(.046)
Ø10.00
(.393 DIA)
3.18
(.125)
Ø10.00
(.393 DIA)
5.08
(.200)
6.60
(.259)
6.00
(.236)
The bracket is not fastened to the switch.
CK94DT-A
5.08
(.200)
Ø6.35-40UNS
(1/4-40UNS)
Ø4.00
(.157 DIA)
Ø10.00
(.393 DIA)
Combined function
5.08
(.200)
CK94DT-A
6.60
(.259)
9435Y B
Normally Open
0.40
(.015)
Ø4.00
(.157 DIA)
6.60
(.259)
9433Y B
Normally Closed
6.00
(.236)
9432Y B
NO
NC
6.00
(.236)
BRACKET MOUNTING
CASE LENGTH 11.2 (.440) : 9400Y
Ø1.60
(.062 DIA)
Ø1.60
CK94DT-A
(.062 DIA)
Ø9.00
(.354 DIA)
EPOXY
1.00
(.039)
5.08
(.200)
0.40
(.015)
Ø10.00
(.393 DIA)
5.08
(.200)
1.00
(.039)
5.08
(.200)
NO
NC
5.08
(.200)
5.08
(.200)
NO
EPOXY
5.08
(.200)
4.55
(.179)
11.85
(.466)
1.00
(.039)
NO
NO Ø10.00
(.393 DIA)
NC Ø6.35-40UNS 0.40
(1/4-40UNS) (.015)
Ø9.00
5.08
(.354 DIA)
(.200)
5.08
5.08
(.200)
(.200)
Combined function
Ø4.00
(.157 DIA)
4.55
(.179)
9435 B
5.08
(.200)
Ø1.60
(.062 DIA)
Ø9.00
(.354 DIA)
11.85
(.466)
Normally Open
CK96DT-A
Ø6.35-40UNS
(1/4-40UNS)
Ø10.00
11.85
(.466)
7.00
(.275)
9433 B
7.00
(.275)
Normally Closed
5.08
(.200)
(.393 DIA)
EPOXY
6.00
(.236)
9432 B
CK96DT-A
Ø6.35-40UNS
(1/4-40UNS)
Ø4.00
(.157 DIA)
6.00
(.236)
STRAIGHT PC TERMINALS
0.40
(.015)
5.08
(.200)
Ø4.00
(.157 DIA)
6.00
(.236)
9635 B
NO
NC
5.08
(.200)
Normally Closed
7.00
(.275)
9632 B
2.00
(.078)
5.20
(.204)
EPOXY
5.08
(.200)
7.00
(.275)
Ø9.00
(.354 DIA)
Ø4.00
(.157 DIA)
EPOXY
6.00
(.236)
Ø6.35-40UNS
(1/4-40UNS)Ø10.00
(.393 DIA)
7.00
(.275)
CASE LENGTH 11.2 (.440) : 9600
Ø6.35-40UNS
(1/4-40UNS)
Ø4.00
(.157 DIA)
6.00
(.236)
7.00
(.275)
PANEL SWITCHES
9400-9600 series
Ø8.50
(.334 DIA)
Also available with quick-connect terminals 2.8 x 0.5 mm : 9633NZ1
4
C96NDT-A
2.00
(.078)
9400-9600 series
Ø8.50
(.334 DIA)
C96NDT-A
Ø4.00
(.157 DIA)
6.00
(.236)
CASE LENGTH 8.5 (.334) : 9400N
Ø6.35-40UNS
(1/4-40UNS)
3.50
(.137)
5.08
(.200)
Ø1.60
(.062 DIA)
EPOXY
0.40
(.015)
1.00
(.039)
1.50
(.059)
7.00
(.275)
Normally Open
10.00
(.393)
Ø9.50
(.374 DIA)
9433N B
5.08
(.200)
Ø8.50
(.334 DIA)
C94NDT-A
3.00
(.118)
19.00
(.748)
Normally Open
Panel cut-out : Ø 16.2 (.637)
Max. current/voltage rating. : 1 A 30 VDC
Epoxy sealed terminals. Options of the following pages not applicable.
2.00
(.078)
0.40
(.015)
Ø16.00x1.00SI
(.629DIAx1.00IS)
5.08
(.200)
5.20
(.204)
9633ADBX1146
Normally Open
9.50
(.374)
Gold plated
silver contacts
7.40
(.291)
Silver contact
9633ABX1146
Ø18.00
(.708DIA)
3.30
(.129)
Ø12.00
(.472DIA)
1.50
(.059)
BUSHING Ø 16 (.630)
METAL PLUNGER : 9633•X1146
Hex nut 19 (.748) across flats
CONTACTS MATERIALS
BASIC P/N
A Silver
CD
Brass, gold plated
Special contact, lower rating : see X601 under "Special options".
SEALING
BASIC P/N
Epoxy sealed terminals (standard)
KB
Combined sealings
Epoxy sealed terminals + front panel sealing by two
O-rings. Protects the switch against water and dust.
Panel seal withstands 0.1 bar pressure.
Option KB not available on 9400Y model.
5.50 Maxi
(.216 MAX)
B
1
O-rings
B
Sealing boots : see “Sealing boots“ section of website.
KB
5
PANEL SWITCHES
5.00
(.196)
5.08
(.200)
1.50
(.059)
EPOXY
0.40
(.015)
SPECIAL OPTIONS
BASIC P/N
X601
Silver plated brass contacts
Current/voltage rating for an electrical life of 20,000 cycles : 0.5 A 30 VDC.
Minimum quantity : 5,000 pieces per model and shipment.
X1146 Model with dia. 16 (.630) bushing and metal plunger
See previous page.
CAPS
Order separately.
For cap colors,
replace last "0" by number :
1
Blue
1/4
Dark blue
2
Black
3
Green
4
Grey
5
Yellow
6
Red
7 Ivory
7/1
White
9
Orange
U1140
Ø15.00
(.590 DIA)
U2020
Square
U2430
Square
Ø6.35-40UNS
(1/4-40UNS)
U1636
For cap U1140
6
Ø10.50
(.413 DIA)
Ø15.50
(.610 DIA)
5.80
(.228)
Ø18.50
(.728 DIA)
8.00
(.314)
8.00
(.314)
6.20
(.244)
Ø8.20
(.322 DIA)
Ø13.50
(.531 DIA)
5.80
(.228)
Order separately. Chrome plated.
Ø12.70
(.500 DIA)
Ø6.35-40UNS
(1/4-40UNS)
U840
For cap U480
3.00
(.118)
6.35
(.250)
5.00
(.195)
4.00
(.157)
3.00
(.196)
U630
U480
Standard
11.50x11.50
(.452 SQ)
11.50x11.50
(.452 SQ)
10.00
(.393)
3.00
(.118)
U1720
6.00
(.236)
U900
3.00
(.118)
6.35
(.250)
3.00
(.118)
4.00
(.157)
3.30
(.129)
7.50
(.295)
Ø5.00
(.196)
Ø10.00
(.393)
Ø9.40
(.370)
Ø8.00
(.314)
DRESS NUTS
8.20
(.322)
PANEL SWITCHES
9400-9600 series
Ø6.35-40UNS
(1/4-40UNS)
U825
For cap U630
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
9432AB 9432CDB 9432YCDB 9433AX1146 9433CDB 9433NCDB 9435CDB 9435YCDB 9633ADX1146
9633AX1146 9635AB 9433AB 9433AB+U907 9433CD 9433YA 9632AB3 9632CDB 9633NAB3 9633NAKB
9633NCDK 9435AB
很抱歉,暂时无法提供与“9433NCDB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+58.4082950+7.54990
