9632CDB
9632CDB
    APEM(埃斐)
    SWITCH PUSH SPST-NC 0.1A 30V
9632CDB 数据手册
PANEL SWITCHES 4 -9 SW 0 96 00 1 80 1 0- 9400-9600 series Momentary pushbutton switches DISTINCTIVE FEATURES Two case lengths Three electrical functions Sealing options Model X1146 with Ø 16 (.630) bushing ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contact (A) : 1 A 30 VDC - gold plated contacts (CD) : 100 mA 30 VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. at 500 VDC • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 1,500 Vrms 50 Hz min. between terminals and frame • Electrical life : 250,000 cycles GENERAL SPECIFICATIONS • Total travel : 9600-9400-9400Y 9600N-9400N Functions 3 and 5 Function 2 Function 3 1.3 mm 2 mm 0.9 mm • Torque : 1.25 Nm (.922 Ft.lb) max. applied to nut • Operating temperature : -30 °C to +65 °C (-22 °F to +149 °F) MATERIALS • Case : thermoplastic UL94-V0 • Actuator : polyamide, glass filled • Bushing : brass, nickel plated • Contacts : A : silver CD : brass, gold plated • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 PANEL SWITCHES 9400-9600 series Momentary pushbutton switches PANEL CUT-OUT Ø6.50 (.255 DIA) 4.55 (.179) 8.70 (.342) 2.40 (.094) TERMINALS 9600Z1 5.20 (.204) 2.80 (.110) OSP CIPCOSZ1 1.50 (.059) 1.20 (.047) 9600 4.55 (.179) 1.20 (.047) 5.20 (.204) 1.00 (.039) 1.00 (.039) 2.00 (.078) C96COSSO-2 1.50 (.059) 4.55 (.179) 5.20 (.204) C96COSPO-2 9400 1.00 (.039) 2.00 (.078) C96COSPO-2 ELECTRICAL FUNCTIONS FICHIER: C96COS-2 ECHELLE:1.5 LE 24-09-92 corrige le 07-01-2010 FICHIER: C96COS-2 Function 2 (NC) ECHELLE:1.5 LE 24-09-92 Function 3 (NO) corrige le 07-01-2010 2 Function 5 (combined) Momentary pushbutton switches BUILD YOUR PART NUMBER BASIC PART NUMBER 9 SERIES NUMBER OF POLES TERMINALS, CASE AND BUSHING 3 Case length 11.2 (.440) ELECTRICAL FUNCTIONS 2 Normally closed (NC) 4 Straight PC terminals 3 Normally open (NO) 6 Solder lug terminals 5 Combined (NC/NO) 4..Y Single pole Straight PC terminals, bracket mounting Case length 8.5 (.334) 4..N Straight PC terminals 6..N Solder lug terminals 6..NZ1 Quick-connect terminals All models have Ø 6.35 (1/4) threaded bushing. OPTIONS ORDER SEPARATELY. CONTACT MATERIALS A CD Silver Brass, gold plated SEALING B KB SPECIAL OPTIONS Epoxy sealed terminals (standard) X1146 Front panel sealing by two O-rings not available with 9400Y. X601 Bushing Ø 16 (.630) Special contact, lower rating CAPS U900 Ø 5 (.196) U1140 Ø 8 (.314) U1720 Ø 9.4 (.370) U480 Ø 10 (.393) standard U630 Ø 15 (.590) U2430 Square - Height 4 (.157) U2020 Square - Height 6 (.236) ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Sealing boots are available to protect the switches against dust and water. See "Sealing Boots" section of website. Mounting accessories : standard hardware supplied with all models : 2 hex nuts 8 mm (.314) across flats and 1 lockwasher. Standard and special hardware available is presented in the “Hardware“ section of website. 3 PANEL SWITCHES 9400-9600 series 6.00 (.236) Ø4.00 (.157 DIA) 11.20 (.440) 2.00 (.078) NO NO Ø10.00 (.393 DIA) NC Ø6.35-40UNS (1/4-40UNS) 0.40 Ø9.00 (.015) (.354 DIA) 5.08 (.200) NO NO NC 0.40 Ø10.00 (.015) (.393 DIA) 5.08 (.200) Ø9.00 CK96DT-A (.354 DIA) 5.20 (.204) 11.20 (.440) 11.20 (.440) NO EPOXY 5.20 (.204) 2.00 (.078) Combined function 5.08 (.200) NO 4.55 (.179) NC F5 0.40 (.015) 5.08 (.200) 15.75 (.620) C94YDT-A 3.18 (.125) 8.50 (.334) Ø9.50 (.374 DIA) C94YDT-A EPOXY 5.00 (.196) 5.08 (.200) 15.75 (.620) Ø6.35-40UNS (1/4-40UNS) F5 0.40 (.015) 15.75 15.75 (.620) (.620) 5.08 (.200) NO Ø1.60 (.062 DIA) 3.18 C94YDT-A (.125) NO 15.75 (.620) 8.20 (.322) 7.00 (.275) Normally Open 15.75 (.620) 15.75 (.620) 4.10 (.161) Ø4.00 (.157 DIA) 3.18 (.125) Ø1.60 (.062 DIA) NO 2.00 (.078) 1.50 (.059) 4.10 (.161) 0.40 (.015) F2 5.08 3.18 (.200) (.125) NC NC 3.18 0.40 3.18 (.015) (.125) (.125) 5.08 (.200)F5 EPOXY Ø1.60 (.062 DIA) 15.75 (.620) NO 0.40 Ø6.35-40UNS (.015) (1/4-40UNS) 0.40 (.015) 5.08 EPOXY (.200) F2 9633N B 5.08 (.200) 5.08 (.200) 13.00 (.511) 4.10 (.161) 13.00 (.511) 13.00 (.511) 3.18 F2 (.125) 1.17 (.046) NO NO 0.40 15.75 (.015) (.620) 1.17 8.20 (.046) (.322) 6.00 (.236) EPOXY Ø4.00 (.157 DIA) 8.20 (.322) SOLDER LUG TERMINALS CASE LENGTH 8.5 (.334) : 9600N Ø6.35-40UNS (1/4-40UNS) 3.18 (.125) 1.17 (.046) Ø10.00 (.393 DIA) 3.18 (.125) Ø10.00 (.393 DIA) 5.08 (.200) 6.60 (.259) 6.00 (.236) The bracket is not fastened to the switch. CK94DT-A 5.08 (.200) Ø6.35-40UNS (1/4-40UNS) Ø4.00 (.157 DIA) Ø10.00 (.393 DIA) Combined function 5.08 (.200) CK94DT-A 6.60 (.259) 9435Y B Normally Open 0.40 (.015) Ø4.00 (.157 DIA) 6.60 (.259) 9433Y B Normally Closed 6.00 (.236) 9432Y B NO NC 6.00 (.236) BRACKET MOUNTING CASE LENGTH 11.2 (.440) : 9400Y Ø1.60 (.062 DIA) Ø1.60 CK94DT-A (.062 DIA) Ø9.00 (.354 DIA) EPOXY 1.00 (.039) 5.08 (.200) 0.40 (.015) Ø10.00 (.393 DIA) 5.08 (.200) 1.00 (.039) 5.08 (.200) NO NC 5.08 (.200) 5.08 (.200) NO EPOXY 5.08 (.200) 4.55 (.179) 11.85 (.466) 1.00 (.039) NO NO Ø10.00 (.393 DIA) NC Ø6.35-40UNS 0.40 (1/4-40UNS) (.015) Ø9.00 5.08 (.354 DIA) (.200) 5.08 5.08 (.200) (.200) Combined function Ø4.00 (.157 DIA) 4.55 (.179) 9435 B 5.08 (.200) Ø1.60 (.062 DIA) Ø9.00 (.354 DIA) 11.85 (.466) Normally Open CK96DT-A Ø6.35-40UNS (1/4-40UNS) Ø10.00 11.85 (.466) 7.00 (.275) 9433 B 7.00 (.275) Normally Closed 5.08 (.200) (.393 DIA) EPOXY 6.00 (.236) 9432 B CK96DT-A Ø6.35-40UNS (1/4-40UNS) Ø4.00 (.157 DIA) 6.00 (.236) STRAIGHT PC TERMINALS CASE LENGTH 11.2 (.440) : 9400 0.40 (.015) 5.08 (.200) Ø4.00 (.157 DIA) 6.00 (.236) 9635 B NO NC 5.08 (.200) Normally Closed 7.00 (.275) 9632 B 2.00 (.078) 5.20 (.204) EPOXY 5.08 (.200) 7.00 (.275) Ø9.00 (.354 DIA) Ø4.00 (.157 DIA) EPOXY 6.00 (.236) Ø6.35-40UNS (1/4-40UNS)Ø10.00 (.393 DIA) 7.00 (.275) SOLDER LUG TERMINALS CASE LENGTH 11.2 (.440) : 9600 Ø6.35-40UNS (1/4-40UNS) Ø4.00 (.157 DIA) 6.00 (.236) Momentary pushbutton switches 7.00 (.275) PANEL SWITCHES 9400-9600 series Ø8.50 (.334 DIA) Also available with quick-connect terminals 2.8 x 0.5 mm : 9633NZ1 4 C96NDT-A 2.00 (.078) 9400-9600 series Ø8.50 (.334 DIA) C96NDT-A Momentary pushbutton switches Ø4.00 (.157 DIA) 6.00 (.236) STRAIGHT PC TERMINALS CASE LENGTH 8.5 (.334) : 9400N Ø6.35-40UNS (1/4-40UNS) 3.50 (.137) 5.08 (.200) Ø1.60 (.062 DIA) EPOXY 0.40 (.015) 1.00 (.039) 1.50 (.059) 7.00 (.275) Normally Open 10.00 (.393) Ø9.50 (.374 DIA) 9433N B 5.08 (.200) Ø8.50 (.334 DIA) C94NDT-A 3.00 (.118) 19.00 (.748) Normally Open Panel cut-out : Ø 16.2 (.637) Max. current/voltage rating. : 1 A 30 VDC Epoxy sealed terminals. Options of the following pages not applicable. 2.00 (.078) 0.40 (.015) Ø16.00x1.00SI (.629DIAx1.00IS) 5.08 (.200) 5.20 (.204) 9633ADBX1146 Normally Open 9.50 (.374) Gold plated silver contacts 7.40 (.291) Silver contact 9633ABX1146 Ø18.00 (.708DIA) 3.30 (.129) Ø12.00 (.472DIA) 1.50 (.059) BUSHING Ø 16 (.630) METAL PLUNGER : 9633•X1146 Hex nut 19 (.748) across flats CONTACTS MATERIALS BASIC P/N A Silver CD Brass, gold plated Special contact, lower rating : see X601 under "Special options". SEALING BASIC P/N Epoxy sealed terminals (standard) KB Combined sealings Epoxy sealed terminals + front panel sealing by two O-rings. Protects the switch against water and dust. Panel seal withstands 0.1 bar pressure. Option KB not available on 9400Y model. 5.50 Maxi (.216 MAX) B 1 O-rings B Sealing boots : see “Sealing boots“ section of website. KB 5 PANEL SWITCHES 5.00 (.196) 5.08 (.200) 1.50 (.059) EPOXY 0.40 (.015) Momentary pushbutton switches SPECIAL OPTIONS BASIC P/N X601 Silver plated brass contacts Current/voltage rating for an electrical life of 20,000 cycles : 0.5 A 30 VDC. Minimum quantity : 5,000 pieces per model and shipment. X1146 Model with dia. 16 (.630) bushing and metal plunger See previous page. CAPS Order separately. For cap colors, replace last "0" by number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7 Ivory 7/1 White 9 Orange U1140 Ø15.00 (.590 DIA) U2020 Square U2430 Square Ø6.35-40UNS (1/4-40UNS) U1636 For cap U1140 6 Ø10.50 (.413 DIA) Ø15.50 (.610 DIA) 5.80 (.228) Ø18.50 (.728 DIA) 8.00 (.314) 8.00 (.314) 6.20 (.244) Ø8.20 (.322 DIA) Ø13.50 (.531 DIA) 5.80 (.228) Order separately. Chrome plated. Ø12.70 (.500 DIA) Ø6.35-40UNS (1/4-40UNS) U840 For cap U480 3.00 (.118) 6.35 (.250) 5.00 (.195) 4.00 (.157) 3.00 (.196) U630 U480 Standard 11.50x11.50 (.452 SQ) 11.50x11.50 (.452 SQ) 10.00 (.393) 3.00 (.118) U1720 6.00 (.236) U900 3.00 (.118) 6.35 (.250) 3.00 (.118) 4.00 (.157) 3.30 (.129) 7.50 (.295) Ø5.00 (.196) Ø10.00 (.393) Ø9.40 (.370) Ø8.00 (.314) DRESS NUTS 8.20 (.322) PANEL SWITCHES 9400-9600 series Ø6.35-40UNS (1/4-40UNS) U825 For cap U630 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: 9432AB 9432CDB 9432YCDB 9433AX1146 9433CDB 9433NCDB 9435CDB 9435YCDB 9633ADX1146 9633AX1146 9635AB 9433AB 9433AB+U907 9433CD 9433YA 9632AB3 9632CDB 9633NAB3 9633NAKB 9633NCDK 9435AB
9632CDB 价格&库存
很抱歉,暂时无法提供与“9632CDB”相匹配的价格&库存,您可以联系我们找货
