PANEL SWITCHES
SW
08
18
ZP
ZP series
Subminiature pushbutton switches • metal bushing
DISTINCTIVE FEATURES
Ø 4.83 mm threaded bushing
Solder lug and straight PC terminals
ELECTRICAL SPECIFICATIONS
• Max. current/voltage rating with resistive load :
- gold plated contacts : 0.4 VA 20 V max. AC or DC
- silver plated contacts : 0.5 A 48V max. AC or DC
• Minimum load : 10 mA 50 mV - 10 µA 5 VDC
• Contact resistance : 50 mΩ max.
• Insulation resistance : 1,000 MΩ min. at 500 VDC
• Dielectric strength: 1,000 Vrms 50 Hz min. between terminals and
frame / 500 Vrms 50 Hz min. between terminals
• Electrical life at full load :
- gold plated contacts : 60,000 cycles
- silver plated contacts: 20,000 cycles
ENVIRONMENTAL SPECIFICATIONS
• Operating temperature : -30 °C to +85 °C (-22 °F to +185 °F)
• Moisture : 21 days 95 % (NFC 20-603 - IEC 68-2-3)
GENERAL SPECIFICATIONS
• Travel :
- function 2 (ON-MOM) : 1.2 mm (.047) ± 0.3 (.11)
- function 3 (OFF-MOM) : 1 mm (.039) ± 0.3 (.11)
• Strength of terminals : pull-out force 10 N max.
• Torque : 1 Nm max. applied between the 2 nuts
• Max. panel thickness : 1.5 mm (.059) with 2 nuts
SOLDERING
• Hand soldering : 280 °C (536 °F) max. for 5 seconds max.
• Wave soldering : 260 °C (500 °F) max. for 5 seconds max.
The company reserves the right to change specifications without notice.
1
MATERIALS
TERMINALS
• Case : thermoplastic UL94-V0
• Bushing : zamac, tin plated
• Contacts and terminals :
0 : brass, gold plated (standard)
1 : brass, silver plated
3 : brass, gold plated (1.27 micron gold)
0.75
(.029)
0.70
(.027)
3.30
(.129)
• Actuator : thermoplastic UL94-V0
1.50
(.059)
PANEL SWITCHES
ZP series
1.50
(.059)
Solder lug
Straight PC
• Terminal seal : epoxy
APEM products may be recycled at end-of-life for the re-claiming of valuable metal
components.
ELECTRICAL FUNCTIONS
3 2 1
Function 2
(ON - MOM)
2
1
3
Function 3
(OFF - MOM)
BUILD YOUR PART NUMBER
BASIC PART NUMBER
ZP
SERIES
NUMBER OF POLES
3
Single pole
TERMINALS
2
ON - MOM
S0
Solder lug
3
OFF - MOM
P0
Straight PC
OPTIONS
BUSHING
CONTACT AND TERMINAL MATERIALS
Brass, gold plated
1
Brass, silver plated
3
Brass, gold plated
(1.27 micron gold)
01
Threaded, with flat
MODELS
00
Standard model
ABOUT THIS SERIES
On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart
Notice: please note that not all combinations of above numbers are available. Refer to the following pages for further information.
Mounting accessories: Standard hardware supplied with all models : 2 hex nuts 7 mm (.275) across flats P/N U5731,
1 locking ring P/N U5831 and 1 lockwasher P/N U5841.
3
PANEL SWITCHES
ZP series
SOLDER LUG TERMINALS
Ø2.50
(.098 DIA)
Ø4.83-48UNS-2A
3.95
(.156)
Shown in function 2 (ON-MOM)
FLAT
ON
MOM
ZP33S0
OFF
MOM
2.80
(.110)
5.60
(.220)
4.00 8.60
(.157) (.338)
Ø6.00
(.236 DIA)
ZP32S0
0.50
(.019)
(10-48UNS-2A)
EPOXY
1.50
(.059)
3 2 1
2.54
(.100)
0.50
(.019)
5.00
(.196)
8.10
(.318)
4.39
(.172)
Ø2.50
(.098 DIA)
3.95
(.156)
FLAT
Ø4.83-48UNS-2A
8.60
(.338)
Ø6.00
(.236 DIA)
3.30
(.129)
5.60
(.220)
0.50
(.019)
(10-48UNS-2A)
ZP32P0
ZP33P0
ON
OFF
EPOXY
MOM
3 2 1
2.54
(.100)
2.54
(.100)
MOM
0.50
(.019)
Ø1.10
(.043 DIA)
8.10
(.318)
5.00
(.196)
PANEL SWITCHES
ZP series
CONTACT & TERMINAL
MATERIALS
BASIC P/N
3
00
Brass, gold plated (standard)
Brass, gold plated (1.27 micron gold)
BUSHING
BASIC P/N
01
00
Ø4.90
(.193 DIA)
Threaded, with flat
4.39
(.172)
4
Ø4.90
(.193 DIA)
4.50
(.177)
Ø2.40
(.094 DIA)
6.10
(.240)
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
ZP33S000100 ZP33W000000
很抱歉,暂时无法提供与“ZP33S000100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.959371+12.34441
- 10+81.9512810+10.65340
- 25+77.2771625+10.04578
- 50+73.9112250+9.60822
- 100+70.68828100+9.18925
- 300+65.85411300+8.56082
- 500+63.71563500+8.28283
- 1000+60.919451000+7.91933
